JUICEDMOTORSPORTS
Old 07-13-2011, 09:11 PM   #1
BLOWN-Z
BLOWN-Z's Avatar
Drives: 2010 1ss
LPW COVER (VENT ISSUE)
Has anyone installed the LPW cover and had oil come out of the vent at highway speeds???? Street driving seems to be fine. I put the stock cover back on and it doesn't do it anymore.
BLOWN-Z is offline   Reply With Quote
Old 07-13-2011, 11:15 PM   #2
BUMBLE-B-TUNA
BUMBLE-B-TUNA's Avatar
Drives: 2010 SS
Yup, same issue. Got a PM from BlownRS/SS with the same issue as well. Been in contact with LPW and they are aware, we will see what becomes of it as far as what the problem is and a fix.
BUMBLE-B-TUNA is offline   Reply With Quote
Old 07-14-2011, 09:01 AM   #3
thundercat 1
Drives: 2010 camaro ss/rs
vent issue also.even tried less fluid. still pushes fluid out.lpw we need a fix!
thundercat 1 is offline   Reply With Quote
Old 07-14-2011, 09:30 AM   #4
Synner
Drives: not stock
Maybe try extending the vent higher?
Synner is online now   Reply With Quote
Old 07-14-2011, 09:37 AM   #5
BUMBLE-B-TUNA
Drives: 2010 SS
Hey thundercat, you should contact LPW by phone if you haven't already so they are aware of just how widespread this problem is. There seems to be more and more people coming forward with this issue on a daily basis.
Old 07-14-2011, 07:57 PM   #6
thundercat 1
called today.was told the owner was out til monday,but would contact me with a fix asap.lets hope its soon
Old 07-15-2011, 05:15 PM   #7
BlackRS/SS
BlackRS/SS's Avatar
Drives: Black RS/SS
I have the same problem, I hope they have a fix. I have a track day set up for next thursday that has cost alot of money. I guess we will see on monday when the owner gets back.
BlackRS/SS is offline   Reply With Quote
Old 07-15-2011, 05:26 PM   #8
BLOWN-Z
BLOWN-Z's Avatar
Drives: 2010 1ss
Not sure if it will be a quick fix, there is quite a bit of difference in the vent location from the stock cover to the lpw cover, they may need a new casting. returning mine tired of changing fluid and swaping covers back and forth!!!!
Old 07-15-2011, 05:29 PM   #9
BLOWN-Z
BLOWN-Z's Avatar
Drives: 2010 1ss
And cleaning up the mess under the car......
Old 07-15-2011, 10:16 PM   #10
Synner
Drives: not stock
Try extending the vent line above the top of the cover before tearing it all apart. Thats probably what their fix will end up being too.
Old 07-15-2011, 10:25 PM   #11
BUMBLE-B-TUNA
Drives: 2010 SS
The vent line already extends above the top of the cover by probably 6" or so. You can't go much higher without drilling a hole in your trunk. Maybe you could extend it up in the wheel well???
Old 07-16-2011, 09:46 AM   #12
Synner
Drives: not stock
Well crap I didn't know that, was only going off their pic on the website. I was wanting to pick one up in two months when I do my first fluid change but I guess I'll wait and see how this shakes out.
Old 07-17-2011, 04:01 AM   #13
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Can anyone tell me if you can change the cover without pulling the diff??
Thanks!!
BoostedX2 is offline   Reply With Quote
Old 07-17-2011, 11:14 AM   #14
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
Thanks!!
I couldn't. Disconnected the drive shaft and removed the bolts from the three diff mount points and let it sag down a bit. Was on a lift to do this.
ADIO SS is offline   Reply With Quote
How to Choose the Best Car Cover for Your Camaro Junkman2008 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 27 02-27-2015 03:10 PM
car cover for 1955,1956 chevy. may work for camaro also if used indoors only nomadicdogg Wash/Wash/Detailing and Cosmetic Maintenance Parts 1 07-30-2011 02:57 PM
Who is suffering or suffered from Engine Rear Cover Leak ffrcobra_65 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 07-29-2010 10:56 AM
Camaro Car Cover....by Tom Henry TAG UR IT Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 22 10-28-2009 10:53 PM
