Old 07-17-2011, 11:17 PM   #1
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
20" factory wheels losing air pressure
I've had to add air to all four tires twice now. First time was a couple of days after the car was delivered, had to add about 3 to 4 psi to all four. Had to add 4psi to three wheels and 6psi to one tonight.
Any thoughts. Thanks!
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 07-17-2011, 11:20 PM   #2
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Are you using a gauge or just the car reading?
Old 07-17-2011, 11:23 PM   #3
Yellow_Glide
Using a trusted gauge. I got the DIC warning the first time and an email from Onstar tonight.
Old 07-18-2011, 12:20 AM   #4
PQ
Booooosted.
PQ's Avatar
I have the same problem but with my POS aftermarket wheels. It's tough to figure these out.
Old 07-18-2011, 12:26 AM   #5
Nessal
Drives: Exige, Miata, Ghia
Yup! I have the same issue. Took delivery with 40 miles on the ODO. Tire pressure was 36psi off the lot. Now with 500 miles on it, the warning light came on and got a onstar notice. They are at 31/32 psi. I thought it just might be the tires expanding from wearing in more. I'm actually about to go pump them right now.
Nessal is offline   Reply With Quote
Old 07-18-2011, 12:35 AM   #6
PQ
Booooosted.
PQ's Avatar
I keep my air hose rolled up outside my garage now. Must be a Pirelli thing.
Old 07-18-2011, 12:38 AM   #7
oldfriend
Drives: Fiat 500 E
Well , on the other hand i do have aftermarket wheels and the OME tires and believe it or not for more than 1 year with no loss of pressure , just the normal drop when got a little cold but never had to put in more air, dropped to 34 but after like 2 maybe 3 miles went up to 36 to 37 psi , just like last week i put it up to 36 when cold before any driving , now it goes up to around 38/39 after same driving distance .Al good over here !
Old 07-19-2011, 08:27 PM   #8
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
You'll experience significant changes in pressure with low-profile tires. If they're all changing by the same amount (approximately), it's likely due to changes in ambient conditions combined with the low volume of air in the tires. Mine change 4-5 psi while I'm driving them.
It's unlikely all four are leaking.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 07-19-2011, 08:31 PM   #9
elpatofeo
LawBraker
elpatofeo's Avatar
Drives: 10 SIM 2LT/RS & 2016 1SS Hyper Blue
I was having the same problem but with my aftermarket wheels, it turned out to be that my wheels were bent. Make sure your wheels are in good condition.
elpatofeo is offline   Reply With Quote
Old 07-19-2011, 10:38 PM   #10
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
There is a Technical Service Bulletin on this. Seems like the bead seals get some corrosion and start leaking. I was putting air in mine weekly before I found out about the TSB. I had to print it out and carry it to the Dealer to get them to fix it.
stso634 is offline   Reply With Quote
Old 07-20-2011, 04:04 PM   #11
Chevrolet Customer Svc
Drives: GM Vehicles
^There are actually a couple of documents on this. You will have to check with your dealer to make sure either of these documents pertain to your issues. If any of you have any issues in getting this resolved let me know and I'll do what I can. Thank you for your time.
Jeff Morris, Chevrolet Customer Service
Old 07-20-2011, 05:41 PM   #12
kmcd
kmcd's Avatar
Originally Posted by kmcd View Post
...It's unlikely all four are leaking.
Apparently I am mistaken. Sorry.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
Ok, I now have my wheels :D PQ Wheels and Tires Talk Sponsored by The Tire Rack 722 12-19-2010 12:13 AM
Wanted to buy: 20" OEM Factory Chromed wheels prostock69 Wheels / Tires 13 07-28-2010 01:07 PM
SLP 2010 Camaro ZL575 supercharged -- unique aero parts & "SS" on grill nUcLeArEnVoY Camaro Photos | Spyshots | Video | Media Gallery 129 04-22-2010 03:59 PM
