Old 12-14-2011, 05:47 PM   #29
Albertog
Albertog's Avatar
Drives: 2011/ 2SS/RS
"CruznSS:With the A6 you need to put in gear when refilling"" ---> What does this mean? Sorry, can someone provide more details for this procedure? Thanks, Albertog
Albertog is offline   Reply With Quote
Old 12-14-2011, 08:50 PM   #30
jpizzle007
jpizzle007's Avatar
Drives: '10 LS3, '11 328i, '78 El Camino
Originally Posted by bannonm View Post
For those that used Royal Purple, any need to use a friction modifier? According to their website it doesn't appear you need to.
Negative. Grip it and rip it. You will notice a difference. RP fluid throughout for me (motor, tranny and diff)
Custom stainless steel catch-can, Halltech Yellow Jacket CAI, T-304 MBRP 3" CB, Solo HiFlow Cats, TSW Interlagos Matte Black, Nitto Invos 275/315, SkipShift Eliminator, MGW ShortThrow Shifter, Flux Capacitor - fully tweeked
jpizzle007 is offline   Reply With Quote
Old 08-23-2012, 12:45 PM   #31
JeSSter
Drives: 2011 RS/SS Cyber Gray Metallic
Why is everyone changing the fluid so early? Just clicked over 56K on my 2SS/RS this morning. Still has factory fluid in it. Wasn't planning on changing till 100K (which I have done on all my other vehicles). My F150 is just about ready for its third change (290K).
JeSSter is offline   Reply With Quote
Old 08-24-2012, 08:59 PM   #32
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Peace of mind. I hit 30k before I decided to change my Diff fluid. It's only 14 dollars for the fluid and pump, and takes about 15 minutes. Nothing that I would regret doing, especially when I saw what came out of the diff.
LS3 SS is offline   Reply With Quote
Old 08-27-2012, 07:14 AM   #33
Forza
Drives: 2010 Camaro 2LT/RS CGM
Once I get something in my head I "have to do it". It won't hurt either way.
Forza is offline   Reply With Quote
Old 08-27-2012, 08:19 PM   #34
LS3 SS
LS3 SS's Avatar
I would advise anyone using RP 75-90 to get a friction modifier with it when you go to buy. My rear end is howling now.
Old 09-06-2012, 01:18 AM   #35
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
x2 i put in royal purple and the sound got worse... went to the dealer with the TSB to replace the seals and so far 1 week and noise free
BronxxBombers213 is offline   Reply With Quote
Old 09-15-2012, 01:40 PM   #36
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
Quick tip I used today. If you can't maneuver the gear oil bottle enough to drain it completely to fill the diff, transfer a few ounces at a time from the gear oil bottle into the empty, smaller GM friction reducer bottle. Use the smaller bottle to then put the last few ounces into the diff until the diff is full. Took me about 3 times to fill up the small bottle and then squeeze it into the diff - but the diff is now full.
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
Old 11-27-2012, 11:43 AM   #37
Stalkker66
Stalkker66's Avatar
Drives: 2012 Imperial Blue Metallic
Same here. I got a new diff installed and used royal purple. I felt the plates grabbing alot and it howles also so i added additive and its better but not gone. I am going to change for mobile 1 synthetic and additive cause thats what i used in my old rear diff and it ran fine. i like RP but not the gear oil "with additive".
Stalkker66 is offline   Reply With Quote
Old 11-27-2012, 10:08 PM   #38
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
The Mobil 1 I found in 75W-90 has "LS" on the bottle, so I only used a smidgen of additive. I can hear the rear end during a tight turn in a parking lot, but nothing during street driving. It grabs the clutch plates in the diff pretty well (M6 manual V-6).
My fluid had a lot of break-in debris both in the fluid and on the drain plug at 1200 miles. I changed it "hot." That's how I change all lubricants, as they are holding more debris than when they are cold. Just be aware they are coming out hot and you'll be fine.
Good advice to remove the fill (top) plug before removing the drain (bottom) plug. I had a manual transmissioned SUV that I found out the hard way it is difficult to fill from the drain plug when the fill plug wouldn't come out.
I tend to follow the manual on this service. It says to change the fluid far more frequently when the car is tracked (mine isn't; I just treat the freeway entrance ramps like a strip). You'll be amazed at what ends up on that magnetic drain plug.
Another "lift" method is a simple couple of pieces of lumber. Amazing what a few 2"x8" pieces of left-over wood can do for your clearance when you drive up on them. Stagger them so you drive both rear wheels up on a pair, then another pair and suddenly you have an extra 3" under the car. (2"x whatever lumber is 1 1/2" thick)
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 12-06-2012, 07:23 PM   #39
Les7311
Les7311's Avatar
Drives: 45th Anniv, 2SS, LS3, '07 M109
Send a message via Yahoo to Les7311
Subscribed.......
Les7311 is offline   Reply With Quote
Old 12-09-2012, 07:48 PM   #40
Les7311
Les7311's Avatar
Change fluid @ 6500 miles, fluid was dirty, funkeee with lots of shavings on magnet.
Hard to reach plug to refill, so used a 3 ft tube laying around garage, then made hole into jug cork that fits snugly for the tube. Extend tube and container outside of wheel (look like a IV bag).....then let gravity take over. took about 30 minutes....
Old 12-10-2012, 07:16 PM   #41
LS3 SS
LS3 SS's Avatar
What Gear oil did you go with?
Old 12-10-2012, 10:15 PM   #42
Les7311
Les7311's Avatar
Red Line 75W90....little over 1 quart @ $14
Differential Fluid JackRabitSlims Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 07-14-2011 09:25 AM
Differential fluid on paint TC Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 3 05-05-2011 10:36 AM
L99 Click click click at the rear axle differential gear housing Goliath Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 01-12-2011 10:16 PM
changing tranny and rear end fluid on a m6 ls3 what all is needed? and what fluids? Jferrell88 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 05-18-2010 06:13 PM
Rear Differential fluid Mobil 1 or Royal Purple, and motor oil discussion. 2010 Bumblebee V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 52 05-08-2010 05:34 PM
