Jason 98 TA
Old 08-09-2011, 01:25 PM   #1
valleyfreak45
Drives: 2007 Silverado
V8 mpg with 4.10 gears?
friends corvette gets 27 mpg at 75 mph with 4.10 gears. does anyone have 4.10 gears? what mpg are you getting? what gears would make better gas mileage but still have some performance?
valleyfreak45 is offline   Reply With Quote
Old 08-09-2011, 01:39 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
You could easily get 27 mpg with 4.10s if you were 600 lbs lighter like the Vette.
MPG is all in how you drive it.
SUX2BU is offline   Reply With Quote
Old 08-09-2011, 01:42 PM   #3
valleyfreak45
ya i know, i was just seeing if any gears gave better MPG than the stockers, i understand the vette is all fiberglass lol
Old 08-09-2011, 01:47 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The shorter the gears the lower it will move your car's highway mpg. Now driving around in the city, shorter gears might increase you mpg if it gets you to a cruising speed more efficiently.
Old 08-09-2011, 02:00 PM   #5
steeleshark2
steeleshark2's Avatar
In town may be a little better then current if you kept your foot out of it. On the highway, you will lose maybe 1 mpg.
Old 08-09-2011, 02:28 PM   #6
pdesanctis
i like to go fast
Drives: 2011 SS
All in all. I'd say MPG shouldn't steer you away from those 4.10's.
pdesanctis is offline   Reply With Quote
Old 08-09-2011, 02:44 PM   #7
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Just don't buy Richmond.
Old 08-09-2011, 05:01 PM   #8
steeleshark2
Mine are just fine!!
Old 08-09-2011, 05:04 PM   #9
I need 4.10's
Old 08-09-2011, 06:21 PM   #10
thundercat 1
Drives: 2010 camaro ss/rs
how about 4.33 give you a good deal.about 1200 miles on them.put 4.11 in it.thinking about supercharging it.little less gear .little bit stronger
thundercat 1 is offline   Reply With Quote
Old 08-09-2011, 10:55 PM   #11
BUMBLE-B-TUNA
BUMBLE-B-TUNA's Avatar
Drives: 2010 SS
4.10's sure are alot of fun! A little pricey after you add all the goodies and such but well worth it in the end. Not much difference in gas mileage, as stated before, its how you drive er. Which I guess I drive more agressively now cause its so much damn fun!!!
JRE 470 RWHP Rough Idle Cam & Tune, Stainless Power LT Headers w/cats, Dynatech exhaust (no drone baby) CAI Intake, 4.10 Gears, JRE Posi Mod, JRE Billet Caps, LPW Diff Cover, Pfadt Diff Bushings, MGW Shifter, SJM Line-lock and bald tires.
BUMBLE-B-TUNA is offline   Reply With Quote
Old 08-09-2011, 11:03 PM   #12
steeleshark2
Same here
Old 08-10-2011, 11:38 AM   #13
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
I have 4:33 and big cam. I get 22 - 23 mpg on highway. You have two overdrives with an M6, I think they are .84 for 5th and .57 for 6th. Around town I can shift 1 - 3- 5 just over 2,000 rpm. Did not notice much change in town but it is the red lights and traffic that kills me. Only lost 1 to 1.5 mpg with gear. 4:33 adds 110 ft. lb. of torque at launch and dropped 60 ft. .2 to 1.60. I am an opponent of stiffer differential bushings. Stock bushings are quieter (picks up less noise from after market gear) and a little flex protects the drive line.
ALWAYS TURN TC OFF ( ONE PUSH) TO SHIFT OR LAUNCH HARD. ABS kicking in to stop wheel spin while applying extra torque breaks things.
nuptualnemesis is offline   Reply With Quote
Old 08-10-2011, 03:32 PM   #14
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Same here: 19K miles and no issues!
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
any 4.10 gears out for the V6? camaro guy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 07-11-2016 04:19 PM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
Richmond Gears 4.10 ProudLS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 09-09-2010 06:53 PM
3.73 vs 4.10 gears sexystreetmachine V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 06-15-2010 10:09 PM
Jay leno hints to the z28 in video!!! tru imperial blu Camaro ZL1 Forum - ZL1 Specific Topics 103 11-27-2009 10:56 AM
