Old 07-14-2011, 08:43 AM   #1
M6HuggerSS
M6HuggerSS's Avatar
Drives: Crane Truck
Arrow High IAT's vs. PERFORMANCE
Just a basic questions for all of you tuners out there...
We've been talking a lot lately about HIGH IAT's with some kits out there, but i was wondering if we could get some detailed info on how this hurts the performance of the kit, and possibly the car.
For instance...
at 120F - 100% power, no issue
at 130F - ?
at 140F - ?
at 150F - 80% power, XX timing pulled
at 160F - ?
at 170F - ?
at 180F - 60% power, XX timing pulled
at 190F - ?
at 200F - ???
at 210F+ -
you get the idea... i think this might clear some issues and help explain what someone is getting into when purchasing ANY compressor.
thanks in advance.
1998 Z28 M6 SOLD :(
315rwhp (3500lbs)
1999 HUGGER SS SOLD :(
400rwhp (3375lbs)
2002 YELLOW Z06 SOLD :(
360rwhp (3040lbs)
2013 CAMARO ZL1 COMMING SOON
M6HuggerSS is offline   Reply With Quote
Old 07-14-2011, 11:35 AM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
For instance...
at 130F - ?
at 140F - ?
at 160F - ?
at 170F - ?
at 190F - ?
at 200F - ???
at 210F+ -
thanks in advance.
It is way more complicated than this due to all the different combinations of Boost, compression, octane etc.
A simple explanation is this;
As Air Temp rises 4 things happen;
1) Air Density or number of oxygen molecules is reduced, the result you can't burn as much fuel so therefor you make less power.
2) The timing advance needed to complete the burn is LESS, hotter Air/Fuel mixture burns quicker.
3) The chance of the Air fuel mixture Pre igniting goes up exponentially, this means the air fuel will either ignite on its own or burn too quickly causing Detonation.
4) Pre ignition or Detonation occurs and Knock sensors pick this up and try to control it by removing timing lead.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 07-14-2011, 12:44 PM   #3
SC2150
Ted has it all covered....and it is exactley what is happening.
Read this thread also....gives some test data on the dyno & the road:
http://www.camaro5.com/forums/showth...=99515&page=13
Old 07-14-2011, 02:22 PM   #4
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
Ted.
Great info Dr.Ted My IAT's on the dyno last night were 215F
Tracy, cant wait to get the Super Chiller to help my car in this volcanic weather
Ahmad
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline   Reply With Quote
Old 07-14-2011, 02:25 PM   #5
JANNETTYRACING
Ahmad
Whipple Time
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 07-15-2011, 01:22 AM   #6
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
Whipple Time
It gets this hot on the dyno only overhere , but on the street it dosnt so TVS2300 for now Dr Ted
Ahmad
2012 ZL1 A6
Old 07-15-2011, 09:53 AM   #7
JANNETTYRACING
Ahmad
Read the last PM I sent you and respond to my email
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 07-16-2011, 07:02 PM   #8
M6HuggerSS
M6HuggerSS's Avatar
Drives: Crane Truck
thanks for the info ted.
Ted.
1998 Z28 M6 SOLD :(
315rwhp (3500lbs)
400rwhp (3375lbs)
360rwhp (3040lbs)
Old 07-17-2011, 09:06 AM   #9
Slowhawk
Drives: 1999 Trans Am
Biggest problem is heat soak on the maf when n/a. It's takes a longtime to cool off.
Slowhawk is offline   Reply With Quote
Old 07-17-2011, 09:09 AM   #10
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
So put the ice bag on the MAF instead of the manifold?
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 07-17-2011, 09:22 AM   #11
Slowhawk
Padre
Sorry, thought this was na. Heat soak affects blowers too. Placement of the sensor is important. When the temp goes up you have to watch out because alot of fi can take more timing without kr.
Old 07-17-2011, 11:26 AM   #12
SC2150
With such an easy, affordable solution IAT temps should never be an issue FI or NA.
