BORLA
Old 07-12-2011, 11:47 AM   #1
SS>GT
SS>GT's Avatar
Drives: 2010 Camaro SS
opinions on rear end 4.10 gears pricing and recomendations?
finally decided to get the rear end done, and im going with 4.10 gears.
the only brand ive found is richmond, so does anyone know if theyre good, or if there is a better option? ( also, if im getting my dealer to install it for me, do i need the install kit they sell as well?)
Also, my dealer quoted me approx $350 to install the above. Is this a fair price?
any info appreciated!
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black.
GO TEAM LS3
SS>GT is offline   Reply With Quote
Old 07-12-2011, 12:07 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I would check out these ... Read too many bad luck stories with Richmond gears ...
http://www.camaro5.com/forums/showthread.php?t=151419
The gear set ...
http://www.lingenfelter.com/mm5/merc...egory_Code=C61
Old 07-12-2011, 12:23 PM   #3
SS>GT
SS>GT's Avatar
The gear set ...
this price seams very reasonable if it is a quiet option...
of course, i now have a few more questions sorry for being a PIA, but is there a noticable difference between 4.10 and 3.91? and also, does this set up require a install kit like the richmond gears do?
2010 camaro 2ss LS3
GO TEAM LS3
Old 07-12-2011, 12:28 PM   #4
SlingShot
SlingShot's Avatar
It's normally suggested to use the install kits, so you get fresh bearings and spacers to do the job right. The performance is close to being the same with both gear sets. The OEM gears are made by AAM, so it has been reported the 3:91 set is just as quiet as stock, and won't whine like the 4:11 set ...
Old 07-12-2011, 01:50 PM   #5
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Richmond started out making 4.10's, then (as I understand it) after numerous "issues", they started making the new 4.11's made out of a stronger material or maybe it was just a different heat treatment process or something. The bottom line is the new 4.11's are stronger and better. I haven't heard of any failures yet with the new 4.11's, but I guess anything is possible. I'm not even sure if they are still making the older version of the 4.10's anymore, and I believe their 3.73's and 4.33's are still being manufactured using the older (inferior) materials or processes. Regardless, the Richmond gears have had their share of "issues" in the 5th Gen Camaro.
As previously stated by SlingShot, I would definitely recommend the Lingenfelter/AAM gears. They are expensive, but at this point, more reliable than the Richmond products. And yes, an install kit is highly advisable for either.
If you can wait, U.S. gear is supposed to be releasing their gears (4.10's included) in Sept. Not sure on prices yet.
Lastly, if you're going to be tearing into the rearend anyway, I would HIGHLY advise adding the Jannetty Posi Mod, Jannetty Billet-Machined Main Caps, and probably the LPW diff. cover. Just make sure your dealership has plenty of experience upgrading these rear ends, I hear it's extremely "tricky". BTW, I think $350 for install is pretty cheap!! Good Luck....keep us updated.
blazzin1 is offline   Reply With Quote
Old 07-12-2011, 03:28 PM   #6
SS>GT
SS>GT's Avatar
not sure what the Jannetty mods will do, but ill do some research. and i Will definately keep you posted!
2010 camaro 2ss LS3
GO TEAM LS3
Old 07-14-2011, 01:17 PM   #7
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I've put over 18K miles on my Richmond 4.10s and have had no issues or whine from day one (and I've loved every second experiencing the night & day difference!)... Like others said, $350 is a very good deal for installation, esp. If a a dealer is doing it for you.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 07-15-2011, 05:48 AM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
All gear installations require an install kit. There are parts that are not reusable and have to be replaced. A "half kit" includes the absolute minimum you need to do the install. A "full kit" includes the same plus some other parts that are a good idea to swap due to wear etc..
$350 for a gear install is dirt cheap, especially from a dealership service department. It is a good 6-8 hour job. I would verify that they have done gear installs on these cars before.
Old 07-15-2011, 04:56 PM   #9
steeleshark2
steeleshark2's Avatar
Go 4.11's not 4.10's if you are going to go Richmond. My gears are awesome and the car should have came with these in the first place.
