Solo Performance
Old 05-19-2011, 05:16 PM   #29
Papa T
Papa T's Avatar
Drives: 2011 2LT RJT, 6A, 19" polished
Originally Posted by JKBUMBLEBEE View Post
why would anyone be in 6th gear going 45-50mph?????
Automatic " it seems that the tranny shifts into 6th " it is what gear the programing puts it in. ( I would not think 6th at 45)
Hmmm just thought of a test:
  • drive at 45 - 50 MPH note vibration.
  • Tap down see what gear it puts you in
  • if it goes to 5, you were in 6th
  • if it goes to 4, you were in 5th
  • that should at least tell you what gear you were in when you felt the vibration??
Papa T is offline   Reply With Quote
Old 07-29-2011, 12:04 AM   #30
Nate76
Nate76's Avatar
Drives: 2013 silver 2SS RS
V6 vibrations at low rpm's (30-40 mph)
My auto v6 has an engine vibration when driving at low Rpms usually around the 1100-1200 mark. It's like it's in too low of a gear. Almost like the engine is lugging. It will disappear when I give it enough gas. Was following the thread on this site regarding this issue with others who were having the same problem but can no longer find it?? Any help would be appreciated.
Nate76 is offline   Reply With Quote
Old 07-29-2011, 10:48 AM   #31
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
Looks like it was deleted..I can't find it either (and I made a post in it and does not show in my posts list)
.....along with the related flaming "I traded for a Corolla thread"
f5journal is offline   Reply With Quote
Old 07-29-2011, 08:20 PM   #32
NicketT
Drives: 2011 Chevrolet Camaro
I have a 2011 Camaro and I am having the same problem. The did have a forum on this 2 days ago and from what I can see it was deleted. I brought my camaro back to the dealer for this problem and they stated that the driveshaft was out of balance and changed it... did not fix the problem. The dealer stated that GM was showing that their were some complaints on this issue, but because their wasn't enough complaints that they weren't going to do anything about it. I did not pay $30,000 for a car to vibrate like it does....
NicketT is offline   Reply With Quote
Old 08-02-2011, 03:39 AM   #33
Siper
Hey! I am using WhatsApp.
Siper's Avatar
Drives: 1LT RS 2011
Same problem here with my automatic 2011 1LT.
Siper is offline   Reply With Quote
Old 08-02-2011, 10:17 PM   #34
texcraig
texcraig's Avatar
Drives: 2011 2LT RS White/Orng Strip
There have been several posts on this. Jeff Morris from Chev Cust Serv has been involved. It seems no dealer or cust serv has come up with any fix. Most agree with you that it is in too high of a gear. Like 6th when it should be 5th. When I use "S" or manual and keep it out of 6th I have no vibration, but when it hits 6th, same problem, vibration. I guess we have to live with it.
texcraig is offline   Reply With Quote
Old 08-03-2011, 11:59 AM   #35
TooCool5
TooCool5's Avatar
2011 has a 2.92 rear end gear to achieve 30 MPG EPA. May be too tall a gear.
2010 has a 3.27
Old 08-04-2011, 04:25 AM   #36
Camaro1*
Camaro1*'s Avatar
Drives: 2011Black Camaro 1 LT RS
I have same issue with my 2011 1LT RS. Dealer ran all camaros on lot and all did the same thing. I was told it is a exhaust issue at the lower rpms. I say its bs and we should not have to live with it.
Camaro1* is offline   Reply With Quote
Old 08-05-2011, 07:13 PM   #37
ncjillian
Drives: 2011 V6 LT1
SAME ISSUE!!
I just bought my 2011 V6 LT1 08/02/11
and it feels like the engine is stuttering around 35-45 mph I am taking it to service in the morning. Does anybody know what this is??? I just traded my 2005 Mustang and I know the transmissions are very different but I am having a hard time figureing out why this car is so shaky and not smooth, pulling off is the worse. I've driven a stick 10 years so I know how and when to shift. They better not give me any BS at Chevy service tommorrow. They tend to tell women BS.
ncjillian is offline   Reply With Quote
Old 08-05-2011, 07:17 PM   #38
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
hmmm, didn't know the gearing changed the following year...difference between auto & manual gearing ratios as well?
Old 08-05-2011, 07:28 PM   #39
Shu71
Drives: 2011 Camaro RS M6
The only gear change from 2010 to 2011 was in the 2LS that was added mid 2011. It has the higher 2.92:1 gearing.
All v6 cars manual or automatic are having the issue but at slightly different rpms. So I don't think it is the transmission. To me it feels like a tuning issue, maybe even the VVT or simply reversion due to the firing order and exhaust manifold design combined with the VVT. Everyone needs to complain to your dealership for a fix. It is quite annoying, at least with the manual trans I can shift around it and keep my rpms out of that range. For me it happens worst at 2200 rpms (30 to 35 mph in third gear trying to hold a steady speed). Anyone who has had a Trifecta tune care to comment if the studdering went away? Anyone with long tube headers still have the problem?
Shu71 is offline   Reply With Quote
Old 08-06-2011, 07:35 AM   #40
Nightfall
"To Punish And Enslave"
Nightfall's Avatar
Drives: B E RS GBA #72541 3564 CC 220 CI
So I Figured Out The V6 A6 Vibration Problum Jeff Read This Please
and everone else who has been complaining about the V6 A6 vibration at 45 mph ish ruffly around there
so last night i was driveing to work had it in D wanted to cruise to work then i noticed the vibration again from 43 to 45 so i did an exprement
i shifted from D to M cause i had a sneeky susption sence i drive so much in M and i hit the down shift button and BOOM i was driveing in 6th gear doing 45
now when i drive in M i normaly dont even touch 6th gear till i am at 50 the lowest or 55 on ave i cruise 45 to 55 in 5th gear so
i was right in D mode when the computer controls the shifting it shifts WAY to early into 6th and it causes heavy vibration so much so your rear veiw mirror rattles like a bass hit
my only guess for this problum is one of two things A it is programed to save you as much fuel as possible IE get to 6th as fast as possible i notice when your just cruiseing it shifts about 1,800 or below rpm as me in M i shift prefectly at 2,000 on ave or close to it
or B the computer codeing is screwed up and it feels it needs to shift into 6th so damn early eather way the computer should be recoded to shift at a higher speed then 45 it knocks it too low on the RPM and bogs to the point the car vibrates
my only way around this and the main reason i started to drive in M was to avoid this i knew something was worng i never guessed it was the computer shifting time programing ugh
anyhoo anyone else try this i got all shift points down from 1est to 6th IE 10mph shift to 2ed and so forth everone else try this tell me what you think
and Jeff hi if your reading this can you call your tech people asking them about changeing the codeing for the shift points? with out voiding anything to improve a more stable non vibrateing ride? is it possible?
thank you for your time Nightfall (i learn ever car i own to the T and all its flaws)
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession
90% canadian 10% mexican 100% american muscle :flag2:
Nightfall is offline   Reply With Quote
Old 08-06-2011, 08:50 AM   #41
TOMS1SS
Drives: NA
Interesting.
TOMS1SS is offline   Reply With Quote
Old 08-06-2011, 08:58 AM   #42
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
Originally Posted by TOMS1SS View Post
Interesting.
Looks like someone dumped a bike without wearing a helmet.
TheHorse13 is offline   Reply With Quote
vibration v6 low rpm lugging
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 606 01-19-2018 05:18 AM
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2790 08-22-2017 01:28 AM
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 11-14-2015 05:07 AM
V6 > 0-60 mph TIMES, what have others got ? 97one Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 137 03-11-2012 05:44 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