Old 07-22-2011, 02:09 PM   #13
Matt@KB
Matt@KB's Avatar
Drives: 67 Camaro
AIR TEMPERATURE TESTING
Over the last 6 months there have been considerable discussions regarding air and water temperatures of supercharger kits. Comparisons are okay if they are accurate. If not they are just more misinformation circulating on the web.
And, it is not our intent to compare the design and efficiency of any kit or the individual mechanical components that influence air discharge temp. These are the supercharger, inlet tract, intercooler, heat exchanger, pump etc. Optimizing these parts lower the air discharge temps. resulting in greater HP and reduced detonation potential. “Hot air” under-hood inlets increase temps and hurt HP while adding an external real cool air kit does the opposite. One would have to be living in a village to not be aware of these basics.
Instead, we hope to point out the testing procedure and criteria we use at Kenne Bell to accurately compare the charge and coolant temps when dyno testing. Disregard any of the following 12 parameters and accuracy is compromised resulting in bogus comparison data. As you will see, it’s easy to skew the data with even the same car, kit, day, ambient and boost.
If any meaningful or accurate data is to be derived from comparing the air discharge temps of supercharger kits on a vehicle, it must be a controlled test with specific test parameters that ELIMINATE THE VARIABLES.
All the below will, and do, affect temperature when tested on a chassis dyno. One “kit” may wrongly appear superior or inferior on the same vehicle because of the simple temp or boost reading error or failure to note a cool air kit upgrade or open vs closed hood change to one kit and not the other.
VARIABLES THAT AFFECT COMPARISON TESTING
1) UNDER-HOOD TEMP (HOOD UP VS DOWN)
2) AMBIENT TEMP.
3) ACTUAL BOOST (1 PSI OF BOOST= 10*-15* SC air discharge temps.)
4) RPM, LENGTH OF RUN + GEAR RATIO
5) STARTING AIR TEMP
6) STARTING INTERCOOLER FLUID TEMP.
7) WATER VS. COOLANT RATIO
8) SUPERCHARGER TEMP.
9) INLET RESTRICTION
10) IDLE-RUN-AFTER RUN
11) WHERE THE ACTUAL CHARGE TEMP MEASUREMENT IS TAKEN
12) IMPROPER CIRCULATION (AIR TO WATER)
1a) FILTER TEMP- The ONLY measurement to use for “engine in” air temp. calculations. Other temp readings under, above or around the dyno or car are wrong. The engine draws air from the filter. Nowhere else matters. Keep in mind this temp. alters HP at 1% per 10* of variation. Also, cooler ambient air makes more boost.
1b) UNDER-HOOD TEMPS (HOOD UP VS DOWN)- Why do dyno operators insist on testing with the hood “up?” That isn’t the way the cars are driven. CLOSE THE HOOD- unless you want false air data. Under-hood temps. reach 200* vs 70* or ambient outside air. If the filter (inlet source) is located under the hood, then the dyno run should be conducted the same way- hood closed. Why is that so difficult to grasp for so many? What are they afraid of? Yes, the hot under-hood air will reduce HP, increase the detonation threshold, lower boost, alter supercharger efficiency and elevate engine and exhaust temps. Not good, but it is what it is- hotter air.
It’s why everyone uses scoops and not mini sized grill cracks to supply the 750-1500 cu.ft. of cool air flow required by the engine. And why the Camaro utilizes an air scoop in the grill. They are looking for cool outside air for their filter box.
Fact: Very little cool air finds it’s way through those little 50 CFM grill openings. Yes, some outside air mixes with all that hot air from the radiator, engine, headers etc. but it is all ingested via the filter into your engine.
Finally, under-hood shrouds and seals do virtually nothing. Once eliminated, this common but huge test misstep (we’ve seen up to 55 HP and 100* with hood “up” vs. “down”) the rest is common sense testing and the air and water data will support meaningful accurate results. All Kenne Bell kits mount the filter outside the engine bay where temps are cooler and consistent at any vehicle position or speed. The dyno fan will simulate vehicle high speed and under-hood air flow.
