R1 Concepts
Old 03-22-2009, 09:23 AM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
L99 and Hydra-Matic 6L80 Question?
When driving the automatic, can you drop the tranny to M while going down the road? Do you have to be at a stop to change the shifter to the manual tap shift mode, or can you change it and start shifting from the wheel on the fly?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 03-22-2009, 09:27 AM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
you can pop it into M while driving.
I piss excellence
and fart awesomeness
Old 03-22-2009, 09:37 AM   #3
ChevyBoiSS
ChevyBoiSS's Avatar
Drives: 2011 2SS/RS RJT
nice ? ive never thought about that be4.. good. i imagine it would be a little jerk or something.. or i hope the computer will just be smart enough to keep it in the same gear ur in and and allow the computer to assist you in shifting up or down.
Thinking bout Victory Red 1SS/RS with Matte Black Custom Stripes. Automatic Transmission (L99)
and apparently a $900 dollar whole in my roof.
OHH.. DID I MENTION 24" off THE GROUND?!
ChevyBoiSS is offline   Reply With Quote
Old 03-22-2009, 09:42 AM   #4
CamaroSpike23
Truth Enforcer
thats pretty much it exactly. when you pop it into M, it will just stay in the gear you are in until you tap the button to shift
I piss excellence
Old 03-22-2009, 09:43 AM   #5
edog
edog's Avatar
Thanks, I was hoping you could. If you needed to it would allow the down shift and aggressive thrust from the current speed. I bet that will be fun to play with.
Old 03-22-2009, 09:51 AM   #6
CamaroSpike23
Truth Enforcer
yup, unless you try do downshift while you are already near redline. it is programmed to keep itself from grenading.
I piss excellence
Old 03-22-2009, 09:54 AM   #7
Mr Twisty
Mr Twisty's Avatar
In manual mode, it's also supposed to be programmed so that it stays in the gear selected till you change it, within minimum and maximum rpms. Great for taking corners a bit too fast and not upsetting the car.
(The tremec is the standard btw)
-- Benjamin Franklin
