HeadlightArmor
Old 03-23-2009, 09:40 AM   #1
fireresq157
fireresq157's Avatar
Drives: 1997 SS & 2010 2SS/RS
Performance Numbers - Skip Shift
First I'd like to say I was pleased with the numbers coming out from these reviews because I know there only one way to go and that's better. I had some time to absorb all the info on performance numbers, and I had a revolution. Not sure this has been mentioned before but all these testers had Skip shift enabled or quite possibly automatics. For anybody that owned a fourth Gen Camaro, Firebird for that matter Vettes, Vipers etc we know what skip shift is. I'd be willing to go out on a limb and say the performance numbers would be allot better if that feature was disabled. like almost all of us have on our old cars with an 20 dollar adapter or do it yourself jobs from radio-shack. You would be able to go through the full range of RPMS on 2nd and 3rd gear rather than just straight to 4rth gear. Heck even the dyno numbers would improve, anybody else had some thought on this and when we could expect an actual review with this feature disabled.
fireresq157 is offline   Reply With Quote
Old 03-23-2009, 09:43 AM   #2
duder4thgen
Drives: Bird
Skip shift is only active in light throttle conditions. Not gonna have any bearing on a car's performance.
duder4thgen is offline   Reply With Quote
Old 03-23-2009, 09:44 AM   #3
Thwick
Drives: 2007 Cobalt SS/SC
I thought under moderate/heavy acceleration the skip shift wouldn't be enabled?
Thwick is offline   Reply With Quote
Old 03-23-2009, 09:48 AM   #4
fireresq157
Skip shift forced you to go from 1st to 4rth when you stomp on the gas, in light throttle conditions you would use all your gears. That's how it worked on mine before I disabled it.
Old 03-23-2009, 09:48 AM   #5
Gary B
Gary B's Avatar
Drives: Subaru
Dude, what are you talking about? Skip shift would have NO bearing on the performance tests. You sound like you're talking about some sort of limiter or something, which skip shift is not!
Time for a new ride soon....6th Gen or 5th Gen Z28? Hmmm....
Gary B is offline   Reply With Quote
Old 03-23-2009, 09:50 AM   #6
Gary B
Gary B's Avatar
Drives: Subaru
Your car is whacked if it did that. Skip shift worked ONLY under part throttle(under 2000 rpms)I think. Flooring the throttle would totally erase the feature.
Old 03-23-2009, 09:52 AM   #7
fdjizm
Drives: 2008 Mustang GT/CS
i think this man is about right...
fireresq157 your epiphany has failed.
fdjizm is offline   Reply With Quote
Old 03-23-2009, 09:55 AM   #8
fireresq157
I guess your right but that's how it seamed to work on mine, I was glad to disable it it was really annoying.
Old 03-23-2009, 09:57 AM   #9
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
^That doesn't make any sense at all. Why would the skip shift take effect if you were just cruising along? It's when you stomp the pedal that it kicks in. Think about it, 2000 rpm's in first and you shift to fourth?!? You would damn near stall. Redlined in first, shift to fourth and you're cruising again...
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 03-23-2009, 10:00 AM   #10
fireresq157
Thats how it worked on my waked car and thats how it makes sence it would save fuel anyhow I'll go hide in a corner now.
Old 03-23-2009, 10:02 AM   #11
Chevyrocker
Weekend Rockstar
don't worry about it dude...you're right, they're wrong...
You can come out of your corner now...
Old 03-23-2009, 10:10 AM   #12
BigRigMike
BigRigMike's Avatar
Drives: 2010 Ford Fusion
I had a 2001 SS skip shift is for light throttle. I believe it was effective up to 3000 RPM. And yes if you shifted on the low end of the limit the engine would bog. It is only supposed to be effective for the EPA tests and the EPA does not do full throttle runs.
http://camaroforums.com/forum/showthread.php?t=16943
Gear Select - Skip Shift (CAGS)
To ensure good fuel economy and compliance with federal economy standards, SECOND and THIRD gear are inhibited when shifting out of FIRST gear, under the following conditions:[*]Coolant temperature is above 50°C (122°F)[*]Vehicle speed is 20 - 29 km/h (12 - 19 mph)[*]Throttle is opened 35 percent or less
BigRigMike is offline   Reply With Quote
Old 03-23-2009, 10:17 AM   #13
Gary B
Gary B's Avatar
Drives: Subaru
Exactly BigRig....it was a stupid idea to incorporate this feature on ANY car, but they had to throw a bone to the EPA guys, so in the long run, it worked for them, but was a small inconvienence to us, being that most RARELY shifted at such a low rpm.
Old 03-23-2009, 10:18 AM   #14
Gary B
Gary B's Avatar
Drives: Subaru
Now you and your buddy there get back in the closet, or corner rather(LOL), you're both wrong.
Skip Shift? cam2fst4u 5th Gen Camaro SS LS LT General Discussions 65 04-03-2009 03:01 PM
Guess the Camaro performance numbers garagelogic 5th Gen Camaro SS LS LT General Discussions 45 01-07-2009 12:02 PM
Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white radz28 5th Gen Camaro SS LS LT General Discussions 23 12-22-2008 10:57 AM
5th gen performance numbers are in from the top Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2008 06:38 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
