| Audio / Visual / Electronics/ Gauges / Nav Audio / Visual / Electronics/ Gauges / Nav |
| View our official forum sponsors list. |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: still saving! Join Date: Feb 2010
July 2011 Electronis specails at GMPARTSHOUSE.COM
As you know we can serve all your GM parts, Lloyd mats and Hawk brake pad needs (with more to come soon!) If there is anything you need please feel free to email myself at patrick@gmpartshouse.com or gene at gene@gmpartshouse.com and we will be happy to get you squared away. We have a price matching policy, however when ever possible we will beat the total price shipped, not to mention you will get our world renound customer service. With that said I am putting together specials lists of all the itms currently offered in our Camaro Catalog. Don't forget to check back often as I will be constantly adding new items. Here is a quick list for you all of our current Camaro electronics specials which can be viewed in more detail or ordered here http://store.gmpartshouse.com/partlocator/index.cfm?action=AccessoryCatalog&catalogid=7587&s iteid=214638&categoryID=161268 OR You can simply click the price to be taken to that specific product Audio System - Subwoofer ![]() Take your Camaro's technology to a higher level with an upgraded Audio System-Subwoofer. This system adds two 10-inch subs and a matched 200 watt amplifier to your Camaro in a custom, sealed enclosure. The system is tuned to enhance the factory GM sound system, adding low, clean sounding bass for true quality music reproduction. It's like putting surround sound in your Camaro. NOTE: SHIPPING WILL BE 35.00! The website will charge a shipping charge but we will adjust it off once we process the order This Personal Device interface Module (PDIM) allows the user to plug their remote audio devices (iPod, MP3 player, etc.) into the USB port. The PDIM allows for command and control of the remote audio device through the radio and steering wheel controls. Auxiliary Gauge Pack ![]() ****NEW AND IMPROVED AT A CHEAPER PRICE AS WELL**** We have revised this kit to make it better than the one that comes direct from GM. Our kit still uses all new GM parts but we have added the hardware to hardmount the gauges to the bezel just like it would be if done at the factory! Also is available with standard USA guages or metric for other countries! Keep tabs on vital vehicle functions with this Auxiliary Gauge Package. Includes Oil Pressure, Battery Volt, Oil Temperature, and Transmission Fluid Temperature gauges. The website will calculate a higher shipping charge but we will adjust it to 20.00 once we process the order. Includes Instructions, harness, gauges, top console trim, hardware to mount guages to plate Kit to add in the HUD to 5th Gen Camaros ![]() This is the complete kit to add a HUD to your Camaro. It includes the display (projector) switch, dash trim bezel, display bolts and nuts. The only additional item needed is a custom built harness ..... This item will ship anywhere in the 48 states for 15.00 flat fee. (The website will charge more but we will refund the difference once we process the order) Steering wheel radio control add on kit This is the complete kit to add the steering wheel radio controls to you Camaro. It includes the steering wheel switch and the harness to wire it into the vehicle. The only additional thing that will need to be done is for the BCM to be recalibrated which can easily be done by your local dealer. Hud only for adding or replacing ![]() This is the hud only from the 2011 Camaro. Can be used as a replacement or to retrofit your 2010 to the hud. Only additional items needed would be the custom harness, hardware, switch and trim bezel. A complete kit is also available with all this included at a special price. NOTE: We charge a flat 15.00 shipping for this item. The website will calculate a higher charge but we will adjust down when we process the order Upgrade module to give your old PDIM the new software This is for the module only for the PDIM with the updated software. This is