Old 07-09-2011, 09:33 PM   #15
SC2150
Brailles are awesome. We use them in the drag cars to reduce weight.
As for the alt, get an overdrive alt pulley whenever you use an underdrive crank pulley and/or have a sound system or other high draw accy. They are cheap for the billet ones.
Old 07-09-2011, 11:59 PM   #16
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 07-10-2011, 12:30 AM   #17
Sawyer
Sawyer's Avatar
Drives: '13 5.0
Nice. What is the price for the 21lb?
Sawyer is offline   Reply With Quote
Old 07-10-2011, 01:27 AM   #18
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by 2010 L99 View Post
Can someone explain the difference from Cranking Amps (CA) and Cold Cranking Amps (CCA)? Technical specs page says 426 CCA and 574 CA for the B2015.
Is the stock battery 720 CA or CCA?
CCA is the maximum amperes that can be continuously removed from a battery for 30 seconds at 0°F before its voltage drops to unusable levels. A 550 CCA battery can supply 550 amperes for 30 seconds at 0°F. This rating is only useful in the selection of engine starting batteries.
CA is the same except it is measured at 3
0°F
The 15 lb Braille has a 21 amp hour rating compared to the stock battery's 80 amp hour rating. So the 15 lb battery has roughly 1/4 the capacity of the stock battery.
About $180 on ebay.
SUX2BU is offline   Reply With Quote
Old 07-10-2011, 09:42 AM   #19
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Braille batteries are great. I put the same one in mine some time ago and haven't had a single issue with it. You can get them at Summit Racing, Jegs, even Amazon carries them I believe. Or Ebay.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 11-01-2011, 11:11 AM   #20
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by BMR guy View Post
SUX2BU, how do you like that Braille battery? I was just looking at them the other day but heard they have charging issues if the car isn't daily driven. Any issues with yours?
Mine is daily driven so I can't answer that part of the question for ya, but it has been about four months and 6,000 miles since I installed the battery and it's working great! I think the longest I have gone without driving my car is two days, lol. The true test will be on the coming months when I have to start the car with temps in the low twenties/high teens, that's about the coldest it gets around here.
Old 11-01-2011, 11:49 AM   #21
BlackMamba88
BlackMamba88's Avatar
Drives: 2010 Challenger 345 R/T
Wow def something worth getting!!! What about if you were to add a subwoofer with over 800rms watts??
BlackMamba88 is offline   Reply With Quote
Old 11-01-2011, 06:05 PM   #22
Kwik
Drives: car
Nice looking package. How come you didn't use the Braille mounting bracket?
Upgrades to suspension, brakes, motor and appearance. 482.7 RWHP- 434.2 RWT - All motor.
Kwik is offline   Reply With Quote
Old 11-01-2011, 08:56 PM   #23
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Cause it's $75 and the stock bracket works fine.
Old 11-01-2011, 09:07 PM   #24
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
I used stock as well, just a little different style of packaging. It is certainly adequate.
DietCoke is offline   Reply With Quote
Old 01-19-2012, 08:09 PM   #25
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Just an update since I have gotten a couple of questions about my battery lately.
The only time ever the battery has struggled to start was when my car was off, I had all my lights on, including headlights, for about 40 min to get video and pictures of the Wind Restrictor.
Oh and I have an ASP under drive pulley also so it doesn't charge as much as a stock pulley would.
The only time I wouldn't recommend this battery is if you have a huge audio/video system or if you have really cold/long winters.
Old 06-05-2012, 12:03 PM   #26
camaro2lt
camaro2lt's Avatar
just bought this same battery hope it works for me since i go to car shows and leave my led orcale halos on for 5hrs at a time. i also hate the weight of these cars i took out my spare tire (45lbs) Jack stand(5lbs) wheel kit(3lbs) and the stock battery that weiged 50lbs. the total of all that is 105lbs just for 4 thigs in the trunk lol. i got the 15lb battery soo now i just have 15lbs in my trunk/
Old 09-18-2012, 02:16 PM   #27
Coyotekiller
Drives: 2012 AGM 2SS
Coyotekiller is offline   Reply With Quote
Old 09-18-2012, 02:39 PM   #28
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by Coyotekiller View Post
Whatcha waitin' on?
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
EXTREMELY LIGHT WEIGHT WHEELS COR Forged Wheels and Tires Talk Sponsored by The Tire Rack 30 10-18-2009 03:33 PM
Anyone??? 0-60, 1/4 time, & speed on stock SS 20" VS. 19" or 20" light weight wheels? 2cnd chance Dragstrip and Launch Techniques Discussion 2 09-19-2009 06:57 PM
