BeckyD @ James Martin Chevy
Old 08-09-2011, 01:48 AM   #1
Carver1
Drives: 2011 1SS/RS LS3
No A/C 2400miles.
Well it happened! Just turned 2400 on my 11 SS and the A/C went hot this afternoon. I was in a drive through getting lunch and at idle, heard a minor belt squeal. I had the AC on low, so I turned it off and the noise went away. I turned it back on and just had hot air in all modes.
Dropped it off at the dealer and got an 09 Nissan 2 door Altima for a loaner.
Nice little car, just not my style.
Hopefully it is something simple. Maybe a switch? The squeal makes me think it is the compressor, but not too sure.
So far, the only issues I have had is the cold second gear grind, and the drivers power window switch doesn't engage sometimes. This is my first trip to the dealer though. Should know what's going on tomorrow afternoon. I miss my car already!
Carver1 is offline   Reply With Quote
Old 08-09-2011, 08:22 AM   #2
nealdiwes
Drives: 2011 camaro ls
Sure sounds like the compressor locked up. Hope not; good luck.
nealdiwes is offline   Reply With Quote
Old 08-09-2011, 12:12 PM   #3
dianeokie
Going places
dianeokie's Avatar
Check out this thread
http://www.camaro5.com/forums/showth...=153011&page=2
Mine did the SAME thing. It's in the shop right now, have a rental from the dealership. They said they know what it to do now, they missed a second step from a second bulletin....here's hoping....
Old 08-12-2011, 03:08 PM   #4
dianeokie
Going places
dianeokie's Avatar
Good news........AC is fixed, I think!
This is what the service slip says as the repair:
Clutch shaft is broken (AC clutch shaft re compressor). PIC 5294B requires the compressor replacement along with the dryer and system flushing. Also, the body control module softwear needs to be updated, recore the system (1.3lbs) printed. Replace the compressor. Compressor has 2.5 oz oil that did not need balancing. Remove the condenser to remove the dryer. Flush the entire system and dry for 30 min add necessary seals and install new dryer. Add oil to condenser and evaporator. Charge system to spec (1.32oz) Reporgram the Body Contro Module to latest softwear. Code S198A. Operate AC in the shop.
Parts:
1 - 92229743 - Receiver 9.195
2 - 12378526 - Lubricant 8.800
2 - 2724966 - Seal Kit 9.222
1 - 52474373 - Seal 9.222
2 - 52477087 - Seal 9.222
1 - 92229740 - *CMPR 9.170
3 - 12356150 - Refrig 8.800
4 - 12378526 - Lubricant 8.800
Good luck!
Old 08-21-2011, 01:40 PM   #5
Carver1
mine is still out of commission. Parts on national back order? This is getting old on a brand new car.......
Old 08-21-2011, 02:18 PM   #6
dianeokie
Going places
dianeokie's Avatar
That stinks....wonder if its because I am dealing with Hendrick that it got fixed so quickly.........I don't how they fixed mine and not yours......take my info in and see what they say
2011 A/C Condenser Cracked !!!!!!! GearHeadPeter Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 06-21-2011 06:33 PM
Max A/C? woodj 5th Gen Camaro SS LS LT General Discussions 6 06-04-2011 02:38 PM
a/c issues anyone have this? joes407 5th Gen Camaro SS LS LT General Discussions 16 03-18-2011 09:31 PM
update on the a/c issues for everyone joes407 5th Gen Camaro SS LS LT General Discussions 4 03-17-2011 02:02 PM
A/C turned hot, and the engine temp rose Bonemaro 5th Gen Camaro SS LS LT General Discussions 17 07-20-2010 09:04 PM
