| Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
Future 5th Gen Owner
Drives: 2006 Chevy Equinox AWD/LT Join Date: Dec 2008
Why is the V6 automatic limited to 115mph?
Not that I'll ever go 115mph, I'm just curious as to the reasoning of the limitation.
Senior Member
Drives: 2010 Camaro 2SS Join Date: Oct 2008
Tires
![]() Drives: 2010 ss rs ls3 red-white rallys Join Date: Oct 2008
yep tires
#4 | ||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
because you touch yourself at night.
seriously tho, its due to the speed rating of the tires. use the search button
![]() Drives: pontiac g5 gt Join Date: Mar 2009
size 18 tires tops off at 118. 19,20 tires tops off at 155.
#6 |
Well, I'll be having 20"s on my 2LT/RS.
#7 |
![]() Drives: '03 Monte Carlo SS Join Date: Mar 2008
then you're fine.
its on the Camaro site. M6 or A6, its an electronic limiter placed at build based on the shoes it comes with. Only the LS and 1LT sport the 18s, the 1LT does have the RS option available to give it 20s. That would get set you to the higher limit. The 2LT has base 19s anyway so it would be set to 155 regardless |
#8 |
Does not have a Camaro
Drives: 99 silverado Z71/66 Chevelle SS Join Date: Apr 2008
I always figure if you cant hit the top speed in the quarter than you don't need to go anyy faster
#9 |
![]() Drives: 2010 Camaro 2LT Rally Yellow Join Date: Mar 2009
Where do you find out all this info?
Ordered 2LT RS |
#10 |
![]() Drives: CGM 2LT RS Join Date: Feb 2009
I have found a lot fn the specs on the new camaro builder that GM put up Monday.
#11 |
Senior Member
#12 | |
only the LS and an un-optioned 1LT would ship with 18s everthing else would be set to 155 Go look at the build site, on the home page Perfomance 01 hover over View Stats 118mph(18-inch tires)/155mph (19/20/21-inch tires) **all models electronically limited** |
#13 | |
50.335252,6.947103
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 2009 Jeep Wrangler Unlimited Join Date: Feb 2008
If I go with a V6, I will get the 2LT
#15 | |
![]() Drives: 2010 LT2 Camaro, 2008 Enclave Join Date: Nov 2008
Past highlights: 2010 pre-order Camaro 2LT,1969 Chevy Malibu, 1972 Plymouth 'Cuda, 1972 Pontiac GTO, 1979 Turbo Buick Century. 'See the USA in your Chevrolet...' Dinah Shore, 1952: http://www.youtube.com/watch?v=KGZvQoPxhNs |
#16 |
![]() Drives: 98 Jeep Cherokee Classic Join Date: Mar 2009
#17 |
#18 | |
![]() Drives: 2SS Camaro LS3 Join Date: Oct 2008
I believe the SS's are aero limited just like the SS Cobalts. GM if I remember correctly stated the SS Cobalt could not exceed 148, however I've had mine up to 155 just after I broke it in.
RECEIVED 5/22 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
#19 | |
![]() Drives: '88FieroGT'04ColoradoZ71'10CamaroLS Join Date: Mar 2009
#20 | |
just can't seem to leave
the wheel size don't affect the speed rating. if they wanted to put some Y-rated tires on the 18" wheels, they could've, but they went with some lower-speed all-seasons. ps - there's plenty of threads discussing this topic.
#21 |
i wonder if you get the ls and buy z rated tires that the dealer can boost up the max speed?
#22 |
i doubt the dealer would, but anybody with an OBD2 tuner can
#23 | ||||
The Jalopy Jedi
I doubt they would. not to mention, you dont need to be going that fast
#24 |
that is true i have a car that tops off at 120 that is plenty fast enough.
#25 |
![]() ![]() ![]() Drives: 04 Pontiac Grand Am, 08 Ninja 650r Join Date: Jan 2009
i think that's subjective
| Thread Tools | |
| Limited slip - slip up by Chevy | mjf | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 27 | 09-12-2012 02:53 PM |
| Camaro SS Automatic (13.2 @ 109 mph)? | SGOS252382 | 5th Gen Camaro SS LS LT General Discussions | 56 | 03-09-2009 03:35 PM |
| 6-speed Automatic Specifications (SS) | Tran | Wiki | 0 | 10-19-2008 01:01 PM |
| 6-speed Automatic Specifications (LS/LT) | Tran | Wiki | 0 | 10-19-2008 12:55 PM |
