| Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions |
Thread Tools |
#251 | |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
It is the right switch.
#252 |
![]() Drives: 2010 SS Camaro Join Date: Mar 2010
hey guys i have a question. i was working on the changing the leds on the gauge cluster had them all put in but when i went to plug it in to see if they worked, i accidentally put the plug in the wrong way and i heard something popped and saw burns along with smoke appear on the board were it plugs in. does this mean the whole board is shot and i have to get a new one?
-jake |
#253 | |
![]() Drives: 2010 RJT 2SS/RS Join Date: May 2012
#254 |
Creektrack:
I have everything apart right now, can you give me a list of the tools I would need to remove the old and put in the new LEDs on the gauge cluster please |
#255 |
![]() Drives: 2012 2SS/RS 05 Jag S type R Join Date: Aug 2011
I can't speak for creektrack, but I did this a few months ago. As he said a good silver bearing solder. You will also need some tweezers to hold the LEDs, a good magnifying hood and most important a good temperature controlled soldering iron. The LEDs are very small and easily melted with too much heat. The soldering iron should have a flat tip to evenly apply heat. So far I have done my guage cluster including the DIC, the radio and the four gauge cluster to white. It turned out really well although I have to take them back apart to redo a couple of the LEDs that went dark.
I did a lot of research finding the proper LEDs. I was not happy paying the cost for prepackaged sets, so I found the specs and bought them in bulk. I paid less than 20 dollars per 100. Price varied a little depending on color and size of the LED. I bought mostly white so price was low for those, and the red was just a little bit more. If you do your homework you can get what you want and save a lot. To me there is a lot more satisfaction doing all this myself. Well worth the effort.
There's more to life than gas mileage
Whipple, Custom Comp Cam, springs, pushrods, timing set, Cold Air Induction, cold air scoop, Doug Thorley tri-why headers, Billet Custom Products baffled Valve covers, RX Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Cora cat back, Hannity remote tuned, all parts user installed. No Dyno yet. |
#256 | |
#257 |
![]() Drives: N/A Join Date: Jul 2011
#258 | |
Sent from my SPH-D710 using Tapatalk 2 |
#259 | |
#260 |
Thank you, just I don't know what desolder braid is or does could you or someone explain?
#261 |
#262 |
![]() ![]() ![]() ![]() Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD Join Date: Mar 2011
solder wick;
http://www.google.com/search?source=...w=1658&bih=952 solder sucker works too, i have one, wick works better in some instances. http://www.google.com/search?source=...w=1658&bih=952 |
#263 |
Thanks guys Gunna try and not mess this up too bad
#264 |
find an old circuit board out of something (old microwave, vcr, mustang) and practice desoldering and soldering.
it helps to get a feel for how long to leave the heat applied and how the solder moves around to follow the heat. |
#265 |
#266 | |
#267 |
same concept, but circuit boards are way less forgiving if you add too much heat.
you can delaminate multi layer boards, lift runs and cause all sorts of issues. i have been soldering circuit boards for 26 years, still can be tricky at times. good luck, have fun, be safe. |
#268 |
I got a question, what if I use a flame to heat up tweasers then use them to pull off the LEDs on the board already? Will that work?
#269 |
it may, but the tweezers don't have capacity to hold heat (no mass) and will cool quickly when trying to remove LEDs.
try it on a scrap circuit board??? |
#270 |
I don't have anything to test on :(
#271 |
#272 | |
Thanks for the advice everyone, now only if I could decide on a color scheme
#273 |
Finally gunna start this mod, I'm gunna start with my gauge cluster, do I need to take the needles off to get to the board to change the LEDs?
#274 |
![]() ![]() ![]() Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
Yes you will have to. I used two teaspoons with blue masking tape on the bottom of the spoons. Just be care full the needle may pop off fast and land some where it should not.
Caddy |
#275 |
So I can just pry it off? I seen in a different thread guys were having trouble with that, just wanna make sure before I snap something
| Thread Tools | |
| Change the Gauge Cluster Color??? | rharon | Camaro DIY & HOW-TO instructions & discussions | 25 | 02-14-2012 04:28 PM |
| NON RS RED HALOS LEDS AND MORE DIY PROJECT !!! | 1969to2010 | Camaro DIY & HOW-TO instructions & discussions | 14 | 02-21-2011 01:56 PM |
| DIY: ABL Color Change | Tecca | Camaro DIY & HOW-TO instructions & discussions | 20 | 05-18-2010 06:50 PM |
| Dealer-Oil change or DIY? | wlvrine | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 32 | 06-23-2009 09:45 PM |
| Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over | bigralph | Off-topic Discussions | 15 | 02-06-2009 07:07 PM |
