Old 07-21-2011, 07:42 PM   #1
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
OEM Tire rims and E Brake lines
I just put bigger tires on my OEM rims, and noticed that the Drivers side Ebrake line has slight cuts in the rubber on the line, from hitting the rim it looks really close to the rim, the passenger side has much more space between it, what should I do... Just get a metal clamp and clamp around the toe arms, not sure if that is a good idea or not??
MARINE1991 is offline   Reply With Quote
Old 07-21-2011, 10:28 PM   #2
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
Read this.... Post #5 & Pics in #52
Quick fix and has been on for two years with no issues
http://www.camaro5.com/forums/showth...=E-brake+cable
CCW polished 505a's
Front 20x10 w/275/40/20's
Rear 20x11.5 w/305/35/20's
Eibach 1" Pro Spring Kit
Factory GFX
MPD1 spoiler
painted bowties
15% tint
FEN is offline   Reply With Quote
Old 07-21-2011, 10:48 PM   #3
MARINE1991
MARINE1991's Avatar
thanks, that the same issue I am having, dont know why GM left that much slack in there, the passager side is good. Good idea, I have to take the car in to get the alignment finished I will tell them about your idea.. see if they have a better one, but yours works too.. thanks...
Old 07-21-2011, 10:55 PM   #4
FEN
FEN's Avatar
It works good. If you just pull the slack away from the wheels it eventually creeps back to its original position. Definitely needs to be clamped as seen in the pictures in my link.
CCW polished 505a's
Factory GFX
MPD1 spoiler
painted bowties
15% tint
Old 07-21-2011, 10:57 PM   #5
MARINE1991
MARINE1991's Avatar
yea I am going to have them do that for me... thanks alot for the help..
Old 07-22-2011, 08:15 PM   #6
MARINE1991
MARINE1991's Avatar
It worked out great.. thanks for the idea.. the guy put 3 on.. seems to be holding will keep an eye on it.. Wish he would have given me a little more room but its good for the OEM rims for now.. thanks again.
Old 07-22-2011, 09:12 PM   #7
FEN
FEN's Avatar
No problem....good to hear it worked out.
CCW polished 505a's
Factory GFX
MPD1 spoiler
painted bowties
15% tint
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
Selling rs package rims and tire Nirvanaforever USA - NY / NJ / PA 3 11-25-2010 03:14 AM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
