Cold Air Inductions
Old 08-11-2011, 07:20 AM   #1
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Aftermarket Tranmission for v6
Are there any options for a aftermarket transmission to replace our AY6?
c_LoW29 is offline   Reply With Quote
Old 08-11-2011, 11:00 AM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I'm with you Mr. Lo.
I asked Rick (RKT56) at T&T performance if they offered anything for us and he said not at this time.
Maybe if enough of us ask nicely they'll will see the need to do so.
Now that Chevy has announced a change to the 2nd gear synchro for the V8 manual trans (new "carbon material" with advanced design), maybe it will trickle down to V6 owners if enough noise is made.
Worse case scenario then would be even if we can't get a recall, a fix would be available for a local shop to rebuild your trans when the original synchro is toast.
Old 08-11-2011, 12:53 PM   #3
Mach
Mach's Avatar
Drives: White M6 1LT RS
Let's keep making noise. We should get at least 50 of us to file the complaint. After all 185 of us voted it was an issue.
Here is the link to the NHTSB complaint form...
https://www-odi.nhtsa.dot.gov/portable/index.cfm
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 08-12-2011, 06:50 PM   #4
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
If it only took 36 for the mustang, 185 should really get their attention.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
not sure wht i want, please help streetsteve 5th Gen Camaro SS LS LT General Discussions 11 11-30-2009 08:58 AM
Muffler Delete or Aftermarket? JohnForeman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 11-01-2009 11:46 AM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 07:37 PM
Aftermarket Exhausts Kinetic Kev HWSE 2013 USA - New England 1 10-01-2009 08:55 PM
aftermarket companies listening? boxmonkeyracing 5th Gen Camaro SS LS LT General Discussions 24 12-13-2008 11:10 PM
