Jason 98 TA
Old 07-06-2011, 11:46 AM   #1
Becustom
ProCharged 600 + RWHP
Becustom's Avatar
Drives: 2SS/RS White/Hugger Orange
Shifting Issues !
Ok ,
I'm really sick and tired of the way my trans shifts !!
I have the LS9R Katech clutch with a remote reservoir and yes it's bled correctly .
This is by far the worst shiffting set up i have ever owned !!
Any help or info on a fix would be great .
Becustom is offline   Reply With Quote
Old 07-06-2011, 12:27 PM   #2
DarkObsession
Drives: 2011 Camaro SS2/LS3
I'm not certain you could be more vague.
What exactly is the problem with the shifting? What is bothering you about it? There are a lot of things that could mean "Shifting issues".
Please elaborate and we will try to help.
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH
DarkObsession is offline   Reply With Quote
Old 07-06-2011, 01:35 PM   #3
Becustom
Becustom's Avatar
Under hard runs it shifts extremely hard and some times will not go into some gears.
From all the people i talk to and research that Iv'e done . It seams the clutch is not Disengaging fully . And the shifting is worse now with the new clutch.
Very frustrating
I guess i'll have to pull it out and have it checked .
Old 07-06-2011, 01:56 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Just out of curiousity, have you taken it to the dealer? What did they say about it all? Or possibly the shop that installed the clutch?
Click to view my build thread
Old 07-06-2011, 02:45 PM   #5
Becustom
Becustom's Avatar
No warranty since day one . To many mods. I installed it.
Old 07-06-2011, 04:56 PM   #6
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
I have the same problem. When you push your clutch pedal to the floor do you still have to push it an extra 1/2" with the tip of your foot to get it to fully disengage?
TC is offline   Reply With Quote
Old 07-07-2011, 01:53 AM   #7
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
If it's not fully disengaging it will "creep".
Clutch in, rev as high as you dare, no foot on brake. I had this shifting problem on another car and I took it drag racing. Wouldn't stay in the lights on the 2-step. Clutch was not fully disengaging.
Try it.
Good luck, I know how frustrating it can be.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 07-07-2011, 02:04 AM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
WOW, is that clutch really $1,700?
SUX2BU is offline   Reply With Quote
Old 07-07-2011, 02:56 AM   #9
TC
TC's Avatar
Yep! I don't know why everything cost so much for this car.
Old 07-07-2011, 03:28 AM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Not everything. you have to know where to find the good deals at. You can find a great clutch that holds 800 ft lbs with a new flywheel for about $630, which ids still about $200 too high.
I got my complete exhaust for $750 (it' snow down to $650) and some people pay over 2 grand!
Old 07-07-2011, 10:53 AM   #11
Becustom
Becustom's Avatar
hey TC ,
Yes it's disengaging at idle and when reving it up.
It starts to engage about 3 " off the floor.
I have been trying to really make sure I push it all the way to the floor before I shift.
Old 07-07-2011, 06:45 PM   #12
TC
TC's Avatar
Hoping it just needs to be broke in a little more. The fingers should give a little once I put some miles on her?
Old 07-08-2011, 12:09 AM   #13
BWood
BWood's Avatar
Drives: 2010 Camaro 2SS/RS M6
I've used a different slave cylinder/bearing, different clutch master, changed the hydraulic lines, split the reservoir, and used just about every tranny fluid under the sun and NOTHING made this issue go away for me. I am completely convinced that it's the tranny and not the clutch. I'm just gonna deal with it for now and buy a better transmission later.
BWood is offline   Reply With Quote
Old 07-08-2011, 08:31 AM   #14
Stingr69
'69 Owned Since '79
Stingr69's Avatar
What fluid are you using in the tranny? I would be concerned that you may have the wrong stuff in there.
I have been blocked out of 3rd gear before but it was only when trying to power shift. It was the first time I ever tried to shift without lifting off the gas between gears. It just would not go into 3rd gear and I had to watch the other guy blast on past me through the lights. I plan on just granny shifting it now at the track. Lift before you shift is the plan!
-Mark.
GM doesn't care about my clutch issues O2BQIK Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 200 07-05-2012 02:23 AM
Camaro 2010 Issues Tim's.2010.Camaro.SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 57 06-04-2010 10:27 AM
?thump? feel in shifter when shifting honeybucket99 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 01-06-2010 12:18 PM
Shifting Problem? TonytheTiger 5th Gen Camaro SS LS LT General Discussions 13 12-10-2008 09:46 AM
