Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 08-11-2011, 01:04 AM   #1
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Have You Changed Your A6 Trans Fluid?
So GM says our automatic transmission fluid is good for approximately 100,000 miles, and shouldn't need changing before that.
They same about the same thing with differential fluid, and as many have done, changed it and saw shavings and dark, burnt fluid.
A couple weeks ago we converted an L99 into an LS3 with cam, and installed an ECS supercharger. We looked over the car to ensure it would all be ok, which included checking the transmission fluid.
The car had 34,000 miles on it.
(Needless to say, we serviced the transmission, with new fluid and filter)
- Jeremy
Click HERE to send me a PM | | | 801-545-4215
Old 08-11-2011, 05:37 AM   #2
Scott@Bjorn3D's Avatar
I talked with Ted Jannetty and with all the racing he does I figure he would know. Every 25K on transmission and rear end fluid. So that is what I do.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-11-2011, 08:15 AM   #3
Sales @ ECS
Sales @ ECS's Avatar
Drives: 2011 CG 2SS
Wow check that out... We have done numerous A6 fluid changes on the Camaros/Vettes, depending on the abuse we have seen the same on even lower mileage cars!
Speaking of that ECS supercharger kit
Sales @ ECS is offline   Reply With Quote
Old 08-11-2011, 08:53 AM   #4
RS/4Life's Avatar
Drives: 2014 2ss/rs
When i need mine done i will bring it to you matt.
RS/4Life is offline   Reply With Quote
DIY - V8 L99 Automatic Transmission Fluid Change Goliath Camaro DIY & HOW-TO instructions & discussions 72 08-06-2017 06:52 AM
What trans fluid to use HaZe_X Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 29 10-16-2011 12:27 PM
2011 Dodge Challenger SRT8 392 Sawyer Chevy Camaro vs... 277 08-01-2011 03:28 AM
Changed the Diff and M6 trans fluid today... FirstLSK Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 04-15-2010 08:21 AM
Did Amsoil change their ATF Dex III? What is the best for the TR6060 now? Russell James Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 11 01-29-2010 06:00 PM
