Emblempros
Old 07-22-2011, 10:25 AM   #1
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
Is this Noise normal when driveing/shifting M6
when i am and shifting gears i hear like a shhhhhshhhh shound coming from my shifter/tranny.. when i am rolling in nuetral and i push the shifter to one side or another i near the same sound... I have a hurst shifter... i just changed my tranny fluid with amsoil yesterday still hear the noise...You can only hear it when the windows are up and radio and ac is off.. 2010 m6 with 5050 miles.
Thanks for all the help guys
Whipped416 is offline   Reply With Quote
Old 07-22-2011, 11:30 AM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Sounds like the lower boot might be opening up and you get to hear more noise. Take the console guages off and see if you can find the air leak. Worth a shot.
The other thing to ask - Amsoil? Is it Automatic Tranny Fluid or is it Gear Oil? You are supposed to be using ATF, not gear oil. That could be making a difference.
-Mark.
Old 07-22-2011, 06:07 PM   #3
Whipped416
Whipped416's Avatar
used amsoil ATF!! YOU THINK THE DUST BOOT COULD BE LOOSE?? maybe it didnt fit right when i took it off to swap shifters
Old 08-01-2011, 05:39 AM   #4
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
could be some of the set screws on the shifter if they get a little backed out they make an annoying sound thats even worse in 5th and 6th . I have a LSR and have had to tighten mine twice.
JLE58 is offline   Reply With Quote
A/C Whining Noise Modern07 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 54 01-14-2014 09:44 AM
Rear end "popping" noise, need help and opinions Fiftydriver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 35 09-19-2013 09:47 PM
Is this noise normal? For LS3 M6 owners only. CamaroSS_LS3 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 57 06-19-2012 02:39 PM
Front End Knocking Noise Dave Sparkes Camaro Price | Ordering | Tracking | Dealers Discussions 4 04-14-2011 08:06 AM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 11:42 PM
