Jason 98 TA
Old 07-13-2011, 07:49 AM   #1
JackRabitSlims
Drives: 2010 Camaro 2SS RS LS3
Differential Fluid
Any suggestions on differential fluid to put in the car? I heard Amisol is a good fluid. Does it need to have something added to it like the one GM regularly uses? Will using something other than GM fluid void the warranty? Thanks for the help.
JackRabitSlims is offline   Reply With Quote
Old 07-13-2011, 08:24 AM   #2
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
I used Mobile 1 and a bottle of LS additive
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 07-13-2011, 10:15 AM   #3
pdesanctis
i like to go fast
Drives: 2011 SS
Royal Purple 75w90 gear fluid is one of the best out there. They're oils are nice, but they're drive train fluids are exceptional.
pdesanctis is offline   Reply With Quote
Old 07-13-2011, 11:57 AM   #4
NavyDood
Retired Navy
NavyDood's Avatar
Drives: 2010 2SS/RS
Amsoil Severe Gear 75w90.
NavyDood is offline   Reply With Quote
Old 07-13-2011, 01:12 PM   #5
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
Do you need to add the additive with Amsoil Severe Gear?
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 07-13-2011, 06:34 PM   #6
NavyDood
Retired Navy
NavyDood's Avatar
Drives: 2010 2SS/RS
They say it may not be necessary. If diff chatter occurs then you are to add some. You might as well put it in there so you don't have to go back and do it. It won't hurt a thing.
Old 07-13-2011, 07:09 PM   #7
AC
***GO HOGS GO***
AC's Avatar
Thanks NavyDood...I'm going to give Amsoil a try next week with my new 3.73's.
Old 07-14-2011, 09:25 AM   #8
JackRabitSlims
Thanks for the info...does anyone know what the additive is called?
Recommed all to do differential fluid change!!! jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 116 07-27-2016 06:08 AM
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 09:10 AM
Magnaflow axleback(16582) too close to differential? no room for wrench; fluid change pdesanctis Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 05-11-2011 04:51 PM
Metal Shavings In Differential Fluid - Yikes! Predator2U Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 03-12-2011 01:49 PM
Differential Fluid: Special Edition Question CamaroFemme Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 12-27-2010 07:17 PM
