Old 07-19-2011, 07:52 AM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
TMPS reset on 2011 2LT
Not sure what happened overnight, but I woke up today and my TPMS has blank reading and says to have serviced. I did have some air yesterday, not sure if / why that would do anything.
I read in the book about resetting the sensors, but in mentions a tool. Can this be done without a tool or does it have to go to the dealer?
FSP tuned: 377/389
Old 07-19-2011, 07:57 AM   #2
RSokie
Proud owner of Litho #195
RSokie's Avatar
Drives: 2011 CGM 2LT/RS
Wow never heard of that one
Old 07-19-2011, 08:01 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Great, only me!
I'm sure they need resetting but I am not sure if I need a tool for that.
FSP tuned: 377/389
Old 07-19-2011, 08:09 AM   #4
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
This will need to be taken to the dealer.
TheHorse13 is offline   Reply With Quote
Old 07-19-2011, 08:22 AM   #5
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
Originally Posted by nyrfan View Post
Not sure what happened overnight, but I woke up today and my TPMS has blank reading and says to have serviced. I did add some air yesterday, not sure if / why that would do anything.
Starting mid year 2011 from what I have been told you can no longer relearn the tpms without the proper tool.
thiggin2 is offline   Reply With Quote
Old 07-19-2011, 08:24 AM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
Interesting, my build was Jan 2011, I wonder if I can do it without the tool?
How would I try it without a tool?
FSP tuned: 377/389
Old 07-19-2011, 10:16 AM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Mystery solved, turns out this did not "just happen"
As I mentioned, I had air put in the tires yesterday (actually my wife did it to be nice as she had the car). She thought she had to do a reset of the TPMS after doing this .
Well while this is a bit of an inconvenience as I am going to have to visit the dealer to reset, it was nice of my wife to try to help. More importantly I now know what happened and that it's not some kind of computer problem.
I called my dealer and was honest about what happened. He said bring it in and I'll be out in about 5 minutes, no charge. Guess while I am there I'll hit them up for my 1K oil change.
FSP tuned: 377/389
Old 07-19-2011, 10:28 AM   #8
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
I believe you can manually reset these... check your manual I know there's a way to do it without that tool. Ask your dealer while your there, I'm sure they'll tell you one way or the other if this is do-able at your home or not.
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 07-19-2011, 02:23 PM   #9
nyrfan
Let's go Rangers!
nyrfan's Avatar
As an FYI - I was in and out of the dealer in 5 minutes.
FSP tuned: 377/389
Old 07-19-2011, 02:39 PM   #10
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
I have a 2011 SS and relearned the sensors after putting new wheels and sensors on. Just went into the DIC started the relearn and went to each wheel starting with the drivers front, to pass front, to pass rear and finishing with driver rear letting a little air out of each tire until the car honks each time. Then when your done the car honks twice and your done. You can then go back and adjust to proper pressure. Worked for me.
Bo Tie 1 is offline   Reply With Quote
Old 07-19-2011, 02:47 PM   #11
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
When I got my new tires at TPMS at discount tire, the service tech had a hand-held sensor tool he just put against the tire wall and the car set the new pressures on its own. Took 1 min for all 4 tires.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 07-19-2011, 04:44 PM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
This does not work on the newer 2011's as noted by the manual. The newer manuals specifically point to needing the tool. Of course I did try it thinking it would still work, but it doesn't.
FSP tuned: 377/389
Old 07-19-2011, 04:53 PM   #13
Bo Tie 1
Bo Tie 1's Avatar
My manual did not say anything either. But I found the info on this site and gave it a try and it worked (go figure)
Old 07-19-2011, 06:21 PM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
Who knows, these damn manuals. Either way my dealer fix my issue.
FSP tuned: 377/389
SINSTR6 - 2011 Black 2LT mikeb27 Member Car Journals 20 05-06-2011 12:45 PM
WTB 2011 2LT RS Door Panels Exo5168 Interior Parts & Accessories 4 04-19-2011 07:39 PM
2011 2LT Pricing ZCT Camaro Price | Ordering | Tracking | Dealers Discussions 1 07-22-2010 02:45 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
