Old 07-28-2011, 11:18 AM   #29
572HP
ACE5 (Atlanta Group)
572HP's Avatar
Drives: "Black Ice"
Originally Posted by Chevrolet Customer Svc View Post
Unfortunately I don't have any information whether from my technical department or my other resources on whether or not tuning this system out would negatively affect the rest of the vehicle. I am also not sure why this feature is inculded with the vehicle. Also to answer another question that you have, AFM should deactivate if you put the vehicle into manual mode (either Sports mode or Tap-shift). Once you put the vehicle back into D mode the AFM system would then re-activate and act upon your vehicle normally. I hope that helps to answer some of your questions.
Jeff Morris, Chevrolet Customer Service
Thanks again for your help Jeff! I would be satisfied if AFM was disabled if you move the shifter down into manual mode (sports mode). However, this doesn't seem to be the case, at least for my car. Others have reported the same thing. Is there something that you can point us to that shows that this is suppose to be the case? When I show up to the dealer to get them to fix this, I don't want them to be able to say that it works as it is supposed to.
Thanks Jeff!
572HP is offline   Reply With Quote
Old 07-28-2011, 11:33 AM   #30
Mike's LazruSS
Drives: 2SS/RS, Black, CGM, Black int.
I was told by a member of the engineering team (someone who should know), at a trade show, that AFM definitely DOES work in both D & M modes. Whether it "kicks in" is dependant on the load on the engine (I believe he said it is fuel demand that does it). That is why you can sometimes avoid it by using paddles... but for sure in my car, sometimes it kicks in even if you use the paddles. You can kind of train yourself to drive around it, so to speak. But it's still a lousy system. I've also been told that it is sensitive to both temperature and altitude, but I can't verify that.
Mike's LazruSS is offline   Reply With Quote
Old 07-28-2011, 12:14 PM   #31
jtzako
Drives: 2010 IBM Camaro SS
I can attest that AFM will kick in if I'm in 6th gear in Tap-Shift mode if my speed isnt too high. (i.e. 50-60 mph)
I never felt it kick in on lower gears but I'm not usually in them long enough so I may just not have hit the right variables.
AFM definitely kicks in in Sport mode (non-tap-shift) since that is what I drive in on a daily basis and it kicks in even under light acceleration sometimes. (very annoying)
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-28-2011, 12:21 PM   #32
Drives: GM Vehicles
The only information that I have to go one are the e-mails that I have that were sent between myself and our techincal department which I am not allowed to divulge. Also we have agents within the department that work solely with our different vehicles and this answer came from the person that works with the Camaro. If your dealership is unwilling to work with you on this subject I would suggest you ask them to speak with our technical department themselves. I hope that helps you.
Old 07-28-2011, 01:51 PM   #33
kbui
kbui's Avatar
Drives: 85 Vette, 07 Escalade ESV, 03 GMC,
Thanks for the info, Jeff. I will definitely talk to my service manager next week when I take the car in for a checkup.
ADM Performance installed and tuned: Maggie, Stainless Works Power LTs, ADM race cai, ADM ZL1 scoop
Whiteside Customs Super Street 2 Package w/ coilovers
BC Racing Coilovers and lowered, Whiteline Bushings & Swaybars
MBRP catback exhaust, ZL1 bumper conversion, Drake billet shifter, Hurst paddles, NLP rear spoiler, OEM GFX, Vis Racing hood, ASA GT5 wheels
kbui is offline   Reply With Quote
Old 07-28-2011, 05:43 PM   #34
Switchback700
Drives: 2010 2SS IBM L99
Thanks Jeff!
My car would always be off in tapshift mode but would be on in sport mode..... maybe GM can at least solve this inconsistency, even better would be the "off" in sport mode and tapshift.... stir it up Jeff, maybe we'll get something done. Thanks for the help.
Switchback700 is offline   Reply With Quote
Old 07-28-2011, 05:55 PM   #35
BlemsBumble
BlemsBumble's Avatar
Drives: '13 ZL1 #662; '10 SS; '99 SS
Excellent post. Been driving the car exclusively in S mode since I drove it off the lot. AFM does not 'deactivate' just by moving out of D. You can work around it using the 'paddles' but AFM is always there, waiting to bite you in the ass.
BlemsBumble is offline   Reply With Quote
Old 07-28-2011, 10:13 PM   #36
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
This is exactly the way I remember it... the lower gears are shorter and if I did keep it in these gears the RPMs were too high for DOD to activate
Originally Posted by godeepdown View Post
I'll try it. I know the difference between manual and sport. I know if I just use the paddles it kicks in. Never tried the 2-3-2 thing. I did buy an auto tho and don't want to have to mess with the paddles. Hard to shift in a corner the way they are set up too. I really would love a factory tune that would turn it off.
