Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions
Old 07-10-2011, 09:28 PM   #1
dereklburt
Drives: 2006 Lotus Elise GM 3.6DI
turbo question-water and oil hookup for turbo
I am wondering where the best place is to hook up a water and oil supply for the turbo? I am mounting the engine transverse in a mid engine car and adding a turbo.
Thank you
dereklburt is offline   Reply With Quote
Old 07-11-2011, 01:14 AM   #2
ZNOLMT
ZNOLMT's Avatar
Drives: Rally Yellow 2LT
I'm sure someone on here can help you out, but I have to ask ..
Are you seriously putting the Camaro LLT 3.6 in a Lotus Elise ??
AND throwing a Turbo on it??
Because if so, that sounds awesome!
ZNOLMT is offline   Reply With Quote
Old 07-11-2011, 06:20 AM   #3
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 2012 LFX/2011 EcoBoost F-150
For the oil most are building a manifold that bolts on to where the oil sending unit attaches. You'll need to of course fit the oil sending unit to the new manifold. I can't help you on the water part because mine are air cooled.
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-Drag Radials-CircleD 4000 Stall-GPI Fuel Enrichment System
586 RWHP & 606 RWTQ @20 psi on 93 Octane (unlocked converter)
1/8 mile -- 7.158 @ 102.10 (20psi)
Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 07-11-2011, 10:22 AM   #4
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
I planned to use the upper and lower radiator hoses for the water feed/return when I had water and oil fed ct26 turbos. The upper provides a vacuum for water return and the lower radiator hose is pressurized for water feed. JEGS sales radiator gauge adapters that could be clamped onto the hoses. http://www.jegs.com/i/Auto+Meter/105/2283/10002/-1
I think local autostores sale something similar for cheaper maybe. Just cut both hoses on a straight section and clamp the adapters in and your good to go. The only problem with this method is that some of the coolant won't be cooled since its bypassing the radiator through the turbo but I'm not sure of the net effect on the entire system.
Pt_killa is offline   Reply With Quote
Old 07-11-2011, 01:22 PM   #5
blackTT600
Drives: 2011 2LT M6 SC
we need pix of the build!!
blackTT600 is offline   Reply With Quote
Old 07-16-2011, 10:21 PM   #6
dereklburt
Yes I am putting the V6 in an Elise and adding a turbo. I am using the Saab 2.8V6 turbo exhaust manifolds. Same block as the 3.6L Here is a pic of the engine mounted in the car. Still a long way to go and this is all new territory as noone has done this before but it fits. At a finished weight of about 2100lbs, it will be a lot of fun
Old 07-16-2011, 10:34 PM   #7
ZNOLMT
ZNOLMT's Avatar
AWESOME !! This should turn out amazing !!
I take it you're fabricating up your own turbo? Or are you using an STS kit?
If you're making your own setup, I'm sure other people would love more turbo options for the V6!
Good luck!
Old 07-17-2011, 12:12 PM   #8
blackTT600
^using the 2.8V6 turbo manifolds, prob using the turbo. either way, with those heads are easy to turbo. this is going to be a SICK little car. good luck and keep up the pix. thanks.
Old 07-17-2011, 12:45 PM   #9
ZNOLMT
ZNOLMT's Avatar
Oh nice! Interesting too. Yeah, with the amount of power you'll be able to easily make, this thing will be a monster! It's great that the weight will still be really low too! Can't wait to see the progress! Looks like you've already made some significant headway though!
Old 07-17-2011, 07:38 PM   #10
blackTT600
Im really happy to see that people are using it in the "swap market" if you will i feel like this will force more after market to explode like the LS market has. our motors have all the potential in the world and its efficient and its lighter weight than a big V8
Old 07-18-2011, 07:55 PM   #11
Ramsey
Ramsey
Ramsey's Avatar
Drives: 2011 1LT IOM
talking about efficiency. with what mods I do have on my 6, I get around 38 MPG @ 72 MPH, and 48 MPG @ 45 MPH. It's really nice to have a car with the power of an 8, and the efficiency of a "Prius" LOL!!!
Ramsey is offline   Reply With Quote
Old 07-18-2011, 09:26 PM   #12
Mach
Mach's Avatar
Drives: White M6 1LT RS
No way! I just drove 600 miles and the best I did was 28.8 MPG at an average speed of 68 MPH and Temp around 91. And we both have a V6 RS.
How do you get 38 MPG at 72 MPH? Are you going downhill?
Sorry to go off topic.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 07-18-2011, 09:54 PM   #13
C586
Drives: 2011 Camaro LS
He is gotta be talking instant or something because that's impossible. There is no way a car this heavy will get that much out of a gallon of gas at that speed. I have tried and the best I have got is 32. And I was able to get 27.5 with my supra when it was 598rwhp.
C586 is offline   Reply With Quote
Old 07-19-2011, 06:31 AM   #14
Steppenwolf1980
Steppenwolf1980's Avatar
Drives: Chevy Camaro & Opel Speedster Turbo
Derek, but you do understand what the concept of a lightweight car is? I mean, putting a 3.6 Liter V6 in it isn't the way to go, imho. And yes, I know that Lotus will offer the Elise with the Evora's V6 engine next year, but all the Lotus drivers here are running mad about that. The car gets way too heavy. I run my Elise-based Opel Speedster Turbo with about 300hp now, at exactly 1950 lbs now (still getting lighter). Still the GM 2.0 V4 ecotec engine which came by factory, only changed turbo and some other stuff. Going to rebuild the engine in winter, swapping turbo to BorgWarner EFR and heading for about 400-450hp with still superb handling in the alps. So basically I get the same power as you do with the V6, but still saving a damn lot of weight. I wish you all the best for your project, but I am concerned that you can't keep the 2100lbs. Keep us informed!
Steppenwolf1980 is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 203 05-03-2013 09:23 AM
A Look at GM's Oil Life Monitoring System franknbeans Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 159 07-31-2012 10:22 AM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 111 12-13-2010 12:22 PM
ON STAR OIL Life % T_MECO Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 04-25-2010 08:55 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