all you need if you have the old PDIM with the old saftware and want to upgrade to the revised one. THIS WILL ONLY WORK IF YOU HAVE PREVIOUSLY INSTALLED THE PDIM OR IF YOU CAME FROM THE FACTORY WITH ONE. THIS WILL NOT ADD THE PDIM!!!. Price 103.91 Skip shift eliminator ![]() Decide for yourself what gear you want to be in! Dump that annoying first-to-fourth "skip-shift" GM incorporates into the 6-speed Camaro, Firebird, Corvette, GTO, GXP and Dodge Challenger's with SLP's Skip-Shift Eliminator. This PLUG IN piece requires no additional modifications to your vehicle. With it in place, you take complete control over gear selection. Isn't that why you got a 6-speed? Plug in installation. Shipped complete including easy installation instructions. Price 27.50 Programmer, 2010-11 Camaro Handheld Tuned DiabloSport with SLP tunes ![]() Looking for the most powerful PCM-tuning tool on the market for your V8 2010-11 Camaro or 2008-09 G8 GT/GXP? In addition to its dyno-proven performance programming, this portable, easy-to-use programmer allows you to fine-tune a wide range of computer-controlled powertrain functions for maximum power (up to 20 hp) and drivability. Manipulate the following parameters in minutes and at the touch of a button. Features: DoD disable Idle RPM Drive/Neutral Injector Slope Adjustment WOT Fuel 2k-3.8k / 4k-4.9k / 5.2k-7k Rev Limit WOT Spark (in degrees) 1k-3.8k / 4k-5k /5.2k-7k Fan adjustment, individual adjustment per temp dependent cell Tire Sizes Clear codes supported Live data and log supported Holds up to 5 custom tunes & Dat viewer is supported All standard DiabloSport features Price 359.99 The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM rnge, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be Price 289.99 "Strong" GM massairflow sensor for Camaro SS
![]() Here we have the strong mass airflow sensors with the leter and number designation on the body. These are the ones that have the revision to compensate for some earlier sensors dropping signal with increased airflow or in some atmospheric conditions especially after installing an intake such as a Vararam. Price 69.03
Patrick Trageser GM Parts House Our prices will NOT be beat! Find a cheaper price shipped and I will make sure we destroy it! ![]() Specailizing in all GM parts and Lloyd floor mats! 1-484-949-2099 |
get in on the deals
Ive got a question bout the MTX package.. is this some sort of PLug N PLay deal?? cause i miss my Pioneer system that came STOCK in my 2008 Cobalt SS turbo. im jus wonderin how this mounts up and plays
2011 Imperial Blue 1.5SS
![]() 2010 Silver Ice Cobalt SS |
It is a pluf and play direct bolt in. Comes with GM connectors to plug right inot the rear speakers and i s designed to mount up perfectly in the trunk area
![]() ![]() ![]() ![]() Drives: 2013 300C HEMI, 2012 Ram 4X4 HEMI Join Date: May 2009
Any way to delay shipping so it arrives August 1st? I am going to be out of town and don't want it sitting at door.
Ordered 2014 1SS 1LE NPP Recaros Backup Cam Sunroof AGM:
Status 1100: June 7 Status 2500: June 11 Status 3000: June 12 TPW July 15 |
#6 | |
#7 |
Email sent
#8 |
Knock Knock - sent emails
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange Metallic 2SS/RS Join Date: Dec 2009
http://www.camaro5.com/forums/showthread.php?t=150940
Founder Of GM Parts House
Home Of The Camaro Parts And GM Parts Specialist Please Visit GM Parts House Online or Call 484.949.2099. |
#10 |
Payment sent ! Thanks
| Thread Tools | |
| Napierville July 3rd 2011 | 06blownSS | Canada | 16 | 07-06-2011 03:50 PM |
| Camaro Corral at Laguna Seca Raceway July 8-9, 2011 | jbucknum | Camaro Motorsports Discussions | 3 | 07-03-2011 01:22 PM |
| Few pics of the car and Dallas Cars and Coffee (July 2 2011) | Crowley | Camaro Photos | Spyshots | Video | Media Gallery | 10 | 07-03-2011 11:04 AM |
| Heidts Performance Car Challenge July 15-17, 2011 | tribone | USA - Rockies / Midwest | 7 | 06-20-2011 11:40 AM |
| GM July Sales Results.. drumroll please? | Zabo | General Automotive + Other Cars Discussion | 14 | 08-05-2009 11:11 AM |
