Old 08-09-2011, 06:27 PM   #1
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
broken axel fixed, now has a vibration please help
i broke my right rear axel on my vortech supercharged 2011 camaro ss at the drag stip friday. i didnt even take it to the dealer because i knew what they would say and i was worried they would fix it and then hit me with a big bill so i ordered the axel from my local dealer and fixed it myself but now there is a little vibration at higher rpms when i let off of the gas and the motor is holding it back i beleive the axel is not exactly right what do i do? all the dealer will do is tell me to bring it in and they will look at it. has anyone had this problem with a replacement gm axel? the vibration is not bad but its there and its agervating do i need to order another axel or what? please help thanks!!
casper sc/1ss/rs is offline   Reply With Quote
Old 08-09-2011, 06:42 PM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
Are you sure it's the axle? Could it be a wheel out of balance? Could it be the driveshaft couplers(another known weak point)?
Eric Baker is offline   Reply With Quote
Old 08-09-2011, 06:45 PM   #3
JETG
Drives: 2011 Camaro SS/RS
Check driveshaft, bet u have twisted bolts
JETG is offline   Reply With Quote
Old 08-09-2011, 07:09 PM   #4
casper sc/1ss/rs
this started after it broke so the i dont think its the wheel/tire but i havent checked the driveshaft i looked at it when it was on the lift but didnt think nothing about twisted bolts so i will check that first but it feels like its more in the right rear instead of the center of the rear but thanks i will check that and let everyone know thanks!
Old 08-16-2011, 12:07 AM   #5
MattyBoySS
MattyBoySS's Avatar
Drives: white with orange stripes 2SS/RS
I had the exact same thing happen to me and the exact condition you are experiencing after the axle had been replaced. I not only took the car the dealer, they replaced my axle then I noticed the vibration. Then they replaced my driveshaft and still I have a vibration. So I replaced both axles and the driveshaft with DSS parts and still feel the vibration. I drained the diff fluid and saw it looked very dark with only 4800 miles. It seemed better with the new fluid but I still feel it's not right. I think something in the posi got damaged when the axle broke. I'm going to try a new diff and see what happens. If you fix yours first let me know what you found
MattyBoySS is offline   Reply With Quote
Old 05-08-2014, 11:49 AM   #6
Brokenss
Drives: 2014 ss
I have a 2014 ss camaro with 2500 miles on it I just broke the axel my question is about the dealer I had the computer tuned and am going to have it set back to stock when I carry it there. What I'm asking is are they going to be able to see that I had all that crap turned off and running at peak performance ? I did get 8.56 in a 8th with a completly stock ss though factory tires also
Brokenss is offline   Reply With Quote
Old 05-08-2014, 12:46 PM   #7
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
You can bet the first thing they will check is for a tune and there is no way to hide it. Expect a nice repair bill and a flag in the GM warranty system.
Hannibal is offline   Reply With Quote
Old 05-08-2014, 01:32 PM   #8
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
yes, they have a TSB to look for modded software and to flag you in their warranty system.
maddoggyusa is offline   Reply With Quote
Old 05-08-2014, 04:49 PM   #9
87GNX
87GNX's Avatar
Drives: Alot
Yeah, you will be tagged by GM and you gotta pay out of pocket from now on.
87GNX is offline   Reply With Quote
axel, high rpms, rear end, vibration
Broken Half shaft Turbobitt V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 26 04-25-2011 10:14 AM
broken axel. joes407 5th Gen Camaro SS LS LT General Discussions 36 05-14-2010 07:54 PM
Car got broken into omerc10696 USA - NY / NJ / PA 20 02-01-2010 08:37 PM
Broken Links moto-camaro Camaro Photoshops / Renderings Forum 0 12-10-2009 11:17 AM
Broken Car Again speeflo Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 21 07-18-2009 07:00 PM
