Cold Air Inductions
Old 10-28-2011, 12:25 AM   #85
anglwngss
Lone Star Camaro
anglwngss's Avatar
Drives: 2011 Synergy Green 2SS/RS
Hmm. That's wacky.. That's where we buy from too.
anglwngss is offline   Reply With Quote
Old 10-28-2011, 06:11 AM   #86
572HP
ACE5 (Atlanta Group)
572HP's Avatar
Drives: "Black Ice"
Originally Posted by anglwngss View Post
Where did you get your LEDs for the 4 gauge? My hubby tried to use white LEDs for his, but burned up a chip. He's going with red instead. :(
I like everything, all looks nice
I also used plcc2. Required 8 for the cluster. I have the headlight switch completed too. I believe this used 6 of the 0805 chips. I took apart the automatic shifter, and it uses a single 5mm LED. I'll have to order a white one. Still have the overhead console (I'm going to do a homelink fiber optic upgrade when I do). Also still have the steering wheel, the door switches, the HUD switches, and of course the radio. All switches will be white. I did put red in the traction control switch. I think I'll leave it though.
Angel, do you have a link to a good radio removal guide?
Those 0805 chips are fairly difficult to work with. I can't imagine working with anything smaller!
572HP is offline   Reply With Quote
Old 10-28-2011, 06:52 AM   #87
572HP
572HP's Avatar
Drives: "Black Ice"
Angel,
Do you have an LED size/count for the radio yet? If so, could you please post. Need to make sure I have enough before I pull the radio.
Old 10-28-2011, 06:54 AM   #88
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
This is an awesome thread. Does all of this stuff require soldering because I am not to good at doing it?
c_LoW29 is offline   Reply With Quote
Old 10-28-2011, 07:37 AM   #89
creektrack
Drives: N/A
Originally Posted by 572HP View Post
Angel,
I hope she doesn't mind, but here are the 2 pics she sent me of the radio...The single leds inside the knobs were pretty tricky, and make sure to use 0805s cuz the 1206s are just a tad too big....
Yes, everything that involves the plcc2 or the 1206/0805 leds need to be soldered, but i believe the 5mm leds do not...
Sent from my PG86100 using Tapatalk
creektrack is offline   Reply With Quote
Old 10-28-2011, 09:45 AM   #90
anglwngss
Lone Star Camaro
anglwngss's Avatar
I haven't made a DIY on the radio yet, but it should be done within the week. Do you see in the first pic that Creektrack posted? on the right where the a/c knob is located, there are 4 LEDs that go in a semi circle just above the knob? In the picture, they alternate between a green circle, white x, green circle, white x..
Well, I discovered, the LEDs share the hash marks. See pic... I wanted to keep the blue and red circle, but couldn't the way the board is designed. There are only 4 LEDs behind the knob, yet they light up 3 hash marks, 2 circles and a snowflake..
Old 10-28-2011, 02:20 PM   #91
572HP
572HP's Avatar
Drives: "Black Ice"
So is this approx 35 0805s and 16 plcc2s placed on end for the radio? Going to need more LEDs so I'd like to get an idea of what is needed.
Old 10-28-2011, 03:13 PM   #92
anglwngss
Lone Star Camaro
anglwngss's Avatar
If you change exactly what I changed, that'd be right. When I sent it back to Creektrack the second time, instead of having green, blue, green, blue LEDs for the right side A/C knob, I changed it to blue, green, green, blue, but it's still the same number of LEDs.
I didn't change the ones in the knobs that light up the rings around the a/c and volume control knobs, but it could be done. I also did not change the LED for the hazard lights and the 2 amber LEDs for the front and rear defroster buttons.
Old 10-28-2011, 08:01 PM   #93
CaryE1
CaryE1's Avatar
Drives: Black 2011 2LT
Oh, you are going to hate the doors and other controls, then. Some of them are TINY!!!
CaryE1 is offline   Reply With Quote
Old 10-28-2011, 09:02 PM   #94
572HP
572HP's Avatar
Drives: "Black Ice"
As long as they are 0805 I'm good. I'm actually starting to get pretty good at them.
Here are two more inventory items:
HUD switch: (3) 0805
Convertible top switch: (1) PLCC2
I just finished the HUD switch and the convertible top button. The HUD switch is a royal PITA. It requires three 0805 LEDs. One of them is underneath the dial. What makes this difficult is that the dial has 3 plastic tabs that sticks through the circuit board and were heated and pressed down to mushroom the plastic. What I did to get it off, was heat up a pair of needle nose pliers and then squeezed the mushroomed tabs back into shape. I did this several times and took my time to be sure I didn't ruin the tabs. Once this was finished, it came right off. I replaced the LED and put the tabs back through the circuit board, heated up a screwdriver tip, and mushroomed the tabs back down. I took my time just to be sure I didn't mess it up. Took me about an hour to do it.
Old 10-28-2011, 09:03 PM   #95
anglwngss
Lone Star Camaro
anglwngss's Avatar
That's a good idea. I just cut off the plastic tabs on the HUD switch then used 3 tiny screws to put it back on
Old 10-28-2011, 09:06 PM   #96
572HP
572HP's Avatar
Drives: "Black Ice"
I like that idea! That would have saved me a lot of time. You are FULL of good ideas! Thanks for starting this thread, and all of your exploratory work.
Old 10-28-2011, 09:40 PM   #97
anglwngss
Lone Star Camaro
anglwngss's Avatar
Are you changing the LEDs in the HUD too? not the switch, but what displays on the window?
I probably would have attempted melting the tabs on the switch, but I didn't think I'd be able to get them back through. The image in my mind had plastic melting and dripping all over the place.. Either method works though, which is always good!
Old 10-29-2011, 06:24 AM   #98
572HP
572HP's Avatar
Drives: "Black Ice"
Yes, it requires extensive soldering (not beginner stuff either). The alternative is to remove the parts and send to someone like creektrack. As much as I am enjoying doing this work myself, I don't think that I would enjoy doing it on someone else's parts as much.
Change the Gauge Cluster Color??? rharon Camaro DIY & HOW-TO instructions & discussions 25 02-14-2012 05:28 PM
NON RS RED HALOS LEDS AND MORE DIY PROJECT !!! 1969to2010 Camaro DIY & HOW-TO instructions & discussions 14 02-21-2011 02:56 PM
DIY: ABL Color Change Tecca Camaro DIY & HOW-TO instructions & discussions 20 05-18-2010 07:50 PM
Dealer-Oil change or DIY? wlvrine Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 32 06-23-2009 10:45 PM
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over bigralph Off-topic Discussions 15 02-06-2009 08:07 PM
