Old 07-14-2011, 05:00 PM   #1
Revenant
Revenant's Avatar
Drives: '11 1SS LS3 and '90 240sx hatch.
Is anyone running a balanced 20x9+20 front and back?
Have pics? I'm curious of the fitment. Thanks
Revenant is offline   Reply With Quote
Old 07-19-2011, 04:46 PM   #2
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Yes 20 x 9 on all 4 corners fits is perfect except i bought new pirellis the streched look didnt work for me
tpower is offline   Reply With Quote
Old 07-19-2011, 05:08 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
I don't think that "+20" offset is gonna work, that's not enough offset I believe.
blazzin1 is online now   Reply With Quote
Old 07-19-2011, 06:16 PM   #4
Sour DeeZ
Drives: 2011 IOM 2SS RS M6
Call me dumb but what exactly does offset mean?
2011 SS/RS IOM M6 --- Kooks 1 7/8" Long Tube Headers Coated, Kooks 3" HFC, Kooks X-pipe, Kooks 3" Cat-back, Cold Air Inductions CAI, Custom Quad Exhaust & Diffuser, Custom Tuned at Jannetty Racing. (2) 10" JL Audio w6's. Rockford Fosgate Power T500-1. Cache COE6.
Sour DeeZ is offline   Reply With Quote
Old 07-19-2011, 06:21 PM   #5
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
ITS WORKS.....very well too.....there are quite a few people running this combo.....bo issues at all.....and a few are even droped. I don't have any pics....but you really can't tell the difference.
Old 07-19-2011, 06:22 PM   #6
Sir Nuke
Sir Nuke's Avatar
read this....it will explain it all.
http://www.camaro5.com/forums/showthread.php?t=111604
Old 07-19-2011, 06:55 PM   #7
blazzin1
blazzin1's Avatar
Oh, I know 20x9 on all fours will work, but I still don't know about that "+20" offset. Most wheels that fit on the Camaro are like +35 or +40.
Old 07-19-2011, 10:42 PM   #8
Sir Nuke
Sir Nuke's Avatar
True enought......I didn't catch that in the OP. if you want to put 20 x 9's on the front and really have them fIt well, they should be +40's.....or a little less will work too.
Old 07-19-2011, 11:49 PM   #9
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
I'm running the stock rear 20x9's all the way around with 275/40/20 tires - link to pics. The stock rears have a +40 offset and even with that, I'd say the inside of my front tires sit maybe 1/4-3/8" away from the front spring mounts - I have about enough clearance to slide the tip of my pinky finger between the tire and the mount. If you went with a +20 offset, I think you'd likely rub the spring mounts from time to time, depending on which size tires you use up front since you'd be moving that inner edge of the tire/wheel 20mm closer to the mount.
rolnslo is offline   Reply With Quote
Old 07-20-2011, 01:37 AM   #10
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
You have it backwards. Going from a +40 to a +20 will decrease the backspacing, not increase it. A 9" wheel with a +20 will probably stick out of the wheel well a little bit.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 07-20-2011, 01:50 AM   #11
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
WOW at all the FAIL in this thread.
This guy has it right. Imagine your stock wheels sticking out about an inch further front and rear.
SUX2BU is offline   Reply With Quote
Old 07-20-2011, 08:29 AM   #12
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Common offset on a 20x9 wheel on the front for the right "stance" is in the +28mm to +32mm range. I've been running the factory 20x9 +40 offset wheels on all 4 corners for well over a year and it looks great and handles better ( reduces under steer ). It would even look better if all four 20x9's had a +28 to +32 offset moving the wheel/tire assembly outward roughly .3" to .5" more. This would also give more wheel/tire clearance for the strut in the front.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 07-20-2011, 09:15 AM   #13
blazzin1
blazzin1's Avatar
I wouldn't say there has been massive amounts of "FAIL" in this thread!!! Come on, one guy got his offsets mixed-up!!! Not a big deal, it happens to all of us at one point or another. Other than that, the advice in this thread has been fairly accurate, don'tcha think?!?!
Old 07-20-2011, 09:31 AM   #14
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
That and people not reading the complete thread title.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 287 08-26-2017 12:29 PM
Add HUD to your 2010 2SSRS@Gen5diy Camaro DIY & HOW-TO instructions & discussions 1976 07-14-2017 01:50 PM
DIY Installing front speakers LOTS OF PICS Darth Martel Camaro DIY & HOW-TO instructions & discussions 65 04-26-2016 04:16 PM
Ginger lost 66 lbs with new running shoes! 18" Forgestar F14 SUX2BU Wheels and Tires Talk Sponsored by The Tire Rack 63 07-12-2012 02:26 PM