So, no exceptions. Locate the ambient temp sensor at the filter whether it be under-hood (hood down) or behind the front bumper. Begin test at the same temp or data is junk.
2) AMBIENT TEMP- Cool outside the engine bay air is what also cools the fluid in the heat exchanger. Cooler air= cooler water= cooler supercharger air into the intercooler= cooler air charge to engine= more boost= higher HP. So, ambient air temp should be the same as it influences all the other components. 20* higher ambient raises intercooler air and water temps. It does matter.
3) ACTUAL BOOST- Boost makes HP, but it produces heat. There’s no free ride. Twin Screw positive displacement, and centrifugal superchargers generate approximately 10* of charge temp per PSI. Starting run design temps are approx. 10* per PSI + Inlet temp. Example: 90* ambient + 90* (9 PSI) = min air charge temp 180* before intercooler. Roots style are higher. Be sure “actual” boost is the same. Don’t just assume all 9 PSI kits develop exactly the same boost. The intercooler system (air to water or air to air) is typically 50-75% efficient depending on numerous kit design variables. To accurately compare kits, boost cannot vary.
4) RPM, LENGTH OF RUN & GEAR RATIO- The higher the RPM, read end or trans. gears the longer the dyno run and the greater the final temp. Everything heats up with time until there is stabilization. Use the same vehicle to insure accuracy.
5) STARTING INTERCOOLER WATER TEMP- If the intercooler water ( it cools the air) is 20* hotter at the “start” of the run, the “finish” will be hotter. Start temps must be identical for accurate comparisons.
6) STARTING INLET AIR TEMP- Same here. Obviously, a hotter filter at the beginning of a run results in higher supercharger discharge temps. A 30-50* variance is common. Start test at same filter air temp. or the tests are useless. NOTE: Under-hood filters are difficult to test because engine bay temps increase (heat soak) with time when idling. Open the hood and let cooler dyno room external air blow in and the test are skewed.
7) WATER VS. COOLANT- Since no liquid cools better than water, 100% water is best. 50/50 is not as efficient in cooling. 90/10 is better. Try placing ice cubes in a pot of coolant. Ice 32* and coolant 50* between the ice cubes. Engine coolant “resists” lower temperatures and freezing. Run the same mix when testing if your goal is an accurate comparison.
8) SUPERCHARGER TEMP (HEAT SOAKING)- Obviously, heat soaked components can heat the air passing through them. For example: We use a thermal laser gun to quickly measure supercharger case temp. If the supercharger is covered (never on our design priority list) with a manifold, intercooler or plastic engine cover, it obviously runs hotter. Then there’s the heat transfer from the engine. However, for test comparisons, the temps. of the supercharger and other metal or plastic pieces in a particular kit “are what they are.”
9) INLET RESTRICTION- NEVER compare 2 kits with inlet tracts ( filter, meter, tubing, throttle body etc.) that vary in restriction/efficiency. If one inlet is larger and enjoys less restriction to air flow to the supercharger, then the supercharger is not required to work as hard. Like sucking coke through a straw vs. a straw half pinched off. The upside of a larger inlet tract is the supercharger uses less HP to suck in the air and subsequently runs cooler AND develops more boost. Supercharging efficiency, boost and inlet temps will all be better but DIFFERENT.
10) IDLE/RUN-AFTER RUN- Idle temp. will be highest before a run. Let it cool to the test temp. and make the run in the same gear, car, boost, trans. and RPM. Check the data at the same peak RPM as everything heats up after getting off the throttle.
11) WHERE THE ACTUAL CHARGE TEMP MEASUREMENTS IS TAKEN- This is probably the most important part of the measurement process. Equally important is the sensor being used is properly calibrated. Different air temp sensors can be calibrated differently and if the person testing is not aware of this, all data will be useless. Transfer functions are different for some push in type sensors vs screw in type and vs shielded/unshielded sensors. The most accurate and fastest response air temperature sensors are the unshielded type. Never compare shielded sensors against unshielded.
