sjm autoprod
Old 07-24-2011, 05:06 PM   #1
steeleshark2
steeleshark2's Avatar
Answers To Your Gears and Cam Drive Ability Questions
I had a couple PMs today asking questions about my gears. I finally decided to make a video (low quality) but I hope this answers a lot of questions. I hope you don't get motion sickness!! Look at my sig for my mods.
Thanks to:
ApexSpeed for outstanding customer service with fast shipping on many of my mods including gears
Texas Speed for an outstanding cam and accessories
EFI Alchemy for install and tune
Old 07-24-2011, 05:12 PM   #2
steeleshark2
As you can tell from the video, gear noise is at a minimum with my mods. Worst is 81-84mph then is gone by 85mph. Very livable. People should notice less noise without the suspension mods that I have.
Old 07-24-2011, 08:34 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
Thanks for that video....
I actually wish I didn't see this kind of stuff because it only makes me want to go out and drop the money on gears and an cam.
Build Journal
Old 07-25-2011, 03:58 AM   #4
Milkman20
Milkman20's Avatar
Drives: Red 2010 Camaro 2SS L99
nice video! thanks for the post!
I just have a question, how did you hold that camera, shift and hold the wheel at the same time? your like an octopus. haha
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers
Exhaust Clip: http://youtu.be/c_quv8eoVNQ
Milkman20 is offline   Reply With Quote
Old 07-25-2011, 07:42 AM   #5
steeleshark2
Thats what she said!!
On a serious note, it was pretty difficult but doable. You are welcome!
Old 07-25-2011, 12:15 PM   #6
Smoky10
Drives: 2010 Camaro 2SS
Your car has much better driveability than mine. If my RPMs get below 1800 in any gear there is some slight bucking, and lower than that it gets worse.
Smoky10 is offline   Reply With Quote
Old 07-25-2011, 12:37 PM   #7
caverman
caverman's Avatar
I've heard that could be the tune that will make/break driveablilty as well.
Build Journal
Old 07-25-2011, 12:48 PM   #8
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
I am really happy with my Richmound 3.73 gears.. adds just a little bit more punch...
MARINE1991 is offline   Reply With Quote
Old 07-25-2011, 02:45 PM   #9
caverman
caverman's Avatar
With an A6 you wouldn't want to go any lower than the 3.73 based on the transmission's gearing. You went from a 3.26 to 3.73 which is a nice jump. On an M6 they come with 3.45 so going to 3.73 is not as big of a jump.
I've heard some say that 4.11 even on an M6 is a bit much. That's why it's nice to the Shark's video.
I'm going to do gears some day but I'm torn for the money. I'm afraid 4.11 might be a bit much and 3.73 not enough. I've heard there is a new 3.90 gear which might be a good compromise.
Build Journal
Old 07-25-2011, 04:48 PM   #10
Shu71
Drives: 2011 Camaro RS M6
3.45 to 4.11 in 6th gear increases rpms at 60 by 264 rpm and at 70 by 309 rpms and at 80 by 353 rpms. RPMS at cruise is only a small snapshot of the real change.
To give a clearer picture how this affects acceleration, say you shift (SS w/ M6) at 6200 rpms, the 3:45 mph gear changes would take place at:
1-2 51 mph
2-3 74 mph
3-4 107 mph
4-5 153 mph
on the 4:11 gears the mph at 6200 rpm shift points would be:
1-2 43 mph
2-3 62 mph
3-4 90 mph
4-5 129 mph
5-6 153 mph
So the rear gear change increases the number of gears needed to get through to the same speed and increases how quickly it will get through the gears and increase speed.
Shu71 is offline   Reply With Quote
Old 07-25-2011, 04:53 PM   #11
Shu71
The difference in the Tremec 6 (SS) versus the Aisin 6 (LS/LT): This is just to show the difference in transmission gear ratio's not as a one has a better ratio set than the other, just that they are very different and this has an effect on the total gear (through the rear dif) the car will have when swapping gears.
2011 Tremec TR6060 (M10)3/16/2010Type:Rear wheel drive, six-speed manual overdrive transmissionEngine range:LS3 426 hpMaximum engine torque: 420 lb-ft ( 569 Nm )Maximum gearbox torque:430 lb-ft ( 580 Nm )Gear ratios:M10First:3.010Second:2.070Third:1.430Fourth:1.000Fifth:0.840Sixth:0.570Reverse:3.280
2011 Aisin AY6 (MV5) 3/16/2010Type: Rear wheel drive, six-speed manual transmissionEngine range:2.8L - 3.6LMaximum engine torque:370 Nm (273 lb-ft)Maximum gearbox torque:370 Nm (273 lb-ft)Gear ratios: MV5First:4.48Second:2.58Third: 1.68Fourth:1.19Fifth:1.00Six:0.75Reverse:3.96
Old 07-25-2011, 05:04 PM   #12
Shu71
I just found the sticky with all this information I just posted, sorry, please feel free to delete for redundancy.
Old 07-25-2011, 05:47 PM   #13
steeleshark2
No problem with having the numbers. To the average person, I feel numbers do not mean much. That is why I did the driving video. People can really see how the gears change your shift points and rpms throughout the speed band. Even with the cam, the shifting will be the same except you will be able to use the gears below 1500rpm.
Old 07-27-2011, 03:51 PM   #14
Tshepp
Show & Go
Tshepp's Avatar
Drives: '10 Camaro 1SS LS3
Still thinking about this...I really dont think highway driving will bother me too much. I just want the launch off the line as I usually only city drive my car...
Sold: Blk/Blk 2010 SS M6 - Speed Inc SI5V2 Cam & Tune, TSP Underdrive balancer, XS Power LTs, XS 3" Exhaust, Roto-Fab Intake, BMR 1" Drop Springs, and more. Only 5600 miles!
Tshepp is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 290 02-10-2018 10:11 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
My Camaro went home to Oshawa to die...... Huggerorange73 5th Gen Camaro SS LS LT General Discussions 753 08-30-2011 03:40 PM
More cam questions 1977and2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 06-21-2011 12:03 AM
