Old 07-29-2011, 07:59 AM   #1
carls2010
carls2010's Avatar
Drives: 2010 SS
V6 MANUAL FLUID ?????
I SAW WHERE A PERSON WAS RUNNING RED LINE MTL FLUID IN HIS VEH, -BUT GM CALLS FOR A GL 5 FLUID.--I currently have red line that is 75-90 GL5.Snth--- So do you think i be better off with the GL4 APPROVED FLUID OR KEEP the redline GL5 i just put in in it. ?? -I saw no diff with my shift aFTER adding new redline 75-90 GL5 Syn.---Im a v6 manuall.---Veh has 4,000 mile on it and has intermit gear clash [slight],----------,[ sorry for the cap's ] -- Also Would love to get rid off all the noise this trans makes going into gears [not gear clash]
carls2010 is offline   Reply With Quote
Old 07-29-2011, 12:36 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I've never been a big fan of Redline, but alot of people are. Many on this site swear by Royal Purple, but the slipperyest stuff I've ever seen is a brand called Motul (Motul 400 i think, GL-5, 75/90 full syn for manual trans) but like you, I saw only minimal improvement over stock.
I think we just need a new transmission!
Old 07-29-2011, 11:01 PM   #3
SUV2008
Drives: 2010 Camaro 1LT RS
Mine got better after Royal Purple Gear Max. I put it in the tranny and rear diff. Tranny still not perfect, but better.
SUV2008 is offline   Reply With Quote
Old 08-01-2011, 09:08 AM   #4
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
I am almost positive that the shifting issues are more due to the clutch not the transmission itself. I have issues putting my car into second gear at a stop light but if I hold it where it gets stuck while slowly releasing the clutch it falls in.
c_LoW29 is offline   Reply With Quote
Old 08-01-2011, 08:15 PM   #5
carls2010
carls2010's Avatar
Drives: 2010 SS
YES, I tried the red line 75-90 and saw no diff in my shift.--i just get just a slight gear clash,,- now and then from the AY6.--So i took that fluid out, and went with red line MTL 70 W 80.- This looks like trans fluid but is for trans's.-And it is syn, and a GL4 CLASS.-In which i saw the cadilac used, that a few years back.- Ive only driven car 20 miles prior to posting this - and WOW SMOOTH SHIFT,,And it cut down on the noise level of actually putting in gear. Ill keep you posted
Old 08-02-2011, 08:16 PM   #6
carls2010
carls2010's Avatar
Drives: 2010 SS
yes after doing talks with trans guys who have rebuilt these and other GM manual trans, --it comes down to the AY6 needs transaxle fluid, NOT GEAR OIL !!!! - AND ALL THREE SAID SAME THING right off the bat when i told the gear clash going into gear,,, get the gear oil out and add, synthetic trans axle fluid ,,example would be RED LINE MTX.-- It LOOKS LIKE automatic fluid but is not.---Mine is getting smoother by the miles just like trans guy said it would. ----P.S. --- WHEN GM ADDED THIS TRANS to the cadilac it orig used this type oil -GL4 RATED.- Wonder why they changed
Old 08-02-2011, 08:21 PM   #7
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
I would be careful changing to any fluid not GM approved. It could be a basis for warranty denial on your tranny..
The Bird is the word!
Old 08-02-2011, 08:30 PM   #8
xpanda305x
Banned
Drives: Dark Knight
flush it and switch back? lmfao
so where is the part number?
xpanda305x is offline   Reply With Quote
Old 08-02-2011, 08:46 PM   #9
Angrybird 12
In the owners manual
Old 08-02-2011, 08:48 PM   #10
carls2010
carls2010's Avatar
Drives: 2010 SS
the red line # i used is 50204.--AND if anyone still complains about a gear clash at all or hard going into most gears ? oh well then, keep your rear end fluid in there.- P.S. - I work at a chrysler dealer and we had had issues over the years of same thing with manual trans that orig had a rear end gear oil in them.-Now they run on tranaxle fluid like i posted .-mmmmmmmmmmm
Old 08-02-2011, 10:53 PM   #11
Mach
Mach's Avatar
Drives: White M6 1LT RS
You might be on to something there!
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 08-03-2011, 04:09 PM   #12
Ventmaster
Ventmaster's Avatar
Carl, this could be a very expensive experiment!
But you've got me thinking....I'd try about anything to improve the trans-
it ruins my enjoyment of the rest of the car.
I thought the shifter was the problem, turns out the stock shifter was just
a very good disguiser of the real problem: the synchro's or maybe the whole transmission.
Old 08-03-2011, 05:11 PM   #13
carls2010
carls2010's Avatar
Drives: 2010 SS
yea, but is a hell of alot better.--- wonder why when gm orig used it on the cadilac it called for a gl4 rated fluid not the gl5 ,,mmmmmm- Also i just put complaint in to the NHTSA, AND hoping others will ,---enough of our whinning ,,and posting issues,-- lets do something.-- gotta call gm now.-- number in owner manul --- P.S. I think the v8 manul trans guys run the tranaxle type fluid [stock] that looks like tran fluid
Old 08-04-2011, 11:36 AM   #14
c_LoW29
ill wait for a few more people to try this i must have spent $200 in gear oil changes
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 10:10 AM
DIY Transmission Fluid change V6 Rob191288 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 35 05-25-2016 06:52 PM
V6 manual tranny fluid & the 1-2 shift gahammerle Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 04-15-2011 09:07 AM
For Sale: Stock V6 CAI, Stock and Injen Windshield Washer Fluid kit cody.freeman1 V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 2 04-12-2011 09:47 PM
For Sale: Stock V6 CAI, Stock and Injen Windshield Washer Fluid kit cody.freeman1 Exterior Parts & Accessories 0 04-12-2011 03:56 PM
