Old 07-09-2011, 11:58 AM   #1
Divrdown
Divrdown's Avatar
Drives: 2017 2SS Hyper Blue
cracks in sidewall
Has anyone had any issues with their tires? Just washing the car up and found that the drivers side front tire has cracks starting in the sidewall like an old tire. They are short for now but there are probably 100 of them, the picture is kind of blury but you can see them.
Divrdown is offline   Reply With Quote
Old 07-09-2011, 11:59 AM   #2
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
I dont see them.
Old 07-09-2011, 12:26 PM   #3
ssummit camaro
ssummit camaro's Avatar
Drives: 2013 1LE on order TPW 12/31
cant see anything
ssummit camaro is offline   Reply With Quote
Old 07-09-2011, 12:41 PM   #4
Divrdown
Divrdown's Avatar
OK here are a couple of better pics, maybe we can see tehm now.
Old 07-09-2011, 12:46 PM   #5
GEEo
OKCamaros
GEEo's Avatar
WOW thats sucks man!!
You should get a new set before you get into an accident. just to be in the safe side.
Old 07-09-2011, 01:23 PM   #6
suplex
suplex's Avatar
Drives: 2011 Coupe, 1LT, A6, No RS Package.
Not to be off topic, but then again...it may not be off topic, what kind of tires are those that your Treadware is only 220? I have 18" Tires on my 1LT Camaro and my Treadware is 620.
I always knew that with low profile tires (that fit on 20" wheels and above) they don't last as long as tires that have a higher profile, but I had no idea that you would be having problems already...and you have a 2011 so you can't even have had it a full calendar year yet.
If this problem persists, and you find yourself having to buy tires all the time, I would seriously consider getting new wheels, as well, and downsizing to 18".
You may not like the look as much, but for what it could save you in tires (especially having to constantly replace 20" tires...if that is the size you have) the cost of the new wheels would be worth it.
Never Underestimate The Power of Forums
suplex is offline   Reply With Quote
Old 07-09-2011, 03:03 PM   #7
Divrdown
Divrdown's Avatar
Car is brand new to me, have had it about 11 days it was manufactured in June of 2010 by the build stickers. I can tell it sat out side for some time due to the heavy rust on the rear rotors even inside the vents (being replaced by dealer). But the only tire affected was the front left. The tires are on the 2SS / RS 20" Pirelli's and yea I know they are only rated at 220 but thats the cost for sticky low profile tires, will upgrade when they wear out.
Anyway I hate to have to only replace one front tire and get into uneven wear issues between the fronts. There are only about 760 miles on the tires. I know the dealer will replace the defective one but what about the other front and even if the rears develop a problem.
Old 07-09-2011, 11:06 PM   #8
Divrdown
Divrdown's Avatar
Any of you tire dealers ever see this on new rubber?
Old 07-18-2011, 02:16 PM   #9
Divrdown
Divrdown's Avatar
After discovering the issue with the tire dealer is going to replace. Are these tires hard to get from GM? Still no tire dealer says it might be another week.
Old 07-18-2011, 02:35 PM   #10
The Stig
knows 2 facts about ducks
The Stig's Avatar
The pzeros? No not by any means. They should have some in stock, and if they don't then it'll probably only take a few days for some to come in. Glad you are getting it all worked out. My guess is that the tires weren't at their proper pressure.
Click to view my build thread
Old 07-18-2011, 02:40 PM   #11
UUTUU
Drives: 2010 SS
Tires? I have a 2010 SS with 18,000 miles with the stock Perelli times and they are 90 % worn. Never burned out or skidded to a stop. Anyone else with this problem.
I'm IN NJ and interested in your used tires and or wheels.
UUTUU
UUTUU is offline   Reply With Quote
Old 07-18-2011, 02:41 PM   #12
Divrdown
Divrdown's Avatar
Yea PSI was low when I picked the car up bumped them up to the correct PSI which is about when I noticed the issue while washing but it appears to only of affected one tire. Just glad to get it taken care of.
Drag Radials - Sidewall vs Width FloMoCamaro Dragstrip and Launch Techniques Discussion 15 02-20-2011 10:47 AM
For sale: Front Bumper (cracks by passenger headlight) Tonka Exterior Parts & Accessories 0 06-02-2010 06:19 PM
PWNED! nail in rear sidewall! need new rear tire... AdamCzap Wheels and Tires Talk Sponsored by The Tire Rack 10 09-17-2009 11:52 PM
Roof Ditch Cracks on RS Package? CarbonFiberSS-RS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 17 06-27-2009 11:58 PM
Potential Huge Problem.... 2010 Camaro Nose Cracks (UPDATE: NOT A PROBLEM AT ALL!) Nine Ball 5th Gen Camaro SS LS LT General Discussions 328 05-03-2009 09:55 PM
