BeckyD@RodgersChevrolet
Old 08-06-2011, 08:00 AM   #43
MiracleAces
MiracleAces's Avatar
Drives: 2011 Black Camaro 2SS/RS Coupe
That was a torture to read.
"Being persistant and never giving up may not always get the job done, but it just may annoy someone else enough to make it worth your while."
MiracleAces is offline   Reply With Quote
Old 08-06-2011, 08:02 AM   #44
coolman
Guest
I've read it twice ,and I'm still not sure what his conclusion was.
coolman is offline   Reply With Quote
Old 08-06-2011, 08:14 AM   #45
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
That the vibration is caused by the A6 getting to the final gear way to soon!!!! Thats what I am gathering!
csjcsj is offline   Reply With Quote
Old 08-06-2011, 08:19 AM   #46
coolman
Guest
Well, it could be that just the change in RPM is making the vibration change it's harmonics which in turn makes the vibration go away. To me it doesn't really prove that the cause of the vibration is from being in 6th gear too soon.
Old 08-06-2011, 08:28 AM   #47
BumbleBee5
BumbleBee5's Avatar
Drives: 2012 Jeep has replaced 2010 1SS/RS!
BumbleBee5 is offline   Reply With Quote
Old 08-06-2011, 08:29 AM   #48
dutchnrican
brevard
dutchnrican's Avatar
Drives: 2012 Black 2SS/RS M6.
lol.
dutchnrican is offline   Reply With Quote
Old 08-06-2011, 08:39 AM   #49
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: The BUFF
I couldn't understand you whatsoever.
Old 08-06-2011, 08:46 AM   #50
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
I think what he is saying is that it would be the same if you shifted to say 5th and cruised around town with a manual trans.
its a syn is offline   Reply With Quote
Old 08-06-2011, 08:48 AM   #51
ccrognlie
ccrognlie's Avatar
Drives: 2011 Camaro 1SS Black on Black
ccrognlie is offline   Reply With Quote
Old 08-06-2011, 09:04 AM   #52
Siper
Hey! I am using WhatsApp.
Siper's Avatar
Drives: 1LT RS 2011
It did get worse when I installed SLP Loudemouth II, but the sound worth it
Siper is offline   Reply With Quote
Old 08-06-2011, 09:20 AM   #53
Xello
Xello's Avatar
Drives: 2010 CGM 2SS/RS
Punctuation or GTFO!
Xello is offline   Reply With Quote
Old 08-06-2011, 09:27 AM   #54
builder11150
builder11150's Avatar
Drives: 1987 Trans Am
Grammar, spelling and punctuation are your friends.
builder11150 is offline   Reply With Quote
Old 08-06-2011, 09:36 AM   #55
Shu71
Drives: 2011 Camaro RS M6
Basically what he is saying is that the PCM is making the transmission shift to 6th gear at lower rpms than it should. However, I don't think it is this simple. The manual transmission cars have the same problem. I can make mine do it at 2000 to 2200 rpms steady speed 30 to 35 mph in third gear. If I UP shift at that speed to 4th it drops rpms to 1700 or so and the vibtration goes away. I firmly believe this is a throttle position, MAP, timing and VVT tune issue. When you shift, either up or down, you force the engine to a different point on the tune table and thus it stops vibrating like my old Harley. Since both manuals and autos are having this problem, it isn't a torque converter shake issue either. The only other thing which could be causing it is exhaust reversion which would cause the AFR to jump all over the place when exhaust gases are reverting back up through exhaust valves, then intake valves and thus messing up in incoming intake charge. This is why I asked in antoher thread on this if anyone with long tube header (would change reversion timing or eliminate it) or anyone with a Trifecta tune is having the issue.
Shu71 is offline   Reply With Quote
Old 08-06-2011, 09:49 AM   #56
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
My Camaro V6 Automatic also vibrates while driving at 37 - 47 mph at 1100 rpms. The automatic is set to shift to 6th gear once you hit a certain speed. For me I think its around 37 MPH. If I lift my foot or if I accelerate the vibration goes away temporarly. Now if you put the car in "M" (Manual Mode) then depress one of the shifter buttons on the steering wheel to have the car enter paddle shift. You can avoid the vibration all togather because who in the correct mind would be in 6th gear while driving at 37 mph. I really think Chevrolet should do something about that shift point. Perhaps keep it in 5th gear until say 50 mph or X rpm.
Ir0nM4n is offline   Reply With Quote
vibration v6 low rpm lugging
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2790 08-22-2017 12:28 AM
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 603 12-02-2016 11:03 PM
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 11-14-2015 04:07 AM
V6 > 0-60 mph TIMES, what have others got ? 97one Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 137 03-11-2012 04:44 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
