Rick@Livernois
Old 03-23-2009, 02:35 AM   #1
vega$
Dreaming Big!
vega$'s Avatar
Drives: 06 Silverado CC 4x4 5.3L
LT Headers question
I know this has been talked about around here before, but there were never clear answers. ( I've been coming here for questions for about a year just never registered til' now.)
If you had some LT headers on the SS, will you will be able to pass the OBD emissions testing? I live in las vegas and as far as my experience there isnt a visual inspection.
thanks for any feedback.
vega$ is offline   Reply With Quote
Old 03-23-2009, 05:23 AM   #2
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
as long as you get some high flow cats and keep all the o2 sensors hooked up you shouldn't have any codes, with lt headers you should also get a tune to go with them to really take advantage of them, so yes you will pass
Gentry78 is offline   Reply With Quote
Old 03-23-2009, 05:55 AM   #3
spd98
Drives: had a goat
You will have codes with long tubes. you will have to have them removed via tune. It may take a week or so to set a code but because of the temperature and flow difference through the cats the O2 numbers will not look the same as stock. The bottom line is that you will need a tune to get the most hp out of your lt's anyway so it's not a big deal.
BTW I actually speak from experience here I personally know of 4 GTO's that had this and 2 g8 gt's.
spd98 is offline   Reply With Quote
Old 03-23-2009, 06:13 AM   #4
Gentry78
HOOK'EM
Gentry78's Avatar
i've never done or seen lt's without a tune so i didn't know if they would set codes under a stock tune or not, so thanks for letting us know
Old 03-23-2009, 09:28 AM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
If there isn't a visual part .. you should be ok as long as you tune (or use eliminators) for any O2 issues ..
IMO (having had both long tubes and shorties) .. it isn't worth the hassel to go to long tubes unless you are going to be making gobs of power .... Shorties can support a lot of power as well and matted to some high flow cats, you don't need the extra parts to turn off the O2s or eliminators to fake those readings .. you stay emissions compliant.
Crowley
Crowley is offline   Reply With Quote
Old 03-23-2009, 09:42 AM   #6
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Just get a good tune, and go to a nice friendly shop for your tuning and inspection...You will be good to go.
Check out the group buy thread...I will be posting a good deal on Long Tubes in the next day or so!
ZZcamaro is offline   Reply With Quote
Old 03-23-2009, 12:05 PM   #7
Melson
Melson's Avatar
Drives: Wild Cherry
Crowley
Crowley,
Are yo going to have Classic put the shorties on??
Melson is offline   Reply With Quote
Old 03-23-2009, 01:02 PM   #8
spd98
Drives: had a goat
Another little FYI you cannot get any o2 sims now that work. Your only choice is a tune. And LT's will always make more power than shorty's.
Old 03-23-2009, 01:14 PM   #9
SS 376
SS 376's Avatar
Drives: IBM 1SS
In states that do visual inspection (like California), you will flunk visual but you can pass smog, provided you have cats.
SS 376 is offline   Reply With Quote
Old 03-23-2009, 02:52 PM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
You'll probably throw codes without a tune because of the 02s, like has already been stated. I had the problem with mid-lengths and LTs. It's possible to pass the sniffer so long as you have a good tune and the rest of the PCM's parameters have been met. I don't remember all of the PCM checks, but believe at least three have to have been checked and passed in order for the smog machine to "pass" the car after the sniffer test. I had problems with this in the past because of not driving the car enough after reflashing the PCM.
It may be best for you to consult a smog shop because they should know all the smog laws of your state. If you lived in a rubbish state like me, I'd tell you to not do anything to your car - actually, I'd tell you to walk...
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 03-23-2009, 02:55 PM   #11
ZZcamaro
You can always pass a visual if you go to the "right" place...wink wink
And a quality tune will pass the smog test no problem
Old 03-23-2009, 05:25 PM   #12
vega$
Dreaming Big!
vega$'s Avatar
Thanks for the feedback. Yeah no visual inspection at the smog check I go to.
Thats also what I figured, that I will get headers and a tune at the same time.
btw best mods to do in order?
headers and tune?
or
CAI and High Flow cat exhaust?
I was thinking of doin CAI and exhaust first..not right away but a few months after purchase.
Headers for the V6? Xanthos Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 49 08-04-2011 12:51 PM
Ready to place my order this week - One Question BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 9 01-21-2009 09:20 PM
Ordered mine! (question enclosed) L. James Camaro Price | Ordering | Tracking | Dealers Discussions 6 10-18-2008 10:41 AM
Noob Camaro Question goose7919 5th Gen Camaro SS LS LT General Discussions 13 09-23-2007 08:26 PM
Ported headers Casull Off-topic Discussions 4 03-23-2007 04:22 PM
