Old 07-23-2011, 12:19 AM   #1
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Might be a dumb question, SS tranny into V6?
Sorry if this is dumb, because Im dumb when it comes to trannys.
Could you in theory swap out a manual V6 tranny for a manual SS tranny?
Or would it be cheaper to take my V6 tranny to a good shop and get it built?
DarkneSS is offline   Reply With Quote
Old 07-23-2011, 01:20 AM   #2
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
The gear ratios in the SS trans are totally different than in teh V6 trans. Also an adapter plate for the bellhousing to mate to the engine would need to be made and depending on the length of the SS trans the driveshaft may or may not have to be altered in length... that's just a few of the issues with that swap
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 07-23-2011, 01:29 AM   #3
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Well, the taller ratios from the SS would kill performance, and 6th gear would basically be unusable, as that would leave you with a V6 with a .57 overdrive and a 3.27 rear end. The V6 simply doesn't have enough torque for the LS3's ratios.
Just curious, what are you planning that would require a stronger transmission?
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 07-23-2011, 01:31 AM   #4
VEESIKS
formerly 2011Camaro
I dont think he necessarily needs a stronger one, I think he just wants one that doesnt grind
Semper Fidelis
Old 07-23-2011, 01:34 AM   #5
fielderLS3
fielderLS3's Avatar
Grinds at the track power shifting, or all the time? Is the car stock now?
Old 07-23-2011, 08:33 AM   #6
DarkneSS
The ratios shouldnt be a problem as people have been swapping to SS gears on their V6 anyway.
Essentially I'd like to turbo the car early next year but I have absolutely no faith in this transmission. It grinds and I dont think it can handle any WHP beyond stock.
The tranny is the weak point on the v6 manual.
This too!
Bone stock car, grinds if I shift quick enough. If you check the thread in this section you will see that anyone that can shift fast has the same problem.
Old 07-24-2011, 07:34 PM   #7
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
On a stock car ours grinds from 1st to 2nd when you try to speed shift or shift in the 5k and up rpm range. Synchronizes cant take the punishment. I switched to a synthetic trans lube and can speed shift with no grind. Still don't do it too often though.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Any V6 with 300whp? FutureCamaroOwner Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 227 07-09-2011 10:32 PM
2010 Rear SS Emblem Alignment Hole Measurement Question Blue Demon 5th Gen Camaro SS LS LT General Discussions 11 02-23-2011 07:12 PM
v6 & SS Camaro Hoods?? NickelsBoy Cosmetics and Lighting Modification Discussions 26 06-09-2010 12:31 PM
Camaro V6 vs SS Insurance mjrebel Chevy Camaro vs... 30 04-26-2010 12:17 PM
Is the V6 auto tranny limited? Blade V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 03-06-2010 06:04 PM
