JUICEDMOTORSPORTS
Old 08-04-2011, 01:10 PM   #1
Heelhook22
Heelhook22's Avatar
Drives: 2010 Black SS
Lingenfelter Clutch return spring
My clutch is starting to sink down to the floor and is starting to act spongy, again. This will be the third time I have replaced the clutch under warranty.
After pumping the clutch and engaging it a few times, I can usually get it to work normally after a few minutes or so. Otherwise, the clutch seems to work fine.
I've been looking into Lingenfelters clutch return spring:
http://www.lingenfelter.com/mm5/merc...gory_Code=C366
I know some folks are separating reservoirs, keeping their fluid fresh, and changing to DOT 4 fluid, but has anyone had any success with the spring by itself?
Cheers,
Heelhook
Heelhook22 is offline   Reply With Quote
Old 08-04-2011, 10:00 PM   #2
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
I never had a clutch problem, and installed the return spring as some extra insurance.
It was super easy to install, and still no clutch issues.
stratman2SSRS is offline   Reply With Quote
Old 08-08-2011, 04:34 PM   #3
Chris@SPMC
Drives: '99 H/C FRC Corvette and '07 TBSS
Any mods? The spring is really a bandaid and if you've been through 3 stock clutches, I'd consider looking at a real clutch. Give me a call if you have any questions, thanks.
Chris@SPMC is offline   Reply With Quote
Old 08-10-2011, 02:10 PM   #4
Heelhook22
Heelhook22's Avatar
Only mods are CAI from CA Inductions and Flowmaster AMT cat back. I drive my car with a spirited foot every now and then but by no means would I call myself a "hard" driver.
Cheers,
Heelhook
Old 08-10-2011, 02:48 PM   #5
2quick
Drives: none
Sounds like there is a leak in the system.
2quick is offline   Reply With Quote
Old 08-10-2011, 04:12 PM   #6
600hp-lpe
Drives: 2010
I have the LPE clutch return spring.. It worked wonders on my clutch (dual disc Zr-1) that I thought I was going to have to replace in April after the pedal came up only halfway and I smoked the clutch really bad.
I am still on the same clutch, havn't changed the fluid since, and I race the car hard every chance I get. I have yet to smoke my clutch again, have the pedal stick on the floor, or halfway down, or have any issue since the return spring was added.
As far as I am concerned, it "fixed" whatever I have wrong with my Camaro's clutch system.
Well worth the price of $90.00, compared to possibly smoking additional $1800.00 clutch setups...
It would be, at the very least, cheap insurance for a clutch pedal that stuck to the floor. If it stayed on the floor during a race, you are done for the day - never mind the run.
600hp-lpe is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
Drag Suspension??? 10camaross Suspension / Brakes / Chassis 38 05-28-2011 09:54 AM
What exactly burns the clutch on an m6? DarkneSS 5th Gen Camaro SS LS LT General Discussions 49 04-15-2011 11:55 AM
-.5 lowering springs? BOOGIE Suspension / Brakes / Chassis 43 04-12-2011 11:51 PM
GM SUPER CHARGER COMMENTS camaro99 Canada 62 01-15-2011 06:27 PM
