Cold Air Inductions
Old 03-29-2011, 02:30 PM   #4733
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
Drives: Victory Red 2010 2SS/RS A6
You are right Don, it isnt as cool, its cooler!!!
Camaro Club Of The Rockies (CCOTR) Check us out on Facebook!
2010 Camaro SS/RS Victory Red A6- Vararam Intake, Doug Thorley Tri Y LTs, Magnaflow X-pipe, Flowmaster Super 40's, VMS Tune, Razzi Ground Effects, Herritage Grill, RED headlight and fog light Halos, LED DRLs, Dash and extended Door ABL, engine, grill and rear defusser LED lighting ........ 12.59@112.21 (DA Corrected)
Icntdrv55 is offline   Reply With Quote
Old 03-29-2011, 02:34 PM   #4734
ud_lose
#34873
ud_lose's Avatar
Drives: '04 Ford F250 6.0L/'69 vette LS6
I guess that means that team L99 wins since team LS3 can't get past tech.
ud_lose is offline   Reply With Quote
Old 03-29-2011, 02:58 PM   #4735
AquaRSSS
AquaRob
AquaRSSS's Avatar
Drives: ABM RS\SS; 69 427 Camaro; 1970 Z28
..only because the L99 ain't breaking the 11.49 second barrier!! Slushboxes get an automatic pass...no pun intended.
AquaRSSS is offline   Reply With Quote
Old 03-29-2011, 03:14 PM   #4736
walhan_qtr
..[ Z06-QTR ]..
walhan_qtr's Avatar
Drives: '10 Camaro 2SS RS M6/ 07 C6 Z06
Send a message via MSN to walhan_qtr Send a message via Yahoo to walhan_qtr Send a message via Skype™ to walhan_qtr
- 07 Silver C6 Z06, Darton sleeved LS7, 441ci, H/C/I, Duel Stage Nitrous, RPS BC3, TR6060, E85. (615whp/582wtq N/A)
- 09 Blk Z06, 427ci LSX, F2 Procharger, Brodix, Holley, ZR1 TR6060, ... (1204whp/1045wtq @ 24psi)
- 06 Blk C6, Darton Sleeved LS2, 427ci, H/C/I, F1X, RPM Trans/Diff, RPS BC3. (New #s soon)
- 10 Black Camaro LS3, 2SS/RS, H/C/I, bolt-ons, Spec. (470whp/450wtq).
- 07 Black Corvette C6(SOLD).
- 98 White/Red Corvette C5(SOLD).
walhan_qtr is offline   Reply With Quote
Old 03-29-2011, 03:14 PM   #4737
Commit and Conquer
Commit and Conquer's Avatar
Drives: 2010 Camaro SS
Originally Posted by mtcwby View Post
OK, I've been on the phone all morning with NHRA tech dept. in CA,
and with SFI Research tech.
There is currently NO parts or blankets that will get our bellhousings past tech inspections.
SFI stated that a SFI 4.1 rated blanket will protect us from a clutch exploding, but the way the 4.1 spec reads, it will not pass inspection.
There are no manufacturers that make a blanket that is labeled to meet the 6.3 rating that we need for superchargers or nitrous.
There is a SFI 9.1 rating for a bellhousing blanket that will pass NHRA Tech inspections, BUT SFI said that there are currently no manufacturers that have even submitted a product to them to be tested to that spec.
When I talked to NHRA, they will not budge. Even though they admit that a 4.1 rated blanked will do the job, it is written for automatic transmissions and not for bellhousings. So technically it won't pass. UNLESS we happen to find an inspector that uses common sense instead of the letter of how the rule is written.
So, if we want a blanket to use and not have to buy a whole transmission. We need to find a manufacturer that will submit their blanket to SFI to get tested and labeled for the 9.1 spec. But that takes time and probably won't happen during this race season.
It will really be interesting to see what alot of the guys that show up at Camaro5fest with sub 11.49 cars do to get past Firebird's Tech inspection. They won't be at some Ma and Pa track that lets them slide.
Why didn't this come up at C5fest. last year? I'm sure there were plenty of sub 11.5 LS3's...
Don,
Let me know if you are still planning to order the SFI 4.1 blanket. My legs are still interested even if it won't pass inspection!
