Old 03-27-2011, 12:04 PM   #4677
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Originally Posted by BUMBLEB View Post
Larry,Garth,Ted what clutch are you guys running and or what clutch do you recommend,I am getting ready to pull my trans and fix an oil leak I have at the rear main seal,may as well put a clutch in.
ZR1, works great and feels like a stock.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 03-27-2011, 01:22 PM   #4678
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
UPDATE:T-shirt PAYMENT using my Paypal account iom2010camaro2ssrs@msn.com
Kirk and Rick suggested using paypal, so had to find out how. Please make sure to check "SEND AS GIFT" so there isn't a transaction charge to me. Include your Name, # of shirts, and $15 per shirt(don't include sizes... I'm only refering to the Camaro5 thread for... that)
OKAY! "Tequila Sunrise" and "Midnight Run" T-shirt order for the Camaro5fest drive
Please respond ASAP, trying to get order placed on Wednesday morning 3/30/11
LPE Brotherhood
Old 03-27-2011, 06:16 PM   #4679
Blue70SS
Blue70SS's Avatar
ZR1 twin clutch has springs incorporated in design that makes it smoother. It will help take out some of the driveline shock too. That really comes into play if your doing harder bushings, engine mounts, or removing driveshaft guibos. On the other hand, not sure it has the SFI ratings..... Also ZR1 requires the Lingenfelter flywheel.
LPE Brotherhood
Old 03-27-2011, 06:34 PM   #4680
BUMBLEB
IN GOD WE THRUST
BUMBLEB's Avatar
Drives: 2010 RY 2SS RS M6 TVS2300 2015 Z06
who has the best price on the clutch?Lingenfelter lists 2 diffrent ones 1400.00 or 795.00
BUMBLEB is offline   Reply With Quote
Old 03-27-2011, 07:20 PM   #4681
Commit and Conquer
Commit and Conquer's Avatar
Drives: 2010 Camaro SS
According to SPEC website all of their flywheels are SFI approved, but it doesn't say anything about the various clutches.
Call me old school but I like the feel of the single disc. I like to think that those extra reps on the leg press are paying off! The stiffer clutch is a personal preference for me so in the final hour I opted for the Spec Stage 4 with the billet steel flywheel.
Forged 418 w/Whipple 2.9L RMCR Tune
786 RWHP 745 RWTQ[/SIZE][/COLOR]
Manley Crank, Wiseco Pistons, Compstar H Beam Rods, ARP Main/Studs, Copper Treated "hi boost" head gaskets, FI Cam & Ported Heads w/Manley Extreme Duty Valves, Lunati Link Bar Lifters, Fuel System w/LPE Dual pumps, Twin Fuel Feed line/Single return w/ boost reference regulator, NW 102mm TB, 10-Rib ASP custom pulley kit, Twin RX Catch Cans, Roto Fab CAI, TSP Stainless Headers, Spec Twin Disc P-Trim Clutch, DSS Level 5 Axles, Eibach and BMR Full suspension
Commit and Conquer is offline   Reply With Quote
Old 03-27-2011, 08:09 PM   #4682
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
I contacted Spec and on mine both the clutch and the flywheel are SFI certified and they are sending me the certificates since I think they got thrown away....We have to have them in our log book for tech inspections. Yours should be right there with the paperwork on yours. However, beyond the specs and certification on the flywheel and clutch you will need the SFI6.1 bellhousing to cover the whole thing up. It was suggested to take a picture of it installed for the log book as well.
Go Joe go...
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 03-27-2011, 08:53 PM   #4683
Blue70SS
Blue70SS's Avatar
The $1470 one includes the flywheel to adapt to 6 bolt pattern, plus a few other items. Looks like you still need the $99 actuator spacer for the Camaro.
$750 is pressure plate and clutch only, but looks like an enhanced ZR1 clutch system with 20% more holding power good for up to 960+ HP. Wonder if it's a newer one. Other one says tested up to 700 HP?
LPE Brotherhood
Old 03-27-2011, 08:55 PM   #4684
Clint@A.I.R.
Drives: 99' Camaro 404 TT
Let me know if you need a clutch.. I can get you a clutch for a good price..
Regards,
Clint
Clint@A.I.R. is offline   Reply With Quote
Old 03-27-2011, 08:56 PM   #4685
Blue70SS
Blue70SS's Avatar
Go Joe go...
So what with the "Log Book"?
LPE Brotherhood
Old 03-27-2011, 09:23 PM   #4686
Commit and Conquer
I was waiting for someone to ask...yeah what with the "log book"?
I'll be the first to admit I'm a newbie but this one is new to me
Old 03-27-2011, 09:24 PM   #4687
Commit and Conquer
Go Joe go...
Larry go ahead and make a copy of that pic for my log book would ya?
In fact, would you go ahead and put together a log book for me?
Old 03-27-2011, 10:04 PM   #4688
2SSONLY
2SSONLY's Avatar
Drives: FAST!
Racer's keep a log book with all the specs on their car, certifications including chasis if needed, expirations dates, etc. Makes teching a breeze.
#5336, 6M, Racing Bone Stock; lookn' to spoil.
can't cut a light...can't run the number...can't even quit.
2SSONLY is offline   Reply With Quote
Old 03-27-2011, 10:12 PM   #4689
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
The log book is something you need to put together with all of your clutch and bell housing information. It will have the SFI certification level date of manufacture, inspection information, serial numbers on the flywheel, clutch or clutches, slipper plates on multi disk, friction plate serial numbers, pressure plate serial numbers, and the certification expiration date. You might also put any information you have on any other SFI items you have; harmonic balancer,belts, trans blankets etc.
2011 Synenergy Green 2SS/RS Automatic.Roto Fab, Bo White ported throttle body, GPI rod mod intake, VVT SS3 cam, CNC ported heads, Doug Thoutley tri-y long tube headers, Solo Mach cat back with j pipes. Yank converter, Factory Reproductions Chrome Z28 wheels ect, ect
Hulk is offline   Reply With Quote
Old 03-27-2011, 10:16 PM   #4690
2SSONLY
2SSONLY's Avatar
Drives: FAST!
Yep, anything they can't see to inspect without dismantling the car.
