Old 07-09-2011, 10:17 AM   #1
Final187
Final187's Avatar
Drives: 2011 black 2lt camaro
Nitrous what come in zex kit?
hello everyone i am about to order a zex nitrous kit, and was curious as to what comes in it... Every site i have looked at gives very vague info as to what is actually included... But i guess the only thing i want to know is does it come with a switch or anything to control when it turns on and off???
"this innovative nitrous system’s Active Fuel Control™ adjusts fuel delivery with changes in nitrous bottle pressure, so that your engine never runs too rich or too lean while spraying. In addition, the system also offers an electronic TPS switch for reliable system activation at wideopen throttle; perfect for the Camaro’s throttle-by-wire system."
Final187 is offline   Reply With Quote
Old 07-10-2011, 12:41 PM   #2
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
It has a throttle position switch combined in the module that houses the solenoids. That allows it to come on when at WOT.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 07-10-2011, 08:01 PM   #3
Final187
Final187's Avatar
Thank you for the info, was really sad to see 30+ views but know one could give any info.....
Old 07-10-2011, 08:40 PM   #4
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
I would also purchase the purge and window switch right away. You can then get some other components little by little. Like bottle warmer, remote bottle opener, and some other safety equipment.
Old 07-11-2011, 11:39 AM   #5
Graham@N
Drives: Pontiac Firebird
If you are looking for a complete system with some good tech help. Let me know. I can give you some in site on a good system as well as how it all will work on your platform.
If not, best of luck with Zex. Nitrous is a blast either way if setup correctly.
Graham@N is offline   Reply With Quote
Old 07-11-2011, 01:16 PM   #6
bmorecam
Hey graham, I heard that its safer to use nitrous when combined with e85 due to the nature of high octane at 105-110 and its cooling traits. I also heard that you gain more HP when spraying vs gas. For an example, a 50hp 50 shot would net you around 75-85 with E85. I've heard that some folks switch to E85 just to spray. How true is all this?
Clearing up some bad information on nitrous Graham@N Forced Induction - V6 12 07-05-2011 03:13 PM
ZEX WET NITROUS KIT FOR SALE Nique303 Local Marketplace 0 05-07-2011 09:23 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
V6 Camaro's - NITROUS KIT!! Add 50-100 Horsepower - Phastek Performance Sean@Phastek V6 Bolt-Ons & Tunes 1 06-09-2010 01:29 PM
Zex Nitrous System for 2010 Camaro SS @ BMC Performance! Kris@BMCPerformance Forced Induction 2 02-18-2010 07:59 PM