Each gear is different w/ the shifter in D or M... DOD can be tuned off or on for each gear independently in both modes (total of 12 settings). It is too bad this constitutes a tune, but I know a lot of dealers look the other way on this one but you better check first. Mine used to be active in 5th & 6th gear D only, off everywhere else.
You are correct.. excellent post...
Old 07-28-2011, 11:28 PM   #37
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
I wanted an automatic, but if I had been able to drive one before I ordered it, I would have known how terrible the AFM is and would have ordered the manual (even though I'm tired of driving sticks).
It's a crying shame that such a lousy system had to be incorporated into an otherwise superb muscle car. The only reason that two-ton resonator is on the L99 is to hide the AFM from unsuspecting drivers who think they bought a true performance machine. I would have gladly paid the extra money to cover the gas-guzzler tax.
Who buys a Camaro to bang around on four cylinders?! It's totally asinine.
Oh well. My AFM is long gone, along with my power train warranty. Good riddance!
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 07-28-2011, 11:32 PM   #38
kmcd
kmcd's Avatar
And another thing. The mere fact that so many people are willing to sacrifice their warranties to get rid of it should be a clear message to GM that AFM is not a crowd pleaser.
Old 07-29-2011, 12:32 AM   #39
melbourne_ls1
melbourne_ls1's Avatar
Drives: 2011 2SS Red Jewel Tintcoat Vert
Disabling AFM using paddle shifters
Wow, there has been a lot of discussion on the behavior of AFM on these cars.
I have owned two L99s, the first was a 2010 2SS coupe and now my 2011 2SS vert. Both have behaved the exact same regarding AFM.
AFM was only disabled when the transmission was in Sport or Manual mode "AND" I used the paddle shifters to manually "downshift" from 2nd gear or higher.
For both cars, when I would start out and shift from Park to Sport mode and then use the paddle shifter (while still stopped) to go to first, AFM would still kick in under low loads as I manually up-shifted to second gear, third gear, etc.
But as soon as I manually "downshifted" from second gear (or higher gear) using the paddle shifter, AFM was disabled and stayed disabled until I shifted back into drive "D" mode.
melbourne_ls1 is offline   Reply With Quote
Old 07-29-2011, 07:39 AM   #40
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
My 2010 L99 does go to 4 cylinders in M, but only when cruising in 6th gear.
Personally, AFM does not bother me. The noisey lifters are another matter. I hear that even 2011s have the tapping on start-up problem. (Why hasn't it been fixed yet?
Mine is intermittent and never lasts more than a second or two, so I have left it alone. But it's annoying.
I hope the LS1 auto either drops the4 AFM or gets better lifters. This will be the deciding factor for me on LS1 vs Shelby Mustang.
Rock-It Man is offline   Reply With Quote
Old 07-29-2011, 09:51 AM   #41
mlee
www.CamaroFest.org
mlee's Avatar
This definitely seems to be the consensus. Thanks for sharing.
...and KCMD you are dead on, the message about folks ELECTING to turn off DOD knowing they lose the factory warranty should ring clear. I'm sure the Warranty is worth more than the gas guzzler tax.
Old 07-29-2011, 10:38 AM   #42
CFD
Drives: 2SS/RS L99 BLACK
I'ts funny because AFM never bothered me that much but there may be an explanation for it. Although I never knew about the "magical" shift sequence of 2-3-2 and will probably never know,I always use tapshift and drive a bit aggressiveley so around town there are many times where I would shift to 3rd and then immediately downshift to second because of traffic. Because of the two perhaps I was deactivating the feature and /or driving outside of it's parameters unkowingly. Now that it has been disabled is when you realize the difference. As mentioned above surely between waranty work on the system, the added cost of the components to support the system and customer dissatisfaction the gas guzzler tax would be cheaper and more acceptable to most of us, I mean who the hell bought this car for gas mileage, if you did, you as well as GM should wake up and smell the rubber burning.
CFD is offline   Reply With Quote
Camaro5 invites you to say thanks to Camaro assemblers and tour the Martinrea plant! Hylton 5th Gen Camaro SS LS LT General Discussions 646 12-23-2009 04:41 PM
65 Camaro's to choose from. tony_c Camaro Price | Ordering | Tracking | Dealers Discussions 25 08-29-2009 04:25 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Active Fuel Management? MJA03 5th Gen Camaro SS LS LT General Discussions 41 01-09-2008 03:25 PM
