Cold Air Inductions
Old 03-18-2009, 05:40 PM   #1
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
Engine Mod
Sooo... now that its finally out in the real world, anyone planning on this 88958733?
Mythic is offline   Reply With Quote
Old 03-18-2009, 05:40 PM   #2
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I don't plan on buying anything from GM Parts...
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 03-18-2009, 05:44 PM   #3
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
what What WHAT!!??!? Why not. Whats wrong with GM parts?
Old 03-18-2009, 05:45 PM   #4
Mythic
Mythic's Avatar
Also, do you know what it does?
Old 03-18-2009, 05:56 PM   #5
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I am going for a custom compcam grind...with a heads and exhaust setup.. Looking to break 515rwhp!!!
ZZcamaro is offline   Reply With Quote
Old 03-18-2009, 08:54 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Than read this http://www.camaro5.com/forums/showthread.php?t=15038
Old 03-18-2009, 10:30 PM   #7
Codefive
Codefive's Avatar
Drives: 1000HP 2010 SSRS
I wouldnt use that cam for a table leg! Its very outdated to start with. If you are going to go through the trouble of changing the cam, there are FAR better options out there that will yield significantly better gains.
Codefive is offline   Reply With Quote
Old 03-18-2009, 10:40 PM   #8
Mythic
Mythic's Avatar
its not out dated
its also the only p/n different between the LS3 and LS3/476
there may be better, but its relatively painless if I just have to swap a cam and a wiring harness for 50hp
because absolutely everything else on the 2 engines is identical by p/n
Old 03-21-2009, 02:35 PM   #9
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
I wouldn't call it outdated. Or of poor design. 50 hp from a simple cam change isn't too bad. Not too mention it follows the 10* or so split between intake/exhaust duration that you will see on EVERY cam mfr's camshafts for the LS3's.
Do other cams make more power? Of course. Because they have more lift and duration. This has less lift than stock, but more duration, and from what I have read from people who have installed this cam into their Vettes, it drives just like stock, pulls plenty of vacuum at idle, has no lope, and drops your mpg by about -1 while cruising on the highway.
If you're wanting to make 500rwhp, this is probably not the cam for you. If you're looking to to make sure bolt on mustangs and SRT-8 challengers don't stand a snowball's chance in Hell against you, while keeping up with GT500's, then this is the perfect cam for you.
UsedTaHaveA68 is offline   Reply With Quote
Old 02-19-2011, 08:26 PM   #10
Kahdir
Kahdir's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
Anyone on here try this Cam?
Is your Camaro a DD?
Kahdir is offline   Reply With Quote
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 01:28 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 05:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 07:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
