| 5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums. |
Thread Tools |
![]() Drives: 2010 Camaro 2SS/RS Join Date: Jul 2011
Hi guys,
first of all, thanks for being such a great site! I didnt introduce myself yet because I'm currently still putting mods on my car and pictures and stuff will follow later, but for now I got this wierd problem ... Info about my car: 2010 2SS model (automatic), it's supercharged (the magnacharger tvs 2300) with a complete Kooks exhaust system. Since I live in Europe (The Netherlands). I don't have on-star and since the car isn't sold over here I can't take it to the dealer. I have brought up the problem with a couple of companies, but so far they have no idea and they would be needing the car for a while and run some tests .. but before I give my car away and possibly loosing mucho cash I figured I ask here first. So here is the problem, I will try to be as clear as possible: It's parked at the store (drive TO the store went fine). I turn on the engine, it starts fine ... it works as normal, no weird noises or anything. I put it in reverse, I back out of my parking spot ... so now i'm in the middle of the street. I brake, put it in Drive and boom ... engine dies. I cannot restart it right away ... cars are coming and I'm blocking the road ... I stay calm. Put it back in Park, turn the ignition off and try again. After about a minute or so (little less) I got it to start again and I drove off. Next day. I'm parked at my parents house (the drive TO my parents house went fine). I want to go home so I step in, start the engine, put it in Reverse to back away from a close car. I brake, put it in Drive and I go forward. I have to make a turn so .. I drive a bit forward and put it in Reverse again to make a turn. Boom ... engine dies again. Couldn't restart for about 30 seconds. I try all over and finally it started again after a bit. This is making me very nervous because it doesnt give me any error msg or lights on the console, nothing at all. It's not fuel or anything, I always get my fuel at the same place. Maybe it's the pump? Maybe it's something electrical? Is it the gearbox? If anyone has any idea it would be great. I can take some ideas to the shop and maybe they can work from there before I loose my car for weeks and paying a lot of money w/o a solution. Thanks anyway! |
![]() ![]() Drives: 2000 Z28. 2010 1SS IMB. Join Date: Aug 2009
fuel pump???? it interesting that you cant restart it right away.
2000 Z28 = Beast
forged 383 ls6, to many mods to list Dyno= 453hp 430tq at the wheels best time= 12.6@110 in the July heat at 6000ft alt DA Corrected = 11.396@121.765 75 shot Giggle Gas = 12.2@118 2010 1SS/RS = Mysstique Whipple Supercharger Dyno= 618hp 555tq at the wheels IMB Silver Stripes VIN#44025 Born: 9/9/09 Delivered: 9/28/09 |
![]() Drives: 1992 Chevy K5 Blazer Join Date: Apr 2011
Sounds almost like a vapor lock in the fuel line, but in modern cars that wouldn't be my first suspect. That usually happened with the old metal fuel lines and usually only in hot weather. Since you have modded it, you might want to check to make sure that the fuel line is tight at all connections to make sure it can't suck air into the line. Next in my mind would be the fuel pump and the delivery system. Not that familiar with the vehicle's electronics, but there is probably a fuel pressure sensor. That sensor likely controls a relay switch which switches power to the fuel pump. When the sensor senses a drop in pressure, it should tell the relay to turn on and make the fuel pump run. Either the relay or the sensor could be culprits as well and would probably be cheaper than replacing the fuel pump. You'll have to spend some time diagnosing it.
Love beautiful photos? Please visit:
http://dougloganphotography.zenfolio.com |
Thanks for the replies guys. If anyone has any more ideas ... would be much appreciated!
Drives a Maro
I just went throught the SAME exact thing.
Mine was surging a bit at idle. Not too bad but enough to notice. and would die EXCATLY the way you describe. TVS2300 and all. Only difference is mine would start faster than that. Turned out to be a header gasket leak. I used the felt Borla gaskets. ![]() After that I agree with the fuel system. Check the gaskets frist though. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 Camaro SS Join Date: Dec 2009
The intial start up power to the fuel pump only lasts for 4-5 seconds and then if the ECM does not detect the proper fuel pressure it does not continue providing power to the pump. Each time the key is cycled it starts over and provides the intial power to the pump, etc. I supect there is an issue related to the pressure detected.
#7 |
Thanks PQ ... I'll make the guys check that first!
#8 |
Drives a Maro
It's a long shot for sure. But an easy fix.
| Tags |
| engine dies stalls |
| Thread Tools | |
| Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
| Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread | UCF w00t | Camaro Price | Ordering | Tracking | Dealers Discussions | 4242 | 09-19-2011 03:27 PM |
| Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
| Why i think you cant do a Dyno in the same day | 2SSRS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
| LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue | 13F20 | 5th Gen Camaro SS LS LT General Discussions | 15 | 09-22-2008 04:35 PM |
