Old 03-23-2009, 03:35 AM   #1
dougmac
Drives: 2011 V6 MCA & 1969 GT Mustang
Will 17" wheels fit over the V6 brakes ??
A WINTER snow tire wheel package is mandatory for my car and 17's are much more reasonably priced.
I've seen other rotors in the 12.64" range fitting inside 17's, so I'm hoping this be the case with Chevy too !!
Sorry if this has been asked before, did a search but nothing came up.
Thanks,
Doug
dougmac is offline   Reply With Quote
Old 03-23-2009, 03:38 AM   #2
Tal
Drives: Old
Don't know, I like the idea of using GM's 18" steelies for snow tires myself.
Tal is offline   Reply With Quote
Old 03-23-2009, 07:30 AM   #3
dougmac
That's what I was thinking initially too ... they will most likely be available for pretty cheap as factory take-offs from somebody but then I realized they were 18's.
Just did a little research on DTD & TireRack and surprisingly there is more to choose from in a 225/60-18 size vs. a 225/65-17 ... both of which would give the proper dia. so not to screw up the speedo & odometer while giving a better width for running in snow, where wider is NOT better !!
225/60-18 size cost anywhere from $89 ("S" speed rated Firestone Winterforce) up to $205. Bridgstone Blizzak LM-25's (130 MPH "H" speed rated, minimum I'll put on my car) go for $149.00 each clearance @ TireRack.
225/65-17 size I could only find two ... Blizzak DM-23 "Q" speed rated @ $106 each or Pirelli Scorpion "T" speed rated for $111 each ... these are also both TRUCK tires !!
Doug
Old 03-23-2009, 01:08 PM   #4
dagolfguy
dagolfguy's Avatar
Drives: 2010 Camaro 2LT RS
If anyone finds out the "where" and the "how much" it will cost for steel winter wheels, please post!!!
Thanks.
dagolfguy is offline   Reply With Quote
Old 03-23-2009, 01:11 PM   #5
SS 376
SS 376's Avatar
Drives: IBM 1SS
Thanks,
Doug
Hopefully there will be people selling their stock 18"s and 20"s well before winter as they swap them for aftermarket wheels, so maybe you can get used stock wheels for a good price and then swap on some winter tires. Don't know if anyone makes 20" snow tires though.
SS 376 is offline   Reply With Quote
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 12:40 PM
possible to fit old style rally wheels on new camaro? RSPARKS5 Wheels and Tires Talk Sponsored by The Tire Rack 17 07-18-2011 11:09 AM
Lighter wheels = much faster? 1_2Many Wheels and Tires Talk Sponsored by The Tire Rack 41 01-30-2011 11:28 PM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 12:12 AM
