Old 07-11-2011, 11:08 PM   #1
essa
Drives: ls1
help me plz .. problem in the tire pressure
hi
I have a problem in the tire pressure I went to the Dealer and he fill the tires
for me . i checked the pressure and it was 35 after 6 hour i checked Once again and it was 33 for 3 tire / 32 for one tire . I do not know Is this normal or not
I bought the car a week ago and I want to make sure that this is normal
essa is offline   Reply With Quote
Old 07-11-2011, 11:20 PM   #2
Speagle
Speagle's Avatar
Drives: 2010 IOM 2SS/RS
Pressure will fluctuate depending on the temp of the tires and the air in them. As you drive the tires will heat up causing the air inside to expand raising the pressure. I assume the car had been sitting for a bit when you got the 32psi reading?
Speagle is offline   Reply With Quote
Old 07-12-2011, 02:02 AM   #3
essa
Drives: ls1
Yes, approximately 5 to 6 hours
actually, When i drove the car for 15 minutes, pressure became 34 .
is 34 normal ? Because in user manual recommend pressure 36 in cold
and it was 32 ​​when tires are cold.. i'm woozy :(
Old 07-12-2011, 02:33 AM   #4
CruznSS
CruznSS's Avatar
Drives: 2SS/RS Camaro ABM - Silver Ralleys
That's normal. Can have dealer fill tires with nitrogen gas. Will not have as much fluctuation in tire pressure. When cold mine are at 33 to 34psi.
Sent from my PC36100 using Tapatalk
CruznSS is offline   Reply With Quote
Tire Pressure Monitoring System gone haywire Bowtie Junkman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 07-27-2011 10:34 AM
Tire Pressure Questions nalinc23 Wheels and Tires Talk Sponsored by The Tire Rack 21 09-15-2010 02:18 PM
Tire Pressure Issues jagan323 Wheels and Tires Talk Sponsored by The Tire Rack 18 04-22-2010 11:27 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
I think i'm done waiting. pinkcamaro10 Off-topic Discussions 332 05-13-2009 05:56 PM
