Centerforce Clutches
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 07-13-2011, 09:24 AM   #1
MJ
MJ's Avatar
Drives: 2010 Camaro SS/RS
Axle nut torque spec
I searched but could not find axle nut torque spec. Anyone with a shop manual want to help out? Thanks in advance...
MJ is offline   Reply With Quote
Old 07-13-2011, 09:48 AM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
You sitting down for this?
266 ft lbs I had to buy a new torque wrench when I changed my axles!
I can be used as a bad example! - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 07-13-2011, 09:58 AM   #3
MJ
MJ's Avatar
266 Ft/Lbs for rear axle nuts?
266 Ft/Lbs for rear axle nuts... ok. Is that spec from the shop manual? My torque wrench goes there, but don't have the socket yet. Thanks...
Old 07-13-2011, 10:34 AM   #4
hypurone
hypurone's Avatar
Straight from my dealer service dept...
Old 07-13-2011, 10:36 AM   #5
MJ
MJ's Avatar
Awesome... thanks!
Old 06-08-2012, 11:40 AM   #6
PQ
Drives a Maro
PQ's Avatar
Drives: Hybrid SS Camaro
Are we sure about this? I found 159 lbs.
Also the TSB said 199 lbs.
266 seems a bit high. That's Newton Meters. Which is actually about 199 lbs.
Old 06-08-2012, 04:49 PM   #7
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
199 ft/lbs according to 2011 shop manual. Also only supposed to use the nut once. When I took my diff out for new gears, I used same nut with blue loctite. Checked it once since and still at 199 ft/lbs.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 06-08-2012, 04:52 PM   #8
PQ
Drives a Maro
PQ's Avatar
Nice.
I even said in the video 199 and then changed it after talking to someone. Bad thing is I can't remember who I talked to.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 207 06-07-2013 11:09 PM
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 44 01-20-2013 03:02 PM
lug nut torque? mike12345 Wheels and Tires Talk Sponsored by The Tire Rack 4 05-06-2010 07:24 AM
Torque Converters Milk 1027 Wiki 0 08-12-2009 06:31 PM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 01:28 AM
