Old 07-21-2011, 06:11 PM   #1
usranger80
usranger80's Avatar
Drives: 2011 1LT "Bumblebee"
Green Valve stem cap=Nitrogen filled?
Just wondering, I have been reading that if you have green valve stem caps it means your tires are filled with nitrogen, my Camaro came from the dealer with green caps but nobody mentioned to me if they were filled with nitrogen...does anyone know if this is common for the Camaros....and how do I even know if the caps are just green or nitrogen filled?
usranger80 is offline   Reply With Quote
Old 07-21-2011, 06:18 PM   #2
11_Camaro
11_Camaro's Avatar
Drives: 2011 RJT 2SS/RS L99
Normall, green caps mean nitrogen filled. I belive it is pretty common. You could contact you dealer and ask whther the tires are nitrogen filled.
11_Camaro is offline   Reply With Quote
Old 07-21-2011, 07:41 PM   #3
pastohio
Drives: Indy Pace Car
To my knowledge they are NOT using nitrogen at the factory, not sure why a dealer would go to this expense, takes a few minutes to evacuate the current air and then buy and put in the nitrogen....I am a BIG BELIEVER in Nitrogen ( in the airline business) YES, green caps are for nitrogen, and some even have the "N" stamped on the top of the cap as well...good luck.
pastohio is offline   Reply With Quote
Old 07-21-2011, 07:44 PM   #4
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
As far as I know mine came from the factory with nitrogen...
FL1CK is offline   Reply With Quote
Old 07-22-2011, 04:41 PM   #5
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
Yes green caps are nitrogen. Most new cars come from the factory with nitrogen fill as there is a profit in it and usually an extra charge. I do not think they come from the factory this way and is a dealer add on. However because nitrogen doesn't change pressure due to temps to the degree air does it keeps the TPMS light for going of due to temp changes. So it nice in newer cars with Tire Pressure Monitoring.
When ordering online please reference "Rudy/Camaro5" as your previous contact. Please click on the link in the sticky thread at the top of wheel and tire forum so the forum gets credit for the sale.
Rudy@Tirerack is offline   Reply With Quote
Old 08-07-2011, 05:32 PM   #6
mikeyroche
Drives: 2011 VR Camaro 1SS/RS M6
Regulations are normally pretty strict up compressed air. Green covers are not only supposed to say what they should take, but what is in the tires. I know mine came from the dealer with Nitrogen filled tires, and even has a sticker on the front windshield saying it uses nitrogen filled tires. I don't think this is a dealer thing since the Pirelli P Zero's are supposed to be Nitrogen filled
2011 Camaro 1SS with RS - K&N Typhoon CAI, Borla Atak Exhaust, Hawk Performance Ceramic Pads, SLP 'SS' Front Grille Emblem, Blue LED interior lighting, Camaro Victory Red Seatbelt Harness pads NEXT - Corvette LS3 Victory Red Fuel Rail Covers(Awaiting Installation), Window Tinting, Custom Leather Interior.
mikeyroche is offline   Reply With Quote
Old 08-07-2011, 05:37 PM   #7
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
If it has Nitrogen... it was done at the dealership, not the factory.
Sterling is offline   Reply With Quote
Old 10-19-2011, 09:17 AM   #8
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
I got mine right off the truck. No green cap, and air is not steady, which means no nitrogen.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 10-19-2011, 10:05 AM   #9
Stingr69
'69 Owned Since '79
Stingr69's Avatar
It's a profit item for the dealership to "install" the nitrogen. They tried to add $50 on top my bill for it at delivery (I was already at sticker!) but I said "no way". They said they will take the nitrogen out, fill it up with air and not charge me the $50. Think about it!!!!
-Mark.
Old 10-19-2011, 11:17 PM   #10
cjordan310
Drives: 2011 LS M6 black
well my tire pressure monitor said that one of my tires need air, i unscrewed the stem cap and looked and it def said "NITRO FILL" sliver cap with white background and blue letters so... abuot to read the owner's manual and then call the dealer 2morrow. I'll let you guys know
cjordan310 is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 289 08-26-2017 12:29 PM
Production Synergy Green Camaro Special Edition - press release and photos CJP 5th Gen Camaro SS LS LT General Discussions 158 01-23-2010 11:42 PM
NEW SYNERGY GREEN INFO, chat i had with camaro representative streetsteve 5th Gen Camaro SS LS LT General Discussions 15 01-13-2010 04:56 PM
GREEN Camaros are coming, WHITE Camaro is alive, and Buick 3800 engine rumor Tran 5th Gen Camaro SS LS LT General Discussions 127 09-25-2009 05:15 AM
Green Camaro, opinions? moto-camaro Camaro Photoshops / Renderings Forum 14 06-26-2009 01:30 PM
