Emblempros
Old 08-05-2011, 09:55 PM   #1
shines
Drives: 2010 Camaro SS/RS
Differential Advice Needed
I have a rebuilt differential with AAM 3.91 gears, the JRE posi mod, and the LPW cover. Before going to the drag strip this past weekend, the differential was perfectly silent. Now, though, there's a whine at 40+ MPH while under light load or coasting.
I only made 4 passes on street tires (Nitto NT05 315's), although I did power shift.
Should I live with the whine or spend another $500 to have the gears setup again?
shines is offline   Reply With Quote
Old 08-05-2011, 10:08 PM   #2
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
You might want to break open your pumpkin and take a look at the JRE spring... there is a bead on one gear that needs to be ground down smooth or it wears into the spring...
Old 08-05-2011, 10:14 PM   #3
shines
WOW! First I've heard of the JRE posi mod issue. Sounds like I get to rip it apart regardless
Thanks for the info.
Old 08-05-2011, 10:17 PM   #4
mlee
www.CamaroFest.org
mlee's Avatar
Yeah... we did about 5 of these back to back and had one spring get trashed and so had to pull the others and grind the bead off of a small gear. Our installer said he missed that step and that it wasn't super clear in the instructions, but it was in there.
Old 08-05-2011, 10:23 PM   #5
shines
I installed the JRE mod myself and I definitely didn't grind anything as part of the install.
Old 08-05-2011, 10:43 PM   #6
thundercat 1
Drives: 2010 camaro ss/rs
check your fluid.lpw covers are having issues with pushing fluid out the vent when driving faster than hiway speeds.i had to call jennetty to have him fax the missing page to the instructions for his posi mod.it was the page were you ground the spiders.
thundercat 1 is offline   Reply With Quote
Old 08-05-2011, 10:51 PM   #7
shines
I just saw the LPW oil leak thread and I do not see the grinding part of the JRE posi mod instructions. I bet my diff fluid is low and my gears overheated. What are these vendors trying to do to us?
Old 08-05-2011, 11:01 PM   #8
shines
After reading the LPW thread I'm convinced I ran low on fluid. It was 150 miles round trip to the track, I'm thinking it got really low on the way back an over heated the gears.
Old 08-06-2011, 01:54 AM   #9
mlee
www.CamaroFest.org
mlee's Avatar
I'd still check that spider gear... after a while it cuts a groove in the JRE spring... Glad you figured out the problem...
Old 08-06-2011, 04:56 PM   #10
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
I have always been advised to heat cycle several times using normal driving before puting the hammer down. Heat cycle from cold to hot to cold. Several times would be six or seven. Can only help and not hurt.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Advice needed please....look inside monstertodd Suspension / Brakes / Chassis 10 07-27-2011 02:52 PM
Metal Shavings In Differential Fluid - Yikes! Predator2U Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 03-12-2011 02:49 PM
Metra install - need installer advice / sanity check SS Drifter Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 08-24-2010 03:48 AM
SLP Advice needed intense1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-09-2010 07:57 PM
Need advice on a cold air intake system central99 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 07-22-2010 05:33 PM
