SDTW Custom Wheels & Tires
Old 08-10-2011, 02:25 PM   #1
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Car not level...
It's only 3/16th of an inch, but I wonder why my driver side would be higher than the passenger side? Not normal obviously... But it wonders me. I've only installed sways, so I doubt that would of messed anything up. I've noticed the slight lean for a while, just never measured it.. Am I being too anal about this, or a concern? Thanks for any help.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 08-10-2011, 02:43 PM   #2
toilets
Drives: 2010 camaro
Front or rear?
toilets is offline   Reply With Quote
Old 08-10-2011, 02:45 PM   #3
toilets
Drives: 2010 camaro
Actually I would like to have that if it were me. if its both I would think that would be ideal so when you sit in the car it would be somewhat level. 3/16th is only about a 4mm difference in height.
Old 08-10-2011, 03:14 PM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
3/16th's of an inch is pretty small...
You mentioned that you've only got sway bars installed on the car, next time your at the dealer for a checkup it may be worth mentioning to them.
It's a long shot but you mentioned that you have Aftermarket Sway bars. One thing you can do if you have adjustable endlinks is to make sure the sway bar isn't preloaded while the car is at ride height on the ground. You can do this by disconnecting both endlinks on each bar while the car is in the air, then put the car back on the ground and when the car is at ride height adjust the length of your endlink so that the studs in the endlink match up with the holes in the control arm and sway bar. Once you've got one endlink front and rear at the proper length match the corresponding enddlink to the same length and install them on the car.
Chances are slim that this is causing your problem, but if it's really bugging you it's worth a check.
Old 08-10-2011, 03:50 PM   #5
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
It's both front and rear, just much more of a difference in the back.
Old 08-10-2011, 04:51 PM   #6
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Dan,
There is a considerable acceptable variation in all springs from OE through aftermarket. The body is built withing a tolerance range as well.
At Pedders we measure ride height from the bottom of the wheel rim lip, up through the wheel center to the painted edge of the fender in mm.
This eliminates tire size, tire profile and inflation from the measurement. With the car parked on a level surface, empty as though it were new with a 1/4 tank of fuel delivers a sound measurement. There are more detailed and accurate methods, but those require the car to be on a lift or frame machine.
If you would consider measuring this way we can compare it accurately to the measurements we have on file for OE Camaros. All we need to confirm is your wheel size.
Typically a SS 5th gen with 20s sits at 690mm front and 700mm rear. The variation we have on file is +/- 5mm. 3/16 = just over 4mm or well within range of what we measure as an acceptable tolerance from the factory.
Old 08-10-2011, 05:50 PM   #7
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Thanks Pete! I'll have to give you an accurate measurement, but it's not off far enough to worry me.
Dan,
Old 08-10-2011, 05:58 PM   #8
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
to account for the weight of the driver. have someone measure it while you are sitting in the car.
almost every car on the road has this offset its just that most people just never pay attention to it
I piss excellence
and fart awesomeness
Old 08-10-2011, 06:01 PM   #9
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
I had no idea there was an offset in new cars to account for the driver, if that's the case, then I'll measure with someone in it, thanks
Old 08-10-2011, 06:05 PM   #10
CamaroSpike23
Truth Enforcer
its nothing new. just about every car I've ever owned has had a slightly higher ride height on the drivers side over the pass side.
I remember quite a few threads on another forum years ago when people would swap their springs out on their 4th gens and they'd complain that their drivers side wheels were rubbing when they would drive and that the car didnt look right when pictures were taken with them in the car after swapping the springs.
I piss excellence
Old 08-10-2011, 09:04 PM   #11
JusticePete
On the 5th Gen the coils are the same side to side, but you are correct in that other cars have left and right hand coils. Our GTO rear coils are the same, but the front are left and right.
Old 08-11-2011, 03:59 PM   #12
caligrown562
Drives: 2012 1SS
I have the same problem but its my driver side that's lower. It feels like I am driving sideways down the road. My front is about a 1/4 inch lower and the rear is 1/2 inch lower. I have no clue what could be wrong...
caligrown562 is offline   Reply With Quote
Old 08-11-2011, 04:27 PM   #13
JusticePete
Please measure using the Pedders methodlogy so we can see where you are relative to our database.
Old 08-11-2011, 09:18 PM   #14
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
So I had my gf sit in my car this morning while I re-measured it, and to my surprise, the car sat level... Thanks for everyone's help.
popping in front end when I hit a bump soonerfanru2 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 697 10-01-2017 10:29 AM
Understanding Paint Correction-The Nitty-Gritty Mr CLuTcH Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 29 03-02-2012 04:51 AM
What makes a car a "tuner" car? Dentyneice General Automotive + Other Cars Discussion 8 05-11-2009 11:19 PM
09 Mustang GT and 09 Challenger R/T test drives CamaroSpike23 General Automotive + Other Cars Discussion 19 04-10-2009 05:27 PM
