HURST
Old 08-02-2011, 04:36 PM   #1
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
A6 with 3.35 gears
Who has em and what big difference u feel, without a doubt will be upgrading just see what others have seen improve
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 08-02-2011, 04:48 PM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
3.35's?
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 08-02-2011, 05:27 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I am not aware of a 3.35 gear but swapping from the factory 3.27s to 3.35 would be pointless. We have found 3.73 to be an excellent option for a street driven A6 SS.
Here is a link to an article on our blog discussing the technical aspects of a gear swap in these cars. It has complete numbers on cruising RPMs and the torque gains to be had with each gear set.
Old 08-02-2011, 06:02 PM   #4
sasquash1984
502 RWHP N/A
Drives: The yeti
What is the oem gears in the ls3 camaro?, I think I meant 3.45
Old 08-02-2011, 06:22 PM   #5
Apex Motorsports
3.45 is stock in the M6 cars. If you can get an M6 pumpkin complete with gears that you can drop in then it could be a somewhat inexpensive way to gain a few percent torque advantage. If you are going to have to pay for an actual gear install it would not be enough of a gain to justify the expense though.
Old 08-02-2011, 06:28 PM   #6
grocerygetter
instigator
grocerygetter's Avatar
Apex said it...I heard the same, 3.73 on a A6.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 08-02-2011, 06:37 PM   #7
sasquash1984
502 RWHP N/A
Drives: The yeti
I got a place...
Old 08-02-2011, 08:32 PM   #8
ADM PERFORMANCE
Drives: 2016 CAMARO SS
I got a place...
They clearly dont do what I do EVERY DAY
If you want a few dozen phone numbers for ADM customers that have this mod....I can make this happen.
ADM PERFORMANCE is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
AAM 3.91 Gears...Very Nice StreetStrip V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 36 06-05-2017 08:44 AM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