Given that the a) sensor types are the same (unshielded) and b) the transfer functions are correct, then c) placement of the sensor is critical. Let’s make sure we are not using a sensor that is located upstream of the supercharger on one system and then downstream on the other. Believe it or not this mistake has been made before. Whenever temperature readings are only a few degrees above ambient under boost, always suspect the sensor is either a) located upstream (before) the supercharger as is the case in many applications if a new sensor has not been relocated from the factory location to the discharge side of the intercooler, or b) sensor is incorrectly calibrated or c) sensor is of the shielded type. Ever wonder why there are sensor “relocation kits?” was it the wrong location?
12) IMPROPER CIRCULATION (AIR TO WATER)- Always compare systems that have proper water circulation. A common error when seeing high discharge air temps is not to insure there is adequate flow in the system. In any new installation it is very easy to have air pockets that hinder/stop circulation of the liquid (cooling media). Even the best designed system can produce high charge temperatures if proper purging of the intercooler system has not been performed. Blockage of airflow to the heat exchanger from debris, bumper cover, etc. can also have a drastic effect. There has to be sufficient airflow across the heat exchanger to drop the charge temperature.
In conclusion, what we often think is the same is the same but it’s different.
If analyzing supercharger kits by the same or competing manufacturers, it is important to refer to the above 12 test variables and make the necessary adjustments to guarantee boost temperatures, run length, inlet, restriction, temps measurement location is identical- and the hood is CLOSED, like you drive the car .
There’s a saying on the Kenne Bell dyno that an OEM engineer left us- “One of the real dangers in running a test is you are bound to get data”.
We hope the information is helpful.
Matt@KB is offline   Reply With Quote
Old 07-22-2011, 02:11 PM   #14
Matt@KB
Matt@KB's Avatar
Drives: 67 Camaro
There are 7 100% stock (except for supercharger and cat back) like new test cars at our facility.
Whenever misleading information about Kenne Bell products is posted we respond and set the record straight. It is not our intent, to discredit anyone. Our goal is simply to clarify with factual testing.
As Matt promised, here are two accurate back to back data logged Dynojet new runs on our ‘10 Camaro test car. The tests are at two different temps: Ambient (88* vs 91*) and filter start (85* vs 87*) to illustrate the relationship even at small increments. Note the H2O start (intercooler water) temps are 4* apart, as they should be with 3* hotter ambient air.
Also, note that by controlling the START temps (ambient, filter and H2O) on both runs, the air charge rise from start to end is a corresponding 4* (16* vs 20*). That is what controlled testing nets- accurate data. This is NOT the 56* (142* vs 86*= 56*) reported- and the prime reason for re-running the tests. One cannot expect any credibility in comparison testing if the ambient, start temps, H2O temps vary- and the hood is up.
Yes, we have run the Whipple comparisons, but that is not what this post is about. We are merely publishing test data on our product. It agrees with test conducted two years ago. We disagreed with the information posted relating to the Kenne Bell supercharger kit temp rise.
Our data is spot on accurate, repeatable and provable. Also, these tests were run at 19* higher ambient (91* vs 72*). At 72*, the charge temp would be 19* cooler as inlet/ambient temp variations are added or subtracted from baseline temps. 151* would be (151-19)= 132* at 72* ambient.
Controlled testing is expensive and time consuming. We post hundreds of dyno test and plenty of technical info on our website to help our customers make better decisions. Can’t make a good decision without good data. We pride ourselves in the accuracy and vigorously defend it when challenged.
At the end of the day, what matters most to us at Kenne Bell is that our customers are satisfied with our kits, tunes and tech.
CUSTOM HIGH PERFORMANCE SPARK PLUG WIRES AT 2 EDGE PERFORMANCE!! MRGOODWRENCH3 Local Marketplace 46 10-17-2011 09:35 PM
Unbeatable Prices on BC / Eibach / Hawk / Hotchkis / MTI / Racing Brake / SLP / More maperformance Suspension / Chassis / Brakes 10 10-04-2010 03:36 PM
No More GM Performance Division... leviticus88 General Automotive + Other Cars Discussion 1 02-19-2009 04:04 PM
