Old 08-12-2011, 03:02 PM   #1
MattF
MaroMan426
Drives: 2011 Camaro 1ss
Send a message via AIM to MattF Send a message via Skype™ to MattF
Squeaky brakes on my Camaro SS after 17,000 miles
my brakes are squeakin up a storm. only 17,000 on the car and i dont drive hard. is this normal? it has the brembo kit that comes standard on the SS
MattF is offline   Reply With Quote
Old 08-12-2011, 03:05 PM   #2
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
Theres about 4 million threads on this.
The brembos squeak but theres many options to fix it. Try the Suspension and brakes forum here.
2010 Chevrolet Camaro SS - was daily driver, now toy
2014 Mercedes Benz E350 4matic Sport - Daily Driver
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1995 Volkswagen Golf Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 08-12-2011, 03:06 PM   #3
MattF
MaroMan426
thank you sir
Old 08-12-2011, 05:12 PM   #4
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
MattF,
Does your Camaro have stick on weight attached to the calipers or rollers (roller skates) attached to the brake pads?
Old 08-12-2011, 07:15 PM   #5
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
I developed the same thing at 15k miles. Upgraded to Hawk HPS ceramic pads - double bonus, no more squeal and a lot less brake dust. Good Luck.
CaniacFan is offline   Reply With Quote
Old 08-14-2011, 01:08 AM   #6
MattF
MaroMan426
yes it does have the roller skates on it..... @ caniacfan thanks for the recommendation. ill be sure to check them out
Old 08-15-2011, 12:53 PM   #7
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
can any supply the part # for this set of pads?
ipimpthisc is offline   Reply With Quote
Old 08-16-2011, 04:20 AM   #8
M-SS
M-SS's Avatar
Drives: Camaro SS 2010
so the Hawk HPS ceramic pads will eliminate the noise ???????
M-SS is offline   Reply With Quote
Old 08-16-2011, 08:38 AM   #9
clg_98ta
clg_98ta's Avatar
The Hawk HPS pads are metallic rather than ceramic.
I have the Hawk Ceramics and do still get occasional low speed (i.e. rolling to a stop) squeal.
Old 08-22-2011, 08:19 AM   #10
M-SS
M-SS's Avatar
Which is worse ?
Old 08-22-2011, 07:59 PM   #11
JusticePete
VIR Specialist
There are three possible explanations.
1. It is the noise that is common to the 5th Gen brakes.
2. They need to be bedded. Find a quiet highway where you can safely accelerate and brake. Run up to 55MPH and stand on the brakes down to 35, up to 65 MPH stand on the brakes down to 35, Up to 75 MPH stand on the brakes down to 35 MPH. Drive at least five miles to let the brakes cool. When you park, leave it in gear or Park. D NOT use the e-brake. We want to avoid pad transfer.
3. You drive hard and need to replace your pads.
You should inspect your pads to make sure there is sufficient pad left to bed them.
If you do burn outs and ride you brake pedal the rears glaze making the noise worse.
If you drive very gently, the pads never really bed and make more noise.
Do the inspection, make sure you have at least 50% of a new pad and give the bedding process a shot. It has worked for quite a few people.
Old 08-23-2011, 04:51 PM   #12
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Same here. 'Seems to be a common thing w/ Brembo brakes. 'Had the same thing from day one w/ my old '04 G35 coupe that had factory Brembos also.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
For Sale: Tjin Edition Chevy Camaro SS (GM Design Award Best GM Vehicle) Tjin Edition Camaro Autos For Sale / Wanted 34 10-11-2013 06:31 PM
Automobile Reviews 2011 Chevrolet Camaro Convertible 2SS Tran Camaro Convertible Forum 33 07-28-2011 07:36 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
