JUICEDMOTORSPORTS
Old 07-11-2011, 02:10 AM   #1
maverickmage
Drives: Camaro V6 LS
Is there a way to shorten clutch travel?
Well... I had my Camaro for about 2 weeks now. Had it parked on the street and someone vandalized it (broke my right side mirror). Took my car to the shop today.
On the way back, I drove my brother's Civic SI. I could almost cry at how short and consistent the clutch was. It was great and probably the best clutch I've ever driven... In comparison, my Camaro needs to travel a mile and a half to fully be pressed down.
Is there a way to shorten the clutch travel? Be it a mod or and aftermarket part?
Edit: oh and if this is in the wrong section, please feel free to move it.
maverickmage is offline   Reply With Quote
Old 07-11-2011, 02:17 AM   #2
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
short shifter....mgw, barton, and hurst are a few
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 07-11-2011, 02:18 AM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You could change the pivot point on the pedal. Nothing a little chopping and welding couldn't take care of.
SUX2BU is offline   Reply With Quote
Old 07-11-2011, 02:19 AM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
He is talking about the clutch pedal, not the shifter.
Old 07-11-2011, 02:28 AM   #5
maverickmage
I have to say... the thought did occur to me. T_T Although I'm hoping that that's not my only option.
Old 07-11-2011, 04:09 AM   #6
REDXIIIDave
El Chupacabra
REDXIIIDave's Avatar
Drives: 2011 2SS/RS A6 Black/Black
Contact ramclutches.com. They have what you're looking for.
REDXIIIDave is offline   Reply With Quote
Old 07-11-2011, 11:05 AM   #7
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Spacer on the slave cylinder
DietCoke is offline   Reply With Quote
Old 07-11-2011, 06:55 PM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You can only use this if your clutch engagement point is very high on your pedal. The adjustment shortens the length of the rod. If your clutch engagement point is close to to bottom and you shorten the rod, that would be a big no no. Your clutch wouldn't disengage properly.
You have to be VERY careful when you do this. too big of a spacer and you will fry your clutch. You could use this along with an adjustable master if your engagement point is too low on your pedal.
Old 07-11-2011, 09:57 PM   #9
maverickmage
hmm.. my clutch engagement point is not too bad. About lower mid maybe. So ramclutches wouldn't be able to help me out.
Hmm spacers... maybe. But SUX2BU seems to know what he's talking about. I'll have to look into this a bit more.
Old 07-12-2011, 12:03 AM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Experience is king, I've rebuilt a lot of M6s and know what and what not to do.
Old 07-12-2011, 06:29 PM   #11
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
It is nonetheless the only proper way to adjust clutch pedal throw.
Old 07-12-2011, 07:00 PM   #12
CFD
Drives: 2SS/RS L99 BLACK
Theoretically, to change the amount of travel required to disengage the clutch would be to change the bore of the master and or slave cylinders. This would also affect pedal effort.
CFD is offline   Reply With Quote
Old 07-13-2011, 01:27 AM   #13
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
That would change the amount of travel by virtue of changing the ratio of pedal to clutch travel. A spacer changes the point of contact of the master cylinder to the clutch teeth, thus changing only the catch point, and not the entire pedal's feel.
Old 07-13-2011, 03:45 AM   #14
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
It doesn't sound to me like he's talking about where it engages and disengages... he's just talking about the overall length of the pedal travel... maybe a way to end the travel after the engage/disengage point... mine has a lot of travel after the clutch disengages that isn't needed.
FL1CK is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
ZR1 Clutch at the Track JM10 Dragstrip and Launch Techniques Discussion 19 02-16-2011 12:02 AM
M6 clutch not Disengaging - Dealer told me to drive it in? toasterfires Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 01-13-2011 05:00 PM
new clutch and now transmission grinds HeaterMan 5th Gen Camaro SS LS LT General Discussions 4 11-16-2010 10:04 PM
Clutch pedal travel Ringo V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 09-24-2009 03:53 PM