Forged 418 w/Whipple 2.9L RMCR Tune
786 RWHP 745 RWTQ[/SIZE][/COLOR]
Manley Crank, Wiseco Pistons, Compstar H Beam Rods, ARP Main/Studs, Copper Treated "hi boost" head gaskets, FI Cam & Ported Heads w/Manley Extreme Duty Valves, Lunati Link Bar Lifters, Fuel System w/LPE Dual pumps, Twin Fuel Feed line/Single return w/ boost reference regulator, NW 102mm TB, 10-Rib ASP custom pulley kit, Twin RX Catch Cans, Roto Fab CAI, TSP Stainless Headers, Spec Twin Disc P-Trim Clutch, DSS Level 5 Axles, Eibach and BMR Full suspension
Commit and Conquer is offline   Reply With Quote
Old 03-29-2011, 03:20 PM   #4738
ud_lose
#34873
ud_lose's Avatar
That's funny. I must be misreading this then.
NO Member Engine/Trans Modifications 1/4 ET @ MPH Details
1
jrh@lpe
TR6060
LS9, Supercharger/TVS 2300, Nitrous, Cam, LT, Exhaust, 9.5, gears, 16'' Skinnies, Slicks
8.997 @ 158.80 MPH
735
2
Paul2010
A6
427 ci, Supercharger/TVS 2300, Heads, Cam, LT, Exhaust, Converter, gears DRs
9.84 @ 144.69 MPH
3
Brooksracing/LMR
A6
427 ci, Supercharger F-1R, LS7 Heads, Built 6L80 E, Converter, Skinnies, 18'' Hoosiers
9.91 @ 124 MPH
433
4
Adam@ST
L99, A6
Supercharger/Kenne Bell, LS3 Cam, Exhaust Converter, 17'' slicks
10.115 @ 139.31 MPH
698
5
SuperchargedSS
A6
Supercharger, TVS/2300, LT, Exhaust, CAI, Meth Inj, Converter, 17'' slicks
10.193 @ 130.22 MPH
599
Old 03-29-2011, 04:18 PM   #4739
AquaRSSS
AquaRob
AquaRSSS's Avatar
1
jrh@lpe
TR6060
8.997 @ 158.80 MPH
735
2
Paul2010
A6
9.84 @ 144.69 MPH
3
Brooksracing/LMR
A6
9.91 @ 124 MPH
433
4
Adam@ST
L99, A6
10.115 @ 139.31 MPH
698
5
SuperchargedSS
A6
10.193 @ 130.22 MPH
599
Ok,
You got me... 4 exceptions out of 99,000 sold.
First one listed a TR6060...and it's the FASTEST one on the list..SWEET!!
thanks!!
Rob
Old 03-29-2011, 05:16 PM   #4740
Icntdrv55
CCOTR Member
Icntdrv55's Avatar
Doesnt look like any LS3s will be breaking the 11.49 second barrier either safely of course....Matter of fact, Im pretty sure I can take Larry RIGHT NOW. I just have to point out the lack of safety equipment on his car, he gets disqualified, I win!!
All that money spend to go fast and you still lose to the A6's! :happy anim:
On a serious note, I would sure like to know how they got away with it last year at C5F I and how everyone who is running under 11.49 is going to get away with it this year. There are many cars that are running that fast going to race at C5F II. How are they doing it???? Kinda makes you say....MMMMMMMMmmmmmm
Old 03-29-2011, 05:26 PM   #4741
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
Originally Posted by 2010 SS RS View Post
Just as a fyi... I talked to Tremec this morning. Housing is made of aluminum and has no sfi rating or protection for that matter. They suggested I speak with Rockwell Standard Gears. I did and ended up being transferred to the performance and racing division. I am waiting for George to give me a jingle back. Looking over the web site it seems that most have gone with upgraded T56 transmissions and dumped the 6060 entirely. T56 does have a bellhousing available. Rockwell has several set ups including Drag racing builds for 1200 hp versions and several road racing versions as well.
The guy at Tremec totally understood the issue and was equally frustrated that nobody has made a sfi approved bellhousing because it makes this an unsupported performance tranny.
It's almost funny that a company as big as Tremec would be frustrated that nobody makes one. You'd think they would think wow... "captive audience" and capitalize on it. They obviously have the know how.
