| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
Shallow Sub stealth box
So i have a 10" Pioneer Premier sub and amp just laying around that I took out of my old car about 6 months ago, I was wondering if there are any "stealthbox" boxes out there for shallow mount subs, wouldnt mind putting this in my car to add a little to the factory sound, especially since its just a fancy paper weight right now. Also, I have looked and looked but is there a good DIY out there for adding a sub and amp to the existing system without cutting or splicing? Thanks in advance!
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
US-
Use one of Subthumps enclosures, the shallow mount sub will fit just fine. I see you have a 1LT, not sure if the adapter he has will work but you can check. I have the BA system so I never really paid attention to anything else that didnt (I am assuming you dont have the BA system). Also for a DIY it is really pretty simple, your best bet is do just do a search, I think you can actually look through my posts as I think I have posted this up before, am just too lazy to type it out again. ![]() Cheers K |
#3 | |
Ah nice then.
You should be good to go, hit up Steve over at Subthump and your install should be cake. He has an adapter you can use to alleviate an splicing. He also has nice enclosures you can use as well. Like I said do a search and search on my user name you should be able to pick up all the DIY info you need. I had zero experience before I did my last camaro and from this forum I could get pretty snazzy. Cheers k |
| Thread Tools | |
| NO LIFT SHIFT & 2STEP - WOT BOX IS HERE!!! | Meister@Torq | Audio / Visual / Electronics/ Gauges / Nav | 14 | 12-21-2012 09:57 PM |
| New from RPI! 2010-11 Camaro Carbon Fiber Engine Pieces (Fuse, Brake Res, Air Box) | RPI Designs | Exterior Parts & Accessories | 3 | 03-06-2011 08:42 AM |
| Engine compartment fuse box tie in? | CYBER69 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 2 | 02-01-2011 01:14 PM |
| 'Black Cat' Camaro SS by German Tuner Speed Box | Tran | 5th Gen Camaro SS LS LT General Discussions | 43 | 02-01-2011 08:36 AM |
| Bloom energy box enables off-grid living | 2ndgenz28 | Off-topic Discussions | 13 | 02-24-2010 06:25 PM |
