HeadlightArmor
Old 08-10-2011, 12:23 AM   #1
Big Daddy Kane
Big Daddy Kane's Avatar
Drives: Red 1SS
What gears??
Ok, I know this has been discussed before, but I would like some new opinions. So far I have installed an e-force supercharger with longtubes. In a few months, I want to swap to different gears.
I've heard that 3:73 is the way to go with a supercharger. Anyone out there running 4:11s and happy with them? People that are running the 3:73s...you happy with your decision, or wished you went steeper? Not worried about top speed. I'm looking for takeoff, but not sure if 600 horsepower is too much for 4:11s.
Any thoughts?? Thanks.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces
Big Daddy Kane is offline   Reply With Quote
Old 08-10-2011, 12:56 AM   #2
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
There is a really good sticky about gearing for performance... Unless you plan on lots of suspension work and slicks, 600 might be too much with a 4.11 gear... Personally, I'm going with 3.07's... 4.11's would be goofy with my power... So would 3.73's... I spin through 4th as it is on anything less than a prepped track with my drag radials...
http://www.camaro5.com/forums/showthread.php?t=95142
Old 08-10-2011, 07:59 AM   #3
Supercharged SS
Drives: 2010 Camaro
Is your car a stick? 4.11's will be to much on the track but would make an evil street car. You'd have to drive around on slicks but if it ever hooked..watch out. Even the 3.73 may be to much but you'd be much better off with that. My car is an auto and as the HP increase we had to move to a higher gear (lower number). That's why I have a 3.45 now.
Old 08-10-2011, 09:17 AM   #4
Big Daddy Kane
Drives: Red 1SS
My car is a stick. It will only see the track a few times. I'm looking for more fun on the street than the track. This is good info, thanks guys.
Old 08-10-2011, 10:56 AM   #5
steeleshark2
steeleshark2's Avatar
4.11s are too much gear for a supercharger.
Old 08-10-2011, 11:01 AM   #6
Camaro21
Drives: SOLD - 2013 M6 ZL1
I have 3.70 gears from ADM and it is good for a daily driver. I can go 80 and still be under 2000 rpm's.
Camaro21 is offline   Reply With Quote
Old 08-10-2011, 11:16 AM   #7
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Being that you have an e-force, low end might just be too crazy w/ 4.11's...1st gear will be almost useless. 3.73's would be a good choice IMO. 4.11's would be a better choice w/ a vortech sc because the power curve is higher. Either way you should also be looking into some stickier tires.
on a N/A-M6 car, 4.11's are PERFECT.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 08-10-2011, 11:29 AM   #8
steeleshark2
AGREED!!!
Old 08-10-2011, 03:48 PM   #9
Big Daddy Kane
Drives: Red 1SS
Hey, thanks guys. I appreciate the responses. Seems like 3.73s are the way to go.
Old 08-10-2011, 04:28 PM   #10
600hp-lpe
Drives: 2010
I have 4.10's with an M6 and 2300 Maggie... My car is used as a race car for Autocross. I use either 2nd or third gear depending on the track layout.
I would not want to drive on the street with these gears. 1st and and 2nd are too low, and way too much noise in 6th on the highway.
I would recommend a 3.73 or stay with the 3.45. I would think 3.73's are perfect for your application.
600hp-lpe is offline   Reply With Quote
Old 08-10-2011, 10:10 PM   #11
Smoky10
Drives: 2010 Camaro 2SS
Wouldn't 3.90s also be ok for a e-force supercharged camaro? Or would that be to much gear also?
Smoky10 is offline   Reply With Quote
Old 08-11-2011, 12:06 AM   #12
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Hey op, I'm not sure if you know this, but on a supercharged car making good power, you go the other way with you're gearing. You'll go faster.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 08-11-2011, 08:42 AM   #13
POWERFREAK
I.AM.
POWERFREAK's Avatar
you go "the other way" with your gearing, your top speed will be higher on any car...but he said he wasn't worried about top speed, but swapping stock gears for 3.73's isn't going to make that much of a difference w/ top speed.
Gears will also improve the way your clutch feels, which is a nice plus.
Wouldn't be a bad choice I guess if you wanted a little more radical low end...a "split the difference gear". Does anyone even make 3.90's for these cars?
NY5thgen.com
Old 08-11-2011, 09:04 AM   #14
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Yes, AAM makes a 3.70 and 3.90 gears that are available through LPE. They are quite expensive, but so far they have been proven to be far superior to the Richmond gears in both strength and noise.
blazzin1 is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
AAM 3.91 Gears...Very Nice StreetStrip V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 36 06-05-2017 08:44 AM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 11:58 PM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