LPE Brotherhood
Old 03-29-2011, 06:04 PM   #4742
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
I still say call Browell Bellhousing. 765-447-2292 They are the company that would help me out to get a bellhousing to match my block/tranny combo last year when others(including Lakewood) were not that interested in making what I needed. They had it to me in 3-4 weeks normal production once we got all the dimensions verified.
2011 Synenergy Green 2SS/RS Automatic.Roto Fab, Bo White ported throttle body, GPI rod mod intake, VVT SS3 cam, CNC ported heads, Doug Thoutley tri-y long tube headers, Solo Mach cat back with j pipes. Yank converter, Factory Reproductions Chrome Z28 wheels ect, ect
Hulk is online now   Reply With Quote
Old 03-29-2011, 06:08 PM   #4743
Blue70SS
Blue70SS's Avatar
Originally Posted by Commit and Conquer View Post
So here is a question for LPE. I know they are running an RPM rebuilt tr6060 tranny in their 8 second car, just like your new one Garth...you dog!
If their is no bellhousing made for the 6060 what are they running that they are passing inspections?
A Black blanket from RCI ..... not sure what the SFI# is though. I'm assuming 4.1 but haven't got an answer back yet. Although, one should show up at Laramie GM on Friday for $255 - how's that for blind ordering. LPE has ran at numerous NHRA tracks and no problems - not quite sure how everyone's getting away with it. I figure worse case is I sell it to Kirky when he gets a Supercharger or high stall torque converter, since it's definitely legal for catching auto guts. While running under 11.5 sounds fun, my goal is to run close to it and not deal with all the extra stuff. On the other hand, I'd jump all over an SFI bell housing at time of install. But as usual, the "Drool Factor" always keeps kicking in! Keeping my legs might be nice too .... I'll let everyone know how it works. (blanket install, not legs)
Then.... Larry's got my head spinning about the T-56 transmission. It always seems to take longer to get things to market than the manufacturers say though. I do think it's great that we're all looking out for each other's interests. Looks like 5 or 6 people all researching...
LPE Brotherhood
Old 03-29-2011, 06:57 PM   #4744
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 17 A10 ZL1,14 2ssrs,96,85,79,69&67
Good luck. Luckily my car is not even close to that fast. Sometimes it pays to be all stock....
Old 03-29-2011, 08:01 PM   #4745
AquaRSSS
AquaRob
AquaRSSS's Avatar
$5 solution...Checker Auto can of red spray paint--paint the bellhousing and when the tech sees the red bellhousing, just nod your head when he asks if that's a Lakewood. He-he
Old 03-29-2011, 10:07 PM   #4746
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
love the idea of red paint Rob...lol
KK I got my call back from George Kreppein at Rockland Standard Gears
http://rsgear.com/about-us/the-transfer-case-guru.aspx
He heads up the division that builds the race tranny's
http://rsgear.com/products/transmiss...smissions.aspx
At present he is in the process of building a race strength TR6060 with a sfi rated housing. He is building it for Hennessey for a special car. He explained the reason no one is touching the TR 6060 is due to the location of the oil pump for the tranny. It is in such a location that it prohibits a bellhousing to fit or be used. This special tranny will be made at Tremec and built by his team. Cost is going to be around 4800 but it will meet all standards..bolt right in. be bullet proof and also be specific gear ratios for maximum racing and a balanced driving. Different gear sets if road racing is the goal. Polished gears, carbon fiber syncros, billet output shaft, sfi 6.3 certified. And a warranty to boot.
18002271523 rockland standard gear.
He will be sending me the specs and I will post them up when available.
Larry
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old school members! 4thGenRocks Off-topic Discussions 14 07-06-2010 04:00 PM
For Sale: 2007 Chev Colorado EXT Cab Z71 4X4 bluch Autos For Sale / Wanted 7 06-25-2009 02:03 PM
Check out this web site i found ezlock83 5th Gen Camaro SS LS LT General Discussions 5 03-04-2009 12:44 PM
Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 236 04-22-2008 12:43 AM
# Of Members TAG UR IT Site Related Announcements / Suggestions / Feedback / Questions 25 03-16-2008 11:47 AM
