Jason 98 TA
Old 08-17-2011, 01:42 AM   #15
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Started the Whipple install
Installed the heat exchanger.
Pinned the crank.
BAP installed.
ADM race scoop.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 08-18-2011, 03:24 AM   #16
yotaman96
yotaman96's Avatar
Inside the Whipple.
Old 09-08-2011, 12:14 AM   #17
yotaman96
yotaman96's Avatar
Been a little while since I updated.
Heritage grille and lower street scene grille with custom painted ports installed. Unfortunately, I now have some paint peeling on my front bumper.
Inside the lower driver side port, you can see the ADM race scoop. I had to cut on it a bit to fit with the port.
Whipple is installed. I ordered the powder coated black CAI from Juiced. CAI is having some supply issues and I needed my intake in time to get tuned and make it to the LS Fest on the 9th. After waiting over a month, Juiced is letting me borrow a polished CAI until mine arrives. You can also see the Roto-Fab windshield washer relocation reservoir in this pic.
I installed the RX performance catch can.
One hose runs from the driver side valve cover to the catch can from the catch can, the hose runs to to center port seen here:
Vmax throttlebody.
Showstopper led sidemarkers. The camera on my phone doesn't do them justice when let. They're awesome. Much nicer than that other companies.
Widened wheels and tires are on. 10.5" in the rear with 315's and 9" in the front with 275's.
Separated the clutch reservoir from the brake reservoir.
McLeod RXT clutch, pressure plate, and flywheel installed.
Tick Performance speed bleeder. I have it zip tied to the trans coolant lines.
DSS 3.5" aluminum driveshaft.
Metco driveshaft safety loop.
Old 09-08-2011, 12:41 AM   #18
arussh
arussh's Avatar
Drives: 2011 2ss/rs, 1990 iroc-z
Very impressive work and attention to detail.
If it runs as well as it looks and I suspect it does, you have a hell of a ride.
Nice.
arussh is offline   Reply With Quote
Old 09-08-2011, 12:47 AM   #19
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
VERY Sweet Ride!
SamHouseIII is offline   Reply With Quote
Old 09-12-2011, 09:38 PM   #20
yotaman96
yotaman96's Avatar
Afterburner tail lights are installed.
And a video showing them working with the sequential turn signal harness.
http://i28.photobucket.com/albums/c2...S/8c86656e.mp4
Three pics of me at the LS Fest courtesy of hotrod.com. The one showing my time shows smoke coming from my car. The oil cooler was leaking so I had to stop racing. Sucked because I know I could have improved my time. The drag radials just needed to be broken in to get better traction.
And a video of that run.
http://i28.photobucket.com/albums/c2...S/796127d9.mp4
Old 12-25-2011, 05:37 PM   #21
yotaman96
yotaman96's Avatar
It's been a bit since I updated. Due to issues with my afterburners, I sent them back and put my stock lights back in. When sjmautoprod releases his, I will try those since I love the look. I also had issues with my DSS driveshaft and my McLeod RXT clutch. I will say that DSS has been excellent to deal with and they have taken care of everything including shipping costs. Top notch company. My axle seals have been leaking as well as I believe my oil pan gasket. Needless to say, my car is currently in pieces right now while I'm chasing down issues. I also took the front bumper off to get repainted to fix a flaw.
I decided to put sjmautoprod's halo kit in.
I also had some custom rotors made by r1concepts.
The back side.
I painted them with high temp black paint so that once used, the dimples and engravings will stay black.
And well, since my car is in pieces right now, I figured why not just take it apart some more? So, I started a cam swap. After looking at a bunch of different cams, I chose a blower cam from TPE.
I decided to swap from the single bolt cam to a 3 bolt cam.
The Crane valve spring tool is expensive, but after using it, I can tell you it's definitely worth the money. It makes the spring swap so easy.
I'm excited to get the car back together and see how well everything works together. I have a lot to do.
Old 01-06-2012, 10:06 PM   #22
yotaman96
yotaman96's Avatar
I did the initial startup tonight after installing the TPE blower cam. After I made sure it had oil pressure, I got out, shut the door, and walked up front to the engine. When I went back to get in the car, it was locked. I don't know why it did it, but it locked me out of the car with it running during its first startup. Not a good feeling. Luckily the temp stayed fine and no issues. I had the window cracked a bit and was able to stick a broom handle in and hit the unlock button. I'm worried it may do this again. Hopefully it was just a fluke due to the battery being unhooked for a bit. Anyway, here's the initial startup and then one after the engine warmed up a bit. Open headers in the vids. Please excuse the mess in the shop.
http://i28.photobucket.com/albums/c2...S/6e380404.mp4
http://i28.photobucket.com/albums/c2...S/c7270f21.mp4
Old 01-06-2012, 11:21 PM   #23
RED DEMON SS
OFF THE CHAIN
RED DEMON SS's Avatar
Drives: PSHHH UWISH
Looking real good, i sure hope you can chase down all those Gremlins!
Also post some videos with some sound?
Old 01-06-2012, 11:24 PM   #24
yotaman96
yotaman96's Avatar
Sound plays on mine.
Old 01-07-2012, 01:31 AM   #25
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Wow you have done a great job. This is amazing car.
IOM Black Diamond is offline   Reply With Quote
Old 01-07-2012, 03:45 AM   #26
Neffarious
Neffarious's Avatar
Drives: 2012 SS (2SS/RS, M6, IOM/Blk Rally)
I have my second key at hand every time I am screwing with battery stuff. I had an issue once with my GM truck out in the middle of the Arizona desert. I have never trusted electronic locks after that. To this day I will still crack a window if I am getting out while the key is in the ignition.
Sounds like a beast. Looking forward to more.
In your next picture post, DIY guide, or advertisement thread take a moment and think of the color blind guy. Thanks.
Neffarious is offline   Reply With Quote
Old 01-07-2012, 09:34 AM   #27
aquablueL99
Jackson's COTW
aquablueL99's Avatar
Drives: 1968 Camaro & 2010 Camaro 2SS
Cool
Unbelievable!! What a build...
aquablueL99 is offline   Reply With Quote
Old 01-07-2012, 09:36 AM   #28
LED Crazy
okcamaros.com
LED Crazy's Avatar
Drives: 2012 2SS/RS IOM L99
This is looking great!
LED Crazy is offline   Reply With Quote
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
